SMAJxx(C)A Series
Surface Mount Transient Voltage Suppressor Rectifiers
Reverse Voltage 5.0 ~ 550 V
400 Watt Peak Pulse Power
DO214AC/(SMA)
Features
● Glass passivated chip
● 400 W peak pulse power capability with a 10/1000
us waveform, repetitive rate (duty cycle):0.01 %
● Excellent clamping capability
● Low reverse leakage
● Very fast response time
● Lead and body according with RoHS standard
Mechanical Data
● Case
Case: DO214AC/(SMA)
O
C/(S ) Molded
o ded plastic
p ast c
● Lead: Solderable per MIL-STD-750, method 2026
● Epoxy: UL 94V-0 rate flame retardant
● Polarity: Color band denotes cathode end except Bipolar
Unit: inch (mm) ● Mounting position: Any
Maximum Ratings & Characteristics Ratings at 25℃ ambient temperature unless otherwise specified.
specified
Symbols
Value
Unit
Peak power dissipation with a 10/1000 us waveform(1)
PPP
400
W
Peak pulse current wih a 10/1000 us waveform(1)
IPP
See Next Table
A
Power dissipation on infinite heatsink at TL = 75 °C
C
PD
30
3.0
W
IFSM
40
A
VF
3.5/6.5
V
TJ,TSTG
-55 to +150
Parameter
Peak forward surge current, 8.3 ms single half sinewave
unidirectional only(2)
Maximum instantaneous forward voltage at 25 A for
unidirectional only(3)
Operating junction and storage temperature range
Note:
1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1;
2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum;
3)VF
很抱歉,暂时无法提供与“SMAJ20A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.24333
- 200+0.19084
- 600+0.16168
- 2000+0.14418
- 10000+0.12906
- 20000+0.12086
