SMAJ350A
SMAJ350A
    ZHIDE(志得)
    SMA(DO-214AC)
    单向TVS 350V截止 峰值浪涌电流:0.7A
SMAJ350A 数据手册
SMAJxx(C)A Series Surface Mount Transient Voltage Suppressor Rectifiers Reverse Voltage 5.0 ~ 550 V 400 Watt Peak Pulse Power DO214AC/(SMA) Features ● Glass passivated chip ● 400 W peak pulse power capability with a 10/1000 us waveform, repetitive rate (duty cycle):0.01 % ● Excellent clamping capability ● Low reverse leakage ● Very fast response time ● Lead and body according with RoHS standard Mechanical Data ● Case Case: DO214AC/(SMA) O C/(S ) Molded o ded plastic p ast c ● Lead: Solderable per MIL-STD-750, method 2026 ● Epoxy: UL 94V-0 rate flame retardant ● Polarity: Color band denotes cathode end except Bipolar Unit: inch (mm) ● Mounting position: Any Maximum Ratings & Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. specified Symbols Value Unit Peak power dissipation with a 10/1000 us waveform(1) PPP 400 W Peak pulse current wih a 10/1000 us waveform(1) IPP See Next Table A Power dissipation on infinite heatsink at TL = 75 °C C PD 30 3.0 W IFSM 40 A VF 3.5/6.5 V TJ,TSTG -55 to +150 ℃ Parameter Peak forward surge current, 8.3 ms single half sinewave unidirectional only(2) Maximum instantaneous forward voltage at 25 A for unidirectional only(3) Operating junction and storage temperature range Note: 1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1; 2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum; 3)VF
SMAJ350A
物料型号:SMAJxx(C)A Series
器件简介:SMAJxx(C)A系列是表面安装瞬态电压抑制二极管,具有400瓦峰值脉冲功率能力,10/1000微秒波形,重复率(占空比)为0.01%。
引脚分配:文档中没有明确提供引脚分配信息,但提到了极性:色带表示阴极端,除了双极性二极管。
参数特性: - 峰值功率耗散:400W - 峰值脉冲电流:见下表 - 在无限大散热器上,TL=75°C时的功率耗散:3.0W - 单向峰值正向浪涌电流:40A - 单向最大瞬态正向电压:3.5V/6.5V - 工作结和存储温度范围:-55至+150°C
功能详解:文档中提到了器件的特点,包括玻璃钝化芯片、优异的钳位能力、低反向漏电流、非常快的响应时间以及符合RoHS标准的引线和本体。
应用信息:文档中没有明确提供应用信息,但根据器件的特性,可以推断它们可能用于电路保护,如抑制电路中的瞬态电压。
封装信息:封装类型为DO214AC/(SMA),是一种模塑塑料封装。
SMAJ350A 价格&库存
很抱歉,暂时无法提供与“SMAJ350A”相匹配的价格&库存,您可以联系我们找货
