SMAJ5.0CA
SMAJ5.0CA
    HXY(华轩阳)
    SMA(DO-214AC)
    双向TVS 5V截止 峰值脉冲电流:43.5A
SMAJ5.0CA 数据手册
HUAXUANYANG SMAJ5.0(C)A-SMAJ440(C)A HXY ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR Features For surface mounted applications in order to optimize board space Low profile package Built-in strain relief Glass passivated junction Low inductance Excellent clamping capability 400W peak pulse power capability at 10/1000μs waveform, Repetition rate (duty cycle): 0.01% SMA Fast response time Typical IR less than 1μA above 10V High Temperature soldering: 260C/10 seconds at terminals Plastic package has underwriters laboratory flammability 94V-0 Mechanical Data Part Number Code Case : JEDEC DO-2 1 4 AC/ SMA molded plastic body Terminals : Solderable per MIL-STD-7 50 , Method 202 6 Polarity : Polarity symbol Mounting Position : Any SMAJ XXX C A 5% VBR Voltage Tolerance marking on body Bidirectional Weight : 0.07 grams Marking : Date Code and Marking Code See Page 3 Voltage Series Code Applications I/O interface AC/DC power supply Low frequency signal transmission line (RS232, RS485, etc.) MAXIMUM RATINGS AND CHARACTERISTICS Ratings at 2 5 C ambient temperature unless otherwise specified. Peak pulse power dissipation at 1 0 / 1 0 0 0 hs waveform ( Note1 , Note2 , Fig . 1 ) PPP M Peak pulse current of at 1 0 / 1 0 0 0 hs waveform ( Note 1 , Fig . 3 ) I PP M Steady state power dissipation at TA = 5 0 C ( Fig . 5 ) Peak forward surge current, superimposed on rated load, Operating junction and Storage Temperature Typical thermal resistance junction Typical thermal resistance junction to to Range lead ambient . See W Table A 3. 3 W IFS M 40 A TJ , TSTG - 6 5 to + 1 5 0 C PM( 8 . 3 ms single half sine- wave ( JEDEC Method) ( Note3 , Fig . 6 ) Minimum 4 0 0 AV) Rθ JL 30 C/ W Rθ JA 1 20 C/ W Notes: 1 . Non- repetitive current pulse, per Fig . 3 and derated above TA = 2 5 C per Fig . 2 . 2 . Mounted on 5 . 0 mm× 5 . 0 mm ( 0 . 0 3 mm thick) copper pads to each terminal . 3 . 8 . 3 ms single half sine- wave, or equivalent square wave, duty cycle= 4 pulses per minutes maximum . Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HUAXUANYANG SMAJ5.0(C)A-SMAJ440(C)A HXY ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR Electrical Characteristics (TA=25°C) Part Number Device Marking Code Reverse Stand- Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) SMAJ5.0A SMAJ5.0CA AE WE 5.0 6.40~7.00 10 9.2 43.5 800 SMAJ6.0A SMAJ6.0CA AG WG 6.0 6.67~7.37 10 10.3 38.8 800 SMAJ6.5A SMAJ6.5CA AK WK 6.5 7.22~7.98 10 11.2 35.7 500 SMAJ7.0A SMAJ7.0CA AM WM 7.0 7.78~8.60 10 12.0 33.3 200 SMAJ7.5A SMAJ7.5CA AP WP 7.5 8.33~9.21 1 12.9 31.0 100 SMAJ8.0A SMAJ8.0CA AR WR 8.0 8.89~9.83 1 13.6 29.4 50 SMAJ8.5A SMAJ8.5CA AT WT 8.5 9.44~10.40 1 14.4 27.8 20 SMAJ9.0A SMAJ9.0CA AV WV 9.0 10.00~11.10 1 15.4 26.0 10 SMAJ10A SMAJ10CA AX WX 10.0 11.10~12.30 1 17.0 23.5 5 SMAJ11A SMAJ11CA AZ WZ 11.0 12.20~13.50 1 18.2 22.0 1 SMAJ12A SMAJ12CA BE XE 12.0 13.30~14.70 1 19.9 20.1 1 SMAJ13A SMAJ13CA BG XG 13.0 14.40~15.90 1 21.5 18.6 1 SMAJ14A SMAJ14CA BK XK 14.0 15.60~17.20 1 23.2 17.2 1 SMAJ15A SMAJ15CA BM XM 15.0 16.70~18.50 1 24.4 16.4 1 SMAJ16A SMAJ16CA BP XP 16.0 17.80~19.70 1 26.0 15.4 1 SMAJ17A SMAJ17CA BR XR 17.0 18.90~20.90 1 27.6 14.5 1 SMAJ18A SMAJ18CA BT XT 18.0 20.00~22.10 1 29.2 13.7 1 SMAJ20A SMAJ20CA BV X 20.0 22.20~24.50 1 32.4 12.3 1 SMAJ22A SMAJ22CA BX XX 22.0 24.40~26.90 1 35.5 11.3 1 SMAJ24A SMAJ24CA BZ XZ 24.0 26.70~29.50 1 38.9 10.3 1 SMAJ26A SMAJ26CA CE YE 26.0 28.90~31.90 1 42.1 9.5 1 SMAJ28A SMAJ28CA CG YG 28.0 31.10~34.40 1 45.4 8.8 1 SMAJ30A SMAJ30CA CK YK 30.0 33.30~36.80 1 48.4 8.3 1 SMAJ33A SMAJ33CA CM YM 33.0 36.70~40.60 1 53.3 7.5 1 SMAJ36A SMAJ36CA CP YP 36.0 40.00~44.20 1 58.1 6.9 1 SMAJ40A SMAJ40CA CR YR 40.0 44.40~49.10 1 64.5 6.2 1 SMAJ43A SMAJ43CA CT YT 43.0 47.80~52.80 1 69.4 5.8 1 SMAJ45A SMAJ45CA CV YV 45.0 50.00~55.30 1 72.7 5.5 1 SMAJ48A SMAJ48CA CX YX 48.0 53.30~58.90 1 77.4 5.2 1 SMAJ51A SMAJ51CA CZ YZ 51.0 56.70~62.70 1 82.4 4.9 1 Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HUAXUANYANG SMAJ5.0(C)A-SMAJ440(C)A HXY ELECTRONICS CO.,LTD Part Number TRANSIENT VOLTAGE SUPPRESSOR Device Marking Code Reverse Stand- Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) SMAJ54A SMAJ54CA RE ZE 54.0 60.00~66.30 1 87.1 4.6 1 SMAJ58A SMAJ58CA RG ZG 58.0 64.40~71.20 1 93.6 4.3 1 SMAJ60A SMAJ60CA RK ZK 60.0 66.70~73.70 1 96.8 4.1 1 SMAJ64A SMAJ64CA RM ZM 64.0 71.10~78.60 1 103.0 3.9 1 SMAJ70A SMAJ70CA RP ZP 70.0 77.80~86.00 1 113.0 3.5 1 SMAJ75A SMAJ75CA RR ZR 75.0 83.30~92.10 1 121.0 3.3 1 SMAJ78A SMAJ78CA RT ZT 78.0 86.70~95.80 1 126.0 3.2 1 SMAJ85A SMAJ85CA RV ZV 85.0 94.40~104.00 1 137.0 2.9 1 SMAJ90A SMAJ90CA RX ZX 90.0 100.00~111.00 1 146.0 2.7 1 SMAJ100A SMAJ100CA RZ ZZ 100.0 111.00~123.00 1 162.0 2.5 1 SMAJ110A SMAJ110CA SE VE 110.0 122.00~135.00 1 177.0 2.3 1 SMAJ120A SMAJ120CA SG VG 120.0 133.00~147.00 1 193.0 2.1 1 SMAJ130A SMAJ130CA SK VK 130.0 144.00~159.00 1 209.0 1.9 1 SMAJ150A SMAJ150CA SM VM 150.0 167.00~185.00 1 243.0 1.6 1 SMAJ160A SMAJ160CA SP VP 160.0 178.00~197.00 1 259.0 1.5 1 SMAJ170A SMAJ170CA SR VR 170.0 189.00~209.00 1 275.0 1.5 1 SMAJ180A SMAJ180CA ST VT 180.0 201.00~222.00 1 292.0 1.4 1 SMAJ190A SMAJ190CA SU YU 190.0 211.00~233.00 1 308.0 1.3 1 SMAJ200A SMAJ200CA SV VV 200.0 224.00~247.00 1 324.0 1.2 1 SMAJ210A SMAJ210CA SW YW 210.0 237.00~263.00 1 340.0 1.2 1 SMAJ220A SMAJ220CA GE VX 220.0 246.00~272.00 1 356.0 1.1 1 SMAJ250A SMAJ250CA SZ VZ 250.0 279.00~309.00 1 405.0 1.0 1 SMAJ300A SMAJ300CA TE UE 300.0 335.00~371.00 1 486.0 0.8 1 SMAJ350A SMAJ350CA TG UG 350.0 391.00~432.00 1 567.0 0.7 1 SMAJ400A SMAJ400CA TK UK 400.0 447.00~494.00 1 648.0 0.6 1 SMAJ440A SMAJ440CA TM UM 440.0 492.00~543.00 1 713.0 0.6 1 Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HUAXUANYANG SMAJ5.0(C)A-SMAJ440(C)A HXY ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR Ratings and Characteristic Curves (TA=25°C unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve 100 10 80 60 1 40 20 0.2×0 .2 ″ (5 .0×5 .0m m) Copp er Pa d Ar ea 0.1 1 10 100 0 1000 0 td- Pulse Width ( µ s) 75 100 125 150 175 Figure 4. Typical Junction Capacitance t r=10 µs 10000 TJ = 2 5 C Pulse W idth(t d ) is defined as the point where t he peak current decays to 50% of I Peak Valu e I 100 50 TA- Ambient Temperature ( C) Figure 3. Pulse Waveform 150 25 Bi - directional V= 0 V P PM 1000 U ni- directio na l V= 0V PPM Uni- di r ectio nal @ V R 100 Half Value PPM ( IP PM /2) 50 10 10 / 10 0 0 µ s Wa v e f o rm as defined by R. E. A td 0 0 1 1.0 2.0 t-Time (ms) 3.0 4.0 Figure 5 . Steady State Power Dissipation Derating R T J= 2 5 C f= 1 .0 M H z Vsig= 50 mVp -p 1 100 10 1000 VBR -Reverse Breakdown Voltage (V) Figure 6 . Maximum Non- Repetitive Forward Curve Surge Current Uni- Directional Only 45 3.6 40 3.0 35 30 2.4 25 1.8 20 15 1.2 10 0.6 0 Bi- dir ec tional @ V 5 0 0 25 50 75 100 125 150 TA- Ambient Temperature ( C) Shenzhen HuaXuanYang Electronics CO.,LTD 175 1 10 100 Number of Cycles at 60Hz www.hxymos.com HUAXUANYANG HXY ELECTRONICS CO.,LTD SMAJ5.0(C)A-SMAJ440(C)A TRANSIENT VOLTAGE SUPPRESSOR SMA Package Outline Dimensions 0.106(2.70) 0.096(2.45) Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HUAXUANYANG SMAJ5.0(C)A-SMAJ440(C)A HXY ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR Attention ■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein in such applications. ■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein. ■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. ■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design. ■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA XUAN YANG ELECTRONICS CO.,LTD. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com
SMAJ5.0CA 价格&库存
很抱歉,暂时无法提供与“SMAJ5.0CA”相匹配的价格&库存,您可以联系我们找货
SMAJ5.0CA
  • 1+0.41250
  • 500+0.13750
  • 2500+0.09163
  • 5000+0.07513
库存:3640
SMAJ5.0CA
库存:360000
SMAJ5.0CA
  • 1+0.08980
库存:75
