山东晶导微电子股份有限公司
Jingdao Microelectronics co.LTD
P4SMAF Series
Surface mount transient voltage suppressor power 400 watts
Stand-Off Voltage:6.8V~550V
FEATURES
PINNING
• For surface mounted applications in order to
PIN
optimize board space.
• Low profile package
DESCRIPTION
1
Cathode
2
Anode
• Glass passivated junction
1
• Low inductance
2
Unipolar
• Plastic package has Underwriters Laboratory
Flammability
Bipolar
MECHANICAL DATA
Top View
Simplified outline SMAF and symbol
• Case: SMAF
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 27mg 0.00095oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Symbol
Value
Unit
Peak Pulse Power Dissipation on 10/1000us waveform
P PPM
400
W
Peak Forward Surge Current (Note 2,Fig 4)
I FSM
60
A
Peak Pulse Current on 10/1000 us waveform (Note 1, Fig 2)
I PPM
see Table 1
A
Typical Junction capacitance at VR=4V, f=1MHz
CJ
390
pF
Parameter
ESD Voltage per IEC6100-4-2
Contact
Air
V ESD1
V ESD2
Typical Thermal Resistance Junction to Ambient(Note 2)
RθJA
Operating Junction Temperature and Storage Temperature Range
T j , T stg
8
15
kV
120
°C/W
-55 ~ +150
°C
NOTES:
1. Non-repetitive current pulse, per Fig.3 and derated above T A = 25°C per Fig. 2.
2. Mounted on FR-4 PCB single-sided copper, mini pad.
3. Peak Forward Surge Current : 8.3ms single half sine-wave Superimposed on rated load (JEDEC method).
4. Peak pulse power waveform is 10/1000μS.
2017.01
SMAF-TVS-P4SMAF Series -400W
Page 1 of 4
山东晶导微电子股份有限公司
P4SMAF Series
Characteristics at Ta = 25°C
Table 1
Reverse
Stand-off
Voltage
Type
UNI
BI
Breakdown
Voltage
V BR @ I T
Reverse
Leakage
Max. Clamp
Voltage
IT
I R @ V RRM
V C @ I PP
I PP
A
Test
Current
V RRM
Min
Max
V
V
V
mA
μA
V
Package
Peak Pulse
Current
SMAF
Device Marking Ccode
UNI
BI
P4SMAF6.8A
P4SMAF6.8CA
5.8
6.45
7.14
10
1000
10.5
39
6V8A
6V8C
P4SMAF7.5A
P4SMAF7.5CA
6.4
7.13
7.88
10
500
11.3
36.3
7V5A
7V5C
P4SMAF8.2A
P4SMAF8.2CA
7.02
7.79
8.61
10
200
12.1
33.9
8V2A
8V2C
P4SMAF9.1A
P4SMAF9.1CA
7.78
8.65
9.55
1
200
13.4
30.6
9V1A
9V1C
10C
P4SMAF10A
P4SMAF10CA
8.55
9.5
10.5
1
50
14.5
28.3
10A
P4SMAF11A
P4SMAF11CA
9.4
10.5
11.6
1
10
15.6
26.3
11A
11C
P4SMAF12A
P4SMAF12CA
10.2
11.4
12.6
1
5
16.7
24.6
12A
12C
P4SMAF13A
P4SMAF13CA
11.1
12.4
13.7
1
5
18.2
22.5
13A
13C
P4SMAF15A
P4SMAF15CA
12.8
14.3
15.8
1
1
21.2
19.3
15A
15C
P4SMAF16A
P4SMAF16CA
13.6
15.2
16.8
1
1
22.5
18.2
16A
16C
P4SMAF18A
P4SMAF18CA
15.3
17.1
18.9
1
1
25.5
16.1
18A
18C
P4SMAF20A
P4SMAF20CA
17.1
19
21
1
1
27.7
14.8
20A
20C
P4SMAF22A
P4SMAF22CA
18.8
20.9
23.1
1
1
30.6
13.4
22A
22C
P4SMAF24A
P4SMAF24CA
20.5
22.8
25.2
1
1
33.2
12.3
24A
24C
P4SMAF27A
P4SMAF27CA
23.1
25.7
28.4
1
1
37.5
10.9
27A
27C
P4SMAF30A
P4SMAF30CA
25.6
28.5
31.5
1
1
41.4
9.9
30A
30C
P4SMAF33A
P4SMAF33CA
28.2
31.4
34.7
1
1
45.7
9
33A
33C
P4SMAF36A
P4SMAF36CA
30.8
34.2
37.8
1
1
49.9
8.2
36A
36C
P4SMAF39A
P4SMAF39CA
33.3
37.1
41
1
1
53.9
7.6
39A
39C
P4SMAF43A
P4SMAF43CA
36.8
40.9
45.2
1
1
59.3
6.9
43A
43C
P4SMAF47A
P4SMAF47CA
40.2
44.7
49.4
1
1
64.8
6.3
47A
47C
P4SMAF51A
P4SMAF51CA
43.6
48.5
53.6
1
1
70.1
5.8
51A
51C
P4SMAF56A
P4SMAF56CA
47.8
53.2
58.8
1
1
77
5.3
56A
56C
P4SMAF62A
P4SMAF62CA
53
58.9
65.1
1
1
85
4.8
62A
62C
P4SMAF68A
P4SMAF68CA
58.1
64.6
71.4
1
1
92
4.5
68A
68C
P4SMAF75A
P4SMAF75CA
64.1
71.3
78.8
1
1
103
4
75A
75C
P4SMAF82A
P4SMAF82CA
70.1
77.9
86.1
1
1
113
3.6
82A
82C
P4SMAF91A
P4SMAF91CA
77.8
86.5
95.5
1
1
125
3.3
91A
91C
P4SMAF100A
P4SMAF100CA
85.5
95
105
1
1
137
3
100A
100C
P4SMAF110A
P4SMAF110CA
94
105
116
1
1
152
2.7
110A
110C
P4SMAF120A
P4SMAF120CA
102
114
126
1
1
165
2.5
120A
120C
P4SMAF130A
P4SMAF130CA
111
124
137
1
1
179
2.3
130A
130C
P4SMAF150A
P4SMAF150CA
128
143
158
1
1
207
2
150A
150C
P4SMAF160A
P4SMAF160CA
136
152
168
1
1
219
1.9
160A
160C
P4SMAF170A
P4SMAF170CA
145
162
179
1
1
234
1.8
170A
170C
P4SMAF180A
P4SMAF180CA
154
171
189
1
1
246
1.7
180A
180C
P4SMAF200A
P4SMAF200CA
171
190
210
1
1
274
1.5
200A
200C
P4SMAF220A
P4SMAF220CA
185
209
231
1
1
328
1.3
220A
220C
P4SMAF250A
P4SMAF250CA
214
237
263
1
1
344
1.2
250A
250C
P4SMAF300A
P4SMAF300CA
256
285
315
1
1
414
1
300A
300C
P4SMAF350A
P4SMAF350CA
300
332
368
1
1
482
0.9
350A
350C
P4SMAF400A
P4SMAF400CA
342
380
420
1
1
548
0.8
400A
400C
P4SMAF440A
P4SMAF440CA
376
418
462
1
1
602
0.7
440A
440C
P4SMAF480A
P4SMAF480CA
408
456
504
1
1
658
0.6
480A
480C
P4SMAF510A
P4SMAF510CA
434
485
535
1
1
698
0.6
510A
510C
P4SMAF530A
P4SMAF530CA
451
503.5
556.5
1
1
725
0.6
530A
530C
P4SMAF540A
P4SMAF540CA
460
513
567
1
1
740
0.5
540A
540C
P4SMAF550A
P4SMAF550CA
468
522.5
577.5
1
1
760
0.5
550A
550C
2017.01
www.sdjingdao.com
Page 2 of 4
山东晶导微电子股份有限公司
P4SMAF Series
Fig.2 Forward Current Derating Curve
100
Non-Repetive Pulse.Wavefom
Shown in Figure.3
T A=25°C
10
1.0
Mounted on 5.0mm
Copper Land Areas
0.1
0.1
1
10
100
1000
10000
PEAK PULSE POWER(P PP)OR CURRENT(I PP)
DERATINGIN PERCENTAGE%
P PPM,PEAK PULSE FORWARD ,kW
Fig.1 Peak Pulse Power Rating Curve
100
80
60
40
I ppm ,Peak Pulse Current (%)
Peak Value
Pulse Width (td) is Defined
as the Point where the Peak.
Current Decayst to 50% of Ipp
I ppm
80
Half Value-I pp /2
60
10/1000usec Waveform as Defined bye R.E.A.
40
2.0
3.0
4.0
I FSM,PEAK FORWARD SURGE CURRENT,
AMPERES
T A =25°C
100
125
150
175
60
50
40
30
T,TIME,ms
2017.01
100
Fig.4 Maximum Non-Repetitive Peak
Fig.3 Pulse Waveform
t f =10usec
75
T A,AMBIENT TEMPERATURE,°C
t d,PULSE WIDTH ,us
120
50
T J=T Jmax
8.3ms Single Half Sinepwave
JEDEC Method
10
100
Number of Cycles at 60Hz
www.sdjingdao.com
Page 3 of 4
山东晶导微电子股份有限公司
P4SMAF Series
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SMAF
∠ALL ROUND
C
A
∠ALL ROUND
HE
g
Top View
mil
Bottom View
A
C
D
E
e
g
HE
max
1.2
0.20
3.7
2.7
1.6
1.2
4.9
min
0.9
0.12
3.3
2.4
1.3
0.8
4.4
max
43
7.9
146
106
63
47
193
min
35
4.7
130
94
51
31
173
UNIT
mm
g
pad
e
E
A
pad
D
E
A
V M
7°
The recommended mounting pad size
2.2
(86)
1.6
(63)
1.8
(71)
1.6
(63)
mm
Unit :
(mil)
2017.01
JD 80404 6B0/7B2
Page 4 of 4
很抱歉,暂时无法提供与“P4SMAF150CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.23242
- 200+0.17993
- 600+0.15077
