SMAJ13CA
SMAJ13CA
    JKSEMI(金开盛)
    SMA(DO-214AC)
    TVS 13V截止 18.6A峰值脉冲
SMAJ13CA 数据手册
SMAJ Series 400W Transient Voltage Suppressor DESCRIPTION: TVS diodes can be used in a wide range of applications which like consumer electronic products, automotive industries, munitions, telecommunications, aerospace industries, and intelligent control systems. SMA FEATURES:  Glass passivated or planar junction.  Excellent clamping capability.  Repetition rate (duty cycle): 0.01%.  Typical IR less than 1μA above 10V.  Low profile package and low inductance.  400W Peak Pulse power capability at 10×1000μs waveform.  Fast response time: typically less than 1.0ps from 0V to VBR min. Symbol  High temperature soldering: 260℃/10s at terminals.  Plastic package has Underwriters Laboratory Flammability 94V-0.  For surface mounted applications in order to optimize board space. ABSOLUTE MAXIMUM RATINGS (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Storage temperature range Operating junction temperature range Steady state power dissipation at TL=75℃ Peak pulse power dissipation on 10/1000μs waveform Maximum Instantaneous Forward Voltage at 30A for Unidirectional Symbol Value Unit Tstg -55 to +150 ℃ Tj -55 to +150 ℃ PM(AV) 3.3 W PPP 400 W VF 5.0 V MARKING HE 1409 http:// www.jksemi.com HE : Device MarkingCode 1409: In ninth week,2014 2021-10-21 版次: c SMAJ Series 400W Transient Voltage Suppressor ELECTRICAL CHARACTERISTICS (TA=25℃) Part Number Marking VR IR@ VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar Uni Bi V μA min(V) max(V) mA max(V) A SMAJ5.0A SMAJ5.0CA HE TE 5.0 800 6.40 7.00 10 9.2 43.5 SMAJ6.0A SMAJ6.0CA HG TG 6.0 800 6.67 7.37 10 10.3 38.8 SMAJ6.5A SMAJ6.5CA HK TK 6.5 500 7.22 7.98 10 11.2 35.7 SMAJ7.0A SMAJ7.0CA HM TM 7.0 200 7.78 8.60 10 12.0 33.3 SMAJ7.5A SMAJ7.5CA HP TP 7.5 100 8.33 9.21 1 12.9 31.0 SMAJ8.0A SMAJ8.0CA HR TR 8.0 50 8.89 9.83 1 13.6 29.4 SMAJ8.5A SMAJ8.5CA HT TT 8.5 10 9.44 10.40 1 14.4 27.8 SMAJ9.0A SMAJ9.0CA HV TV 9.0 5 10.00 11.10 1 15.4 26.0 SMAJ10A SMAJ10CA HX TX 10.0 1 11.10 12.30 1 17.0 23.5 SMAJ11A SMAJ11CA HZ TZ 11.0 1 12.20 13.50 1 18.2 22.0 SMAJ12A SMAJ12CA IE UE 12.0 1 13.30 14.70 1 19.9 20.1 SMAJ13A SMAJ13CA IG UG 13.0 1 14.40 15.90 1 21.5 18.6 SMAJ14A SMAJ14CA IK UK 14.0 1 15.60 17.20 1 23.2 17.3 SMAJ15A SMAJ15CA IM UM 15.0 1 16.70 18.50 1 24.4 16.4 SMAJ16A SMAJ16CA IP UP 16.0 1 17.80 19.70 1 26.0 15.4 SMAJ17A SMAJ17CA IR UR 17.0 1 18.90 20.90 1 27.6 14.5 SMAJ18A SMAJ18CA IT UT 18.0 1 20.00 22.10 1 29.2 13.7 SMAJ20A SMAJ20CA IV UV 20.0 1 22.20 24.50 1 32.4 12.4 SMAJ22A SMAJ22CA IX UX 22.0 1 24.40 26.90 1 35.5 11.3 SMAJ24A SMAJ24CA IZ UZ 24.0 1 26.70 29.50 1 38.9 10.3 SMAJ26A SMAJ26CA JE VE 26.0 1 28.90 31.90 1 42.1 9.5 SMAJ28A SMAJ28CA JG VG 28.0 1 31.10 34.40 1 45.4 8.8 SMAJ30A SMAJ30CA JK VK 30.0 1 33.30 36.80 1 48.4 8.3 SMAJ33A SMAJ33CA JM VM 33.0 1 36.70 40.60 1 53.3 7.5 SMAJ36A SMAJ36CA JP VP 36.0 1 40.00 44.20 1 58.1 6.9 SMAJ40A SMAJ40CA JR VR 40.0 1 44.40 49.10 1 64.5 6.2 SMAJ43A SMAJ43CA JT VT 43.0 1 47.80 52.80 1 69.4 5.8 SMAJ45A SMAJ45CA JV VV 45.0 1 50.00 55.30 1 72.7 5.5 SMAJ48A SMAJ48CA JX VX 48.0 1 53.30 58.90 1 77.4 5.2 SMAJ51A SMAJ51CA JZ VZ 51.0 1 56.70 62.70 1 82.4 4.9 http:// www.jksemi.com 2021-10-21 版次: c SMAJ Series 400W Transient Voltage Suppressor ELECTRICAL CHARACTERISTICS (TA=25℃, continued) Part Number Marking VR IR@ VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar Uni Bi V μA min(V) max(V) mA max(V) A SMAJ54A SMAJ54CA RE WE 54.0 1 60.00 66.30 1 87.1 4.6 SMAJ58A SMAJ58CA RG WG 58.0 1 64.40 71.20 1 93.6 4.3 SMAJ60A SMAJ60CA RK WK 60.0 1 66.70 73.70 1 96.8 4.1 SMAJ64A SMAJ64CA RM WM 64.0 1 71.10 78.60 1 103.0 3.9 SMAJ70A SMAJ70CA RP WP 70.0 1 77.80 86.00 1 113.0 3.6 SMAJ75A SMAJ75CA RR WR 75.0 1 83.30 92.10 1 121.0 3.3 SMAJ78A SMAJ78CA RT WT 78.0 1 86.70 95.80 1 126.0 3.2 SMAJ85A SMAJ85CA RV WV 85.0 1 94.40 104.0 1 137.0 2.9 SMAJ90A SMAJ90CA RX WX 90.0 1 100.0 111.0 1 146.0 2.8 SMAJ100A SMAJ100CA RZ WZ 100.0 1 100.0 111.0 1 162.0 2.5 SMAJ110A SMAJ110CA SE XE 110.0 1 111.0 123.0 1 177.0 2.3 SMAJ120A SMAJ120CA SG XG 120.0 1 122.0 135.0 1 193.0 2.1 SMAJ130A SMAJ130CA SK XK 130.0 1 133.0 147.0 1 209.0 1.9 SMAJ150A SMAJ150CA SM XM 150.0 1 144.0 159.0 1 243.0 1.7 SMAJ160A SMAJ160CA SP XP 160.0 1 167.0 185.0 1 259.0 1.6 SMAJ170A SMAJ170CA SR XR 170.0 1 178.0 197.0 1 275.0 1.5 SMAJ180A SMAJ180CA ST XT 180.0 1 189.0 209.0 1 292.0 1.4 SMAJ200A SMAJ200CA SX XX 200.0 1 201.0 222.0 1 324.0 1.3 SMAJ220A SMAJ220CA ZE YE 220.0 1 211.0 234.0 1 356.0 1.1 SMAJ250A SMAJ250CA ZG YG 250.0 1 224.0 247.0 1 405.0 1.0 SMAJ300A SMAJ300CA ZK YK 300.0 1 233.0 258.0 1 486.0 0.8 SMAJ350A SMAJ350CA ZM YM 350.0 1 391.0 432.0 1 567.0 0.7 SMAJ400A SMAJ400CA ZP YP 400.0 1 447.0 494.0 1 648.0 0.6 SMAJ440A SMAJ440CA ZR YR 440.0 1 492.0 543.0 1 713.0 0.6 ① Surge waveform: 10/1000μs VR :Stand-off Voltage -- Maximum voltage that can be applied VBR: Breakdown Voltage VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp IR: Reverse Leakage Current http:// www.jksemi.com 2021-10-21 版次: c SMAJ Series 400W Transient Voltage Suppressor ORDERING INFORMATION SMAJ xx C A 400W SMA Series 5% VBR Voltage tolerance VR Voltage C: Bi-directional RATINGS AND V‐I CHARACTERISTICS CURVES (TA=25ºC, unless otherwise noted) FIG.1:V- I curve characteristics (Uni-directional) FIG.2:V- I curve characteristics (Bi-directional) IPP V VC VBR VR IT IR VC VBR VR VF VR V BR VC FIG.4: Pulse derating curve FIG.3: Pulse waveform PPP derating in percentage(%) 100 tr = rise time to peak value td = decay t ime to half value tr= 10μs 100 IR IT IPP IPP IPPM(%IRSM) 150 V 80 Pea k value 60 Half val ue 40 50 20 0 0 td 1.0 http:// www.jksemi.com t(ms) 2.0 3.0 4.0 0 0 25 50 TA(℃) 75 100 2021-10-21 125 版次: c 150 175 SMAJ Series 400W Transient Voltage Suppressor SOLDERING PARAMETERS Pb-Free assembly (see FIG.5) Reflow Condition -Temperature Min (Ts(min)) -Temperature Max(Ts(max)) +200℃ TP -Time (Min to Max) (ts) 60-180 secs. TL Critical Zone TL to TP tL TS(max) Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow tp Ramp-up -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. Temperature Pre Heat FIG.5: Reflow condition +150℃ Ramp-down Preheat TS(min) 25 Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ ts time to peak temperatue (t 25℃ to peak) Time PACKAGE MECHANICAL DATA A Dimensions B C Ref. Max. Min. Max. A 4.25 4.65 0.167 0.183 B 2.50 2.90 0.098 0.114 C 1.35 1.65 0.053 0.065 D 0.76 1.52 0.030 0.060 E E 4.93 5.28 0.194 0.208 F 0.051 0.203 0.002 0.008 J K G 0.15 0.31 0.006 0.012 H 1.98 2.41 0.078 0.095 J 6.80 F H Inches Min. G L D Millimeters 2.60 K DO-214AC (SMA) http:// www.jksemi.com L 0.268 2.40 0.102 0.094 2021-10-21 版次: c SMAJ Series 400W Transient Voltage Suppressor TAPE AND REELSPECIFICATION‐SMA Cathode Ref. B W FE P0 P1 A P Dimensions Millimeters Inches A 2.79 ± 0.3 0.110 ± 0.012 B 5.33 ± 0.3 0.210 ± 0.012 d 1.5 ± 0.1 0.059 ± 0.004 D 330.0 13.0 D2 13 ± 1 0.512 ± 0.039 E 1.5 ± 0.2 0.059 ± 0.008 F 5.65 ± 0.2 0.222 ± 0.008 P 4.0 ± 0.2 0.157 ± 0.008 P0 4.0 ± 0.2 0.157 ± 0.008 P1 2.0 ± 0.2 0.079 ± 0.008 W 12.0 ± 0.2 0.472 ± 0.008 W1 16.8 ± 2.0 0.661 ± 0.079 OUTLINE REEL (PCS) PER CARTON (PCS) REEL DIAMETERS (mm) TAPING 5,000 80,000 330 Website: http://www.jksemi.com For additional information, please contact your local SalesRepresentative. ©Copyright 2021, jksemi is a registered trademark of jksemi All rights arereserved http:// www.jksemi.com 2021-10-21 版次: c
SMAJ13CA 价格&库存
很抱歉,暂时无法提供与“SMAJ13CA”相匹配的价格&库存,您可以联系我们找货
