SS24
SS24
    JINGYANG(晶扬电子)
    SMA(DO-214AC)
SS24 数据手册
TITAN MICRO SS24AG 2A Surface Mount Trench Schottky Barrier Rectifiers ■ Features ■ Outline • Low forward voltage drop. • Excellent high temperature stability. • Fast switching capability. • Suffix "G" indicates Halogen-free part, ex.SS24G. • Lead-free parts meet environmental standards of MIL-STD-19500 /228 SMA(DO-214AC) 0.067 (1.70) 0.047 (1.20) Marking code 0.187 (4.75) 0.157 (4.00) 0.114 (2.90) 0.083 (2.10) 0.012 (0.30) TYP. 0.098 (2.50) 0.067 (1.70) ■ Mechanical data • Epoxy:UL94-V0 rated flame retardant • Case : Molded plastic, DO-214AC / SMA • Terminals : Solder plated, solderable per MIL-STD-750, Method 2026 • Polarity : Indicated by cathode band • Weight : 0.002 ounce, 0.055 gram 0.008 (0.20) 0.003 (0.08) 0.061 (1.55) 0.030 (0.75) 0.224 (5.70) 0.185 (4.70) Dimensions in inches and (millimeters) ■ Maximum ratings and electrical characteristics Rating at 25 O C ambient temperature unless otherwise specified. Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Conditions Parameter Symbol Forward rectified current See Fig.1 Forward surge current 8.3ms single half sine-wave superimposed on rate load (JEDEC method) V R = V R R M T A = 25 O C Reverse current V R = V R R M T A = 125 C Thermal resistance SS24 REV: V4 MAX. UNIT IO 2.0 A IFSM 50 A f=1MHz and applied 4V DC reverse voltage CJ Junction to ambient RθJA TSTG Storage temperature Symbol TYP. 0.5 IR O Diode junction capacitance MIN. 20 mA 120 pF O 88 -55 +150 C/W O C Marking code Max. repetitive peak reverse voltage V R R M (V) Max. RMS voltage V R M S (V) Max. DC blocking voltage V R (V) Max. forward voltage @2A, T A = 25 O C V F (V) Operating temperature T J ( O C) SS24 40 28 40 0.50 -55 ~ +150 1 of 3  www.jy-electronics.com.cn TITAN MICRO SS24AG 2A Surface Mount Trench Schottky Barrier Rectifiers ■ Rating and characteristic curves FIG.2-TYPICAL FORWARD CHARACTERISTICS AVERAGE FORWARD CURRENT,(A) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE 3.0 2.5 2.0 1.5 1.0 0.5 0 0 20 40 60 80 100 120 140 160 180 200 INSTANTANEOUS FORWARD CURRENT,(A) 10 T A = 150 O C 1.0 T A = 125 O C T A = 100 O C 0.1 T A = 85 O C T A = 50 O C T A = 25 O C AMBIENT TEMPERATURE,(OC) 0.01 0 0.1 0.2 0.3 0.4 0.5 0.6 FORWARD VOLTAGE,(V) FIG.3 - TYPICAL REVERSE CHARACTERISTICS 100 TA = 150OC 600 TA = 125OC 500 10 Total Capacitance,C T (pF) Instantaneous Reverse Current,I R (mA) Fig. 4 - Total Capacitance VS. Reverse Voltage TA = 100OC 1.0 TA = 85OC .1 TA = 50OC f = 1MHz 400 300 200 100 0 TA = 25OC 1 .01 0 10 20 30 10 100 Reverse Voltage,V R (V) 40 Reverse Voltage,V R (V) REV: V4 2 of 3  www.jy-electronics.com.cn TITAN MICRO SS24AG 2A Surface Mount Trench Schottky Barrier Rectifiers ■ Ordering Information ■ SMA foot print C A Part Number Symbol Quantity Per Reel Reel Size Package SS24AG SS24 3 ,000 13 Inch SMA B A B C 0.068 (1.70) 0.104 (2.60) 0.060 (1.50) Dimensions in inches and (millimeters) ■ TITAN reserves the right to make changes to this document and its products and specifications at any time without notice. ■ Customers should obtain and confirm the latest product information and specifications before final design, purchase or use. ■ TITAN makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does TITAN assume any liability for application assistance or customer product design. ■ TITAN does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. ■ No license is granted by implication or otherwise under any intellectual property rights of TITAN . ■ TITAN products are not authorized for use as critical components in life support devices or systems without express written approval of TITAN . REV: V4 3 of 3  www.jy-electronics.com.cn
很抱歉,暂时无法提供与“SS24”相匹配的价格&库存,您可以联系我们找货
