SMAFJ220A
SMAFJ220A
    YFW(佑风微)
    SMA-F
    单向TVS 220V截止 峰值浪涌电流:1.1A@10/1000US
SMAFJ220A 数据手册
P4SMAFJ5.0A(CA) THRU P4SMAFJ220A(CA) SMAF Surface mount transient voltage suppressor power 400 watts Stand-Off Voltage: 5.0V~220V Pinning 1.Cathode 2.Anode       FEATURES 1    For surface mounted applications in order tooptimize board space.  Low profile package.     2 Unipolar  Glass passivated junction.  Low inductance. Bipolar  Plastic package has Underwriters Laboratory Flammability. SMAF MECHANICAL DATA  Case: SMAF  Terminals: Solderable per MIL-STD-750, Method 2026  Approx. Weight: 27mg / 0.00095oz Maximum Ratings and Electrical characteristics Ratings at 25 ambient temperature unless o °C therwise specified. Parameter Symbol Value Unit Peak Pulse Power Dissipation on TA=25°C (Note 1,2,5, Fig1) PPPM 400 W Peak Forward Surge Current (Note3, Note4) IFSM (UNI) 40 A IPPM see Table 1 A Contact VESD1 ±30 Air VESD2 ±30 Cj 390 pF RθJA 70 °C TJ,TSTG -55 to +150 °C Peak Pulse Current on 10/1000 us waveform (Note 1) Fig 3 ESD Voltage per IEC6100-4-2 kV Typical Junction Capacitance at VR=4V, f=1MHz Typical Thermal Resistance Junction to Ambient(Note 2) Operating Junction Temperature and Storage Temperature Range NOTES: 1. Non-repetitive current pulse, per Fig.3 and derated above TA = 25°C per Fig. 2. 2. Mounted on 5mm2 copper pads to each terminal. 3. Peak Forward Surge Current : 8.3ms single half sine-wave Superimposed on rated load (JEDEC method). 4. Peak pulse power waveform is 10/1000μS. www.yfwdiode.com 1/5 G uangDong YFW Electronics Co, Ltd. P4SMAFJ5.0A(CA) THRU P4SMAFJ220A(CA) SMAF Characteristics at Ta = 25°C Table 1 Reverse Stand-off Voltage Type Breakdown Voltage V BR @ I T Max. Clamp Peak Pulse Voltage Current I R @ V RWM Package SMAF Device Marking Ccode V C @ I PP I PP μA V A 800 1600 9.6 41.6 5.0V 10 800 1600 9.2 43.5 5.0A 5.0D 8.45 10 800 1600 11.4 35.1 6.0V 6.0C V RMW Min Max BI V V V P4SMAFJ5.0 P4SMAFJ5.0C 5 6.4 P4SMAFJ5.0A P4SMAFJ5.0CA 5 P4SMAFJ6.0 P4SMAFJ6.0C UNI Reverse Leakage Test Current IT UNI BI mA μA 7.55 10 6.4 7.25 6 6.67 UNI BI 5.0C P4SMAFJ6.0A P4SMAFJ6.0CA 6 6.67 7.67 10 800 1600 10.3 38.8 6.0A 6.0D P4SMAFJ6.5 P4SMAFJ6.5C 6.5 7.22 9.14 10 500 1000 12.3 32.5 6.5V 6.5C P4SMAFJ6.5A P4SMAFJ6.5CA 6.5 7.22 8.3 10 500 1000 11.2 35.7 6.5A 6.5D P4SMAFJ7.0 P4SMAFJ7.0C 7 7.78 9.86 10 200 400 13.3 30.1 7.0V 7.0C P4SMAFJ7.0A P4SMAFJ7.0CA 7 7.78 8.95 10 200 400 12 33.3 7.0A 7.0D P4SMAFJ7.5 P4SMAFJ7.5C 7.5 8.33 10.67 1 100 200 14.3 28 7.5V 7.5C P4SMAFJ7.5A P4SMAFJ7.5CA 7.5 8.33 9.58 1 100 200 12.9 31 7.5A 7.5D P4SMAFJ8.0 P4SMAFJ8.0C 8 8.89 11.3 1 50 100 15 26.5 8.0V 8.0C P4SMAFJ8.0A P4SMAFJ8.0CA 8 8.89 10.23 1 50 100 13.6 29.4 8.0A 8.0D P4SMAFJ8.5 P4SMAFJ8.5C 8.5 9.44 11.92 1 10 20 15.9 25.1 8.5V 8.5C P4SMAFJ8.5A P4SMAFJ8.5CA 8.5 9.44 10.82 1 10 20 14.4 27.7 8.5A 8.5D P4SMAFJ9.0 P4SMAFJ9.0C 9 10 12.6 1 5 5 16.9 23.6 9.0V 9.0C P4SMAFJ9.0A P4SMAFJ9.0CA 9 10 11.5 1 5 5 15.4 26 9.0A 9.0D P4SMAFJ10 P4SMAFJ10C 10 11.1 14.1 1 5 5 18.8 21.2 10V 10C P4SMAFJ10A P4SMAFJ10CA 10 11.1 12.8 1 5 5 17 23.5 10A 10D P4SMAFJ11 P4SMAFJ11C 11 12.2 15.4 1 1 1 20.1 20 11V 11C P4SMAFJ11A P4SMAFJ11CA 11 12.2 14 1 1 1 18.2 22 11A 11D P4SMAFJ12 P4SMAFJ12C 12 13.3 16.9 1 1 1 22 18.1 12V 12C P4SMAFJ12A P4SMAFJ12CA 12 13.3 15.3 1 1 1 19.9 20.1 12A 12D P4SMAFJ13 P4SMAFJ13C 13 14.4 18.2 1 1 1 23.8 16.8 13V 13C P4SMAFJ13A P4SMAFJ13CA 13 14.4 16.5 1 1 1 21.5 18.6 13A 13D P4SMAFJ14 P4SMAFJ14C 14 15.6 19.8 1 1 1 25.8 15.5 14V 14C P4SMAFJ14A P4SMAFJ14CA 14 15.6 17.9 1 1 1 23.2 17.2 14A 14D P4SMAFJ15 P4SMAFJ15C 15 16.7 21.1 1 1 1 26.9 14.8 15V 15C P4SMAFJ15A P4SMAFJ15CA 15 16.7 19.2 1 1 1 24.4 16.4 15A 15D P4SMAFJ16 P4SMAFJ16C 16 17.8 22.6 1 1 1 28.8 13.8 16V 16C P4SMAFJ16A P4SMAFJ16CA 16 17.8 20.5 1 1 1 26 15.3 16A 16D P4SMAFJ17 P4SMAFJ17C 17 18.9 23.9 1 1 1 30.5 13.1 17V 17C P4SMAFJ17A P4SMAFJ17CA 17 18.9 21.7 1 1 1 27.6 14.5 17A 17D P4SMAFJ18 P4SMAFJ18C 18 20 25.3 1 1 1 32.2 12.4 18V 18C P4SMAFJ18A P4SMAFJ18CA 18 20 23.3 1 1 1 29.2 13.7 18A 18D P4SMAFJ20 P4SMAFJ20C 20 22.2 28.1 1 1 1 35.8 11.1 20V 20C P4SMAFJ20A P4SMAFJ20CA 20 22.2 25.5 1 1 1 32.4 12.3 20A 20D P4SMAFJ22 P4SMAFJ22C 22 24.4 30.9 1 1 1 39.4 10.1 22V 22C P4SMAFJ22A P4SMAFJ22CA 22 24.4 28 1 1 1 35.5 11.2 22A 22D P4SMAFJ24 P4SMAFJ24C 24 26.7 33.8 1 1 1 43 9.3 24V 24C P4SMAFJ24A P4SMAFJ24CA 24 26.7 30.7 1 1 1 38.9 10.3 24A 24D P4SMAFJ26 P4SMAFJ26C 26 28.9 36.6 1 1 1 46.6 8.6 26V 26C P4SMAFJ26A P4SMAFJ26CA 26 28.9 33.2 1 1 1 42.1 9.5 26A 26D P4SMAFJ28 P4SMAFJ28C 28 31.1 39.4 1 1 1 50 8 28V 28C P4SMAFJ28A P4SMAFJ28CA 28 31.1 35.8 1 1 1 45.4 8.8 28A 28D P4SMAFJ30 P4SMAFJ30C 30 33.3 42.2 1 1 1 53.5 7.5 30V 30C P4SMAFJ30A P4SMAFJ30CA 30 33.3 38.3 1 1 1 48.4 8.3 30A 30D P4SMAFJ33 P4SMAFJ33C 33 36.7 46.5 1 1 1 59 6.8 33V 33C P4SMAFJ33A P4SMAFJ33CA 33 36.7 42.2 1 1 1 53.3 7.5 33A 33D P4SMAFJ36 P4SMAFJ36C 36 40 50.7 1 1 1 64.3 6.2 36V 36C P4SMAFJ36A P4SMAFJ36CA 36 40 46 1 1 1 58.1 6.9 36A 36D P4SMAFJ40 P4SMAFJ40C 40 44.4 56.3 1 1 1 71.4 5.6 40V 40C P4SMAFJ40A P4SMAFJ40CA 40 44.4 51.1 1 1 1 64.5 6.2 40A 40D P4SMAFJ43 P4SMAFJ43C 43 47.8 60.5 1 1 1 76.7 5.2 43V 43C P4SMAFJ43A P4SMAFJ43CA 43 47.8 54.9 1 1 1 69.4 5.7 43A 43D P4SMAFJ45 P4SMAFJ45C 45 50 63.3 1 1 1 80.3 5 45V 45C www.yfwdiode.com 2/5 G uangDong YFW Electronics Co, Ltd. P4SMAFJ5.0A(CA) THRU P4SMAFJ220A(CA) SMAF Characteristics at Ta = 25°C Table 1 Reverse Stand-off Voltage Type Breakdown Voltage V BR @ I T V RMW Min Max BI V V V P4SMAFJ45CA 45 50 P4SMAFJ48 P4SMAFJ48C 48 P4SMAFJ48A P4SMAFJ48CA 48 UNI P4SMAFJ45A Reverse Leakage Test Current Package Max. Clamp Peak Pulse Voltage Current I R @ V RWM SMAF Device Marking Ccode V C @ I PP I PP μA V A UNI BI 5 5 72.7 5.5 45A 45D 1 5 5 85.5 4.7 48V 48C 1 5 5 77.4 5.2 48A 48D IT UNI BI mA μA 57.5 1 53.3 67.5 53.3 61.3 P4SMAFJ51 P4SMAFJ51C 51 56.7 71.8 1 5 5 91.1 4.4 51V 51C P4SMAFJ51A P4SMAFJ51CA 51 56.7 65.2 1 5 5 82.4 4.9 51A 51D P4SMAFJ54 P4SMAFJ54C 54 60 76 1 5 5 96.3 4.2 54V 54C P4SMAFJ54A P4SMAFJ54CA 54 60 69 1 5 5 87.1 4.6 54A 54D P4SMAFJ58 P4SMAFJ58C 58 64.4 81.6 1 5 5 103 3.9 58V 58C P4SMAFJ58A P4SMAFJ58CA 58 64.4 74.1 1 5 5 93.6 4.3 58A 58D P4SMAFJ60 P4SMAFJ60C 60 66.7 84.5 1 5 5 107 3.7 60V 60C P4SMAFJ60A P4SMAFJ60CA 60 66.7 76.7 1 5 5 96.8 4.1 60A 60D P4SMAFJ64 P4SMAFJ64C 64 71.1 90.1 1 5 5 114 3.5 64V 64C P4SMAFJ64A P4SMAFJ64CA 64 71.1 81.8 1 5 5 103 3.9 64A 64D P4SMAFJ70 P4SMAFJ70C 70 77.8 98.6 1 5 5 125 3.2 70V 70C P4SMAFJ70A P4SMAFJ70CA 70 77.8 89.5 1 5 5 113 3.5 70A 70D P4SMAFJ75 P4SMAFJ75C 75 83.3 105.7 1 5 5 134 3 75V 75C P4SMAFJ75A P4SMAFJ75CA 75 83.3 95.8 1 5 5 121 3.3 75A 75D 5 P4SMAFJ78 P4SMAFJ78C 78 86.7 109.8 1 5 139 2.9 78V 78C P4SMAFJ78A P4SMAFJ78CA 78 86.7 99.7 1 5 5 126 3.2 78A 78D P4SMAFJ85 P4SMAFJ85C 85 94.4 119.2 1 5 5 151 2.6 85V 85C P4SMAFJ85A P4SMAFJ85CA 85 94.4 108.2 1 5 5 137 2.9 85A 85D P4SMAFJ90 P4SMAFJ90C 90 100 126.5 1 5 5 160 2.5 90V 90C P4SMAFJ90A P4SMAFJ90CA 90 100 115.5 1 5 5 146 2.7 90A 90D P4SMAFJ100 P4SMAFJ100C P4SMAFJ100A P4SMAFJ100CA P4SMAFJ110 P4SMAFJ110C P4SMAFJ110A P4SMAFJ110CA P4SMAFJ120 P4SMAFJ120C P4SMAFJ120A P4SMAFJ120CA P4SMAFJ130 P4SMAFJ130C P4SMAFJ130A P4SMAFJ130CA P4SMAFJ150 P4SMAFJ150C P4SMAFJ150A P4SMAFJ150CA P4SMAFJ160 P4SMAFJ160C P4SMAFJ160A P4SMAFJ160CA P4SMAFJ170 P4SMAFJ170C P4SMAFJ170A P4SMAFJ170CA P4SMAFJ180 P4SMAFJ180C P4SMAFJ180A P4SMAFJ180CA P4SMAFJ190 P4SMAFJ190C P4SMAFJ190A P4SMAFJ190CA P4SMAFJ200 P4SMAFJ200C P4SMAFJ200A P4SMAFJ200CA P4SMAFJ210 P4SMAFJ210C P4SMAFJ210A P4SMAFJ210CA P4SMAFJ220 P4SMAFJ220C P4SMAFJ220A P4SMAFJ220CA www.yfwdiode.com 100 111 141 1 5 5 179 2.2 100V 100C 100 111 128 1 5 5 162 2.5 100A 100D 110 122 154.5 1 5 5 196 2 110V 110C 110 122 140.5 1 5 5 177 2.3 110A 110D 120 133 169 1 5 5 214 1.9 120V 120C 120 133 153 1 5 5 193 2 120A 120D 130 144 182.5 1 5 5 231 1.7 130V 130C 130 144 165.5 1 5 5 209 1.9 130A 130D 150 167 211.5 1 5 5 268 1.5 150V 150C 150 167 192.5 1 5 5 243 1.6 150A 150D 160 178 226 1 5 5 287 1.4 160V 160C 160 178 205 1 5 5 259 1.5 160A 160D 170 189 239.5 1 5 5 304 1.3 170V 170C 170 189 217.5 1 5 5 275 1.4 170A 170D 180 198 253.8 1 5 5 322 1.2 180V 180C 180 198 230.4 1 5 5 292 1.3 180A 180D 190 209 267.9 1 5 5 340 1.2 190V 190C 190 209 243.2 1 5 5 308 1.3 190A 190D 200 220 282 1 5 5 358 1.1 200V 200C 200 220 256 1 5 5 324 1.2 200A 200D 210 231 296.1 1 5 5 376 1.1 210V 210C 210 231 268.8 1 5 5 340 1.2 210A 210D 220 242 310.2 1 5 5 394 1 220V 220C 220 242 281.6 1 5 5 356 1.1 220A 220D 3/5 G uangDong YFW Electronics Co, Ltd. P4SMAFJ5.0A(CA) THRU P4SMAFJ220A(CA) SMAF Fig.2 Forward Current Derating Curve PEAK PULSE POWER(P PP)OR CURRENT(I PP) DERATINGIN PERCENTAGE% P PPM,PEAK PULSE FORWARD ,kW Fig.1 Peak Pulse Power Rating Curve 100 Non-Repetive Pulse.Wavefom Shown in Figure.3 T A=25°C 10 1.0 Mounted on 5.0mm Copper Land Areas 0.1 0.1 10 1 100 1000 10000 100 80 60 40 20 0 25 I ppm ,Peak Pulse Current (%) I FSM,PEAK FORWARD SURGE CURRENT, AMPERES T A =25°C Peak Value 100 Pulse Width (td) is Defined as the Point where the Peak. Current Decayst to 50% of Ipp I ppm 80 Half Value-I pp /2 60 10/1000usec Waveform as Defined bye R.E.A. 40 20 0 0 1.0 2.0 3.0 4.0 T,TIME,ms www.yfwdiode.com 100 125 150 175 Fig.4 Maximum Non-Repetitive Peak Forward Surge Current Fig.3 Pulse Waveform t f =10usec 75 T A,AMBIENT TEMPERATURE,°C t d,PULSE WIDTH ,us 120 50 60 50 40 30 20 10 T J=T Jmax 8.3ms Single Half Sinepwave JEDEC Method 0 1 10 100 Number of Cycles at 60Hz 4/5 G uangDong YFW Electronics Co, Ltd. P4SMAFJ5.0A(CA) THRU P4SMAFJ220A(CA) SMAF SMAF Package Outline Plastic surface mounted package; 2 leads ∠ALL ROUND C A ∠ALL ROUND HE g g pad e E A pad D E A V M Top View A C D E e g HE max 1.1 0.20 3.7 2.7 1.6 1.2 4.9 min 0.9 0.12 3.3 2.4 1.3 0.8 4.4 max 43 7.9 146 106 63 47 193 min 35 4.7 130 94 51 31 173 UNIT mm mil Bottom View ∠ 7° The recommended mounting pad size 1.6 (63) 2.2 (86) 1.8 (71) 1.6 (63) mm Unit : (mil) Summary of Packing Options Package SMAF www.yfwdiode.com Packing Description Packing Quantity Industry Standard Tape/Reel,13”reel 10000 EIA-481-1 Tape/Reel,7”reel 3000 EIA-481-1 5/5 G uangDong YFW Electronics Co, Ltd.
SMAFJ220A 价格&库存
很抱歉,暂时无法提供与“SMAFJ220A”相匹配的价格&库存,您可以联系我们找货
SMAFJ220A
