SMAJ28AJ
SMAJ28AJ
    WEEN(瑞能)
    SMA(DO-214AC)
    单向TVS 28V截止 峰值浪涌电流:8.8A
SMAJ28AJ 数据手册
SMAJ Series 400W Transient Voltage Suppressor Rev.01 - 08 February 2021 Product data sheet 1. General description SMAJ series, 400W transient voltage suppressor (TVS) in SMA package, designed to protect electronic circuits against damage induced by lightning surges or other transient voltage events. 2. Features and benefits • • • • • • • • • • • • • Peak pulse power 400W @ 10/1000μs waveform Excellent clamping capability Low incremental surge resistance Surface mount package for easy assembly and PCB space-saving Typical IR < 1μA when VBR min > 12V Fast response time: typically < 1.0ps from 0V to VBR minimum IEC 61000-4-2 ESD 30kV (Air), 30kV (Contact) EFT protection of data lines in accordance with IEC 61000-4-4 Guaranteed high temperature for reflow soldering: 260°C/10sec Mold compound complies to UL94V-0 flammability classification Meets MSL level 1, per J-STD-020 Pb-free lead finish Halogen free and RoHS compliant 3. Applications • • • • Bi-directional Cathode Uni-directional RoHS Power supplies Industrial applications Power management circuits I/O interfaces Anode halogen-Free 4. Ordering information Type number SMAJxxxXX Package name SMA Orderable part number Packing method SMAJxxxXXJ Tape and reel Small packing Package quantity version 5000 SMAJ Package issue date 18-Oct-2020 eg. SMAJ5.0CA SMA SMAJ5.0CAJ 5000 18-Oct-2020 Tape and reel SMAJ 5. Absolute maximum ratings In accordance with the Absolute Maximum Rating System (IEC 60134). Tj = 25 °C unless otherwise specified. Symbol Parameter Conditions Values Unit Absolute maximum rating PPPM peak pulse power [1] 400 W PM(AV) steady state power dissipation on infinite heatsink at Ta = 50 °C 3.3 W IFSM peak forward surge current tp = 8.3 ms; single half sine-wave pulse; duty cycle = 4 pulses per minute maximum; unidirectional units only 60 A VF forward on-state voltage IF = 35 A; unidirectional units only 3.5 V Tstg storage temperature range -65 to 150 °C Tj operating temperature range -65 to 150 °C [1] In accordance with IEC 61643-321 (10/1000 μs current waveform). SMAJ series WeEn Semiconductors 400W Transient Voltage Suppressor 6. Characteristics Tj = 25 °C unless otherwise specified. PN (Uni) PN (Bi) SMAJ5.0A SMAJ5.0CA 5 6.45 6.98 10 9.2 43.5 400 A005AJ A005CJ SMAJ6.0A SMAJ6.0CA 6 6.8 7.32 10 10.3 38.8 400 A006AJ A006CJ SMAJ6.5A SMAJ6.5CA 6.5 7.27 7.92 10 11.2 35.7 250 A06FAJ A06FCJ SMAJ7.0A SMAJ7.0CA 7 7.82 8.57 10 12 33.3 100 A007AJ A007CJ SMAJ8.0A SMAJ8.0CA 8 8.95 9.76 1 13.6 29.4 50 A008AJ A008CJ SMAJ9.0A SMAJ9.0CA 9 10.1 11 1 15.4 26 10 A009AJ A009CJ SMAJ10A SMAJ10CA 10 11.21 12.19 1 17 23.5 5 A010AJ A010CJ SMAJ11A SMAJ11CA 11 12.32 13.38 1 18.2 22 1 A011AJ SMAJ12A SMAJ12CA 12 13.43 14.57 1 19.9 20.1 1 A012AJ A012CJ SMAJ13A SMAJ13CA 13 14.54 15.76 1 21.5 18.6 1 A013AJ A013CJ SMAJ14A SMAJ14CA 14 15.75 17.04 1 23.2 17.2 1 A014AJ A014CJ SMAJ15A SMAJ15CA 15 16.86 18.34 1 24.4 16.4 1 A015AJ A015CJ SMAJ16A SMAJ16CA 16 17.97 19.52 1 26 15.4 1 A016AJ A016CJ SMAJ17A SMAJ17CA 17 19.08 20.72 1 27.6 14.5 1 A017AJ A017CJ SMAJ18A SMAJ18CA 18 20.19 21.9 1 29.2 13.7 1 A018AJ A018CJ SMAJ20A SMAJ20CA 20 22.41 24.28 1 32.4 12.3 1 A020AJ A020CJ SMAJ22A SMAJ22CA 22 24.63 26.66 1 35.5 11.3 1 A022AJ A022CJ SMAJ24A SMAJ24CA 24 26.95 29.23 1 38.9 10.3 1 A024AJ A024CJ SMAJ26A SMAJ26CA 26 29.12 31.67 1 42.1 9.5 1 A026AJ A026CJ SMAJ28A SMAJ28CA 28 31.33 34.16 1 45.4 8.8 1 A028AJ A028CJ SMAJ30A SMAJ30CA 30 33.55 36.54 1 48.4 8.3 1 A030AJ A030CJ SMAJ33A SMAJ33CA 33 36.98 40.3 1 53.3 7.5 1 A033AJ A033CJ SMAJ36A SMAJ36CA 36 40.3 43.9 1 58.1 6.9 1 A036AJ A036CJ SMAJ40A SMAJ40CA 40 44.7 48.8 1 64.5 6.2 1 A040AJ A040CJ SMAJ43A SMAJ43CA 43 48.2 52.4 1 69.4 5.8 1 A043AJ A043CJ SMAJ45A SMAJ45CA 45 50.4 54.9 1 72.7 5.5 1 A045AJ A045CJ SMAJ48A SMAJ48CA 48 53.7 58.5 1 77.4 5.2 1 A048AJ A048CJ SMAJ51A SMAJ51CA 51 57.1 62.3 1 82.4 4.9 1 A051AJ A051CJ SMAJ54A SMAJ54CA 54 60.5 65.8 1 87.1 4.6 1 A054AJ A054CJ SMAJ58A SMAJ58CA 58 64.9 70.7 1 93.6 4.3 1 A058AJ A058CJ SMAJ60A SMAJ60CA 60 67.2 73.2 1 96.8 4.1 1 A060AJ A060CJ SMAJ64A SMAJ64CA 64 71.6 78 1 103 3.9 1 A064AJ A064CJ SMAJ70A SMAJ70CA 70 78.4 85.4 1 113 3.5 1 A070AJ A070CJ SMAJ75A SMAJ75CA 75 83.9 91.5 1 121 3.3 1 A075AJ A075CJ SMAJ78A SMAJ78CA 78 87.4 95.1 1 126 3.2 1 A078AJ A078CJ SMAJ85A SMAJ85CA 85 95.1 103.3 1 137 2.9 1 A085AJ A085CJ SMAJ series Product data sheet Reverse Breakdown Test Max. Max. Peak Maximum Stand off Voltage VBR @ current Clamping Pulse Reverse Voltage IT IT Voltage VC Current Leakage VR (V) (mA) @ Ipp Ipp IR @ VR (V) (V) (A) (μA) Min Max All information provided in this document is subject to legal disclaimers. 08 February 2021 © Marking Uni Bi A011CJ WeEn Semiconductors Co., Ltd. 2021. All rights reserved 2/7 SMAJ series WeEn Semiconductors 400W Transient Voltage Suppressor Uni-directional Bi-directional Ipp Vc VBR VR IR VF IT IT IR Vc VBR VR V IR IT V VR VBR Vc Ipp Ipp Fig. 1. I-V curve characteristics; Uni-directional Fig. 2. I-V curve characteristics; Bi-directional IPP (%) tr = 10 μs 100 Peak Value IPP Half Value IPP/2 50 tp 0 Fig. 3. Peak pulse power derating curve 100 1 2 3 tp (ms) Fig. 4. Pulse waveform 80 Tj = 25°C PPPM (kW) 0 10 x 1000 Waveform as defined be R.E.A Pulse width 8.3ms IFSM (A) Non-repetitive pulse waveform shown in pulse waveform graph single half sine-wave 60 10 40 1.0 20 0.1 0.1 1.0 10 100 Fig. 5. Peak pulse power rating curve SMAJ series Product data sheet 0 1000 10000 tp (μs) 1 10 number of cycles (n) 102 Fig. 6. Maximum non-repetitive surge current Uni-directional only All information provided in this document is subject to legal disclaimers. 08 February 2021 © WeEn Semiconductors Co., Ltd. 2021. All rights reserved 3/7 SMAJ series WeEn Semiconductors 400W Transient Voltage Suppressor 10000 Cj (pF) Uni-directional V=0V 1000 SMAJ xx xx Bi-directional V=0V A: Uni-directional CA: Bi-directional Reverse Standard off Voltage VR 100 Product series 10 1 10 VBR (V) 100 Fig. 7. Typical junction capacitance Fig. 8. Part numbering Product Type Marking Code XXXXXJ YWWDXX Cathode band (for uni-directional products only) Trace Code Marking Y: Year Code WW: Week Code XX: Assembly Lot Code Fig. 9. Part marking SMAJ series Product data sheet All information provided in this document is subject to legal disclaimers. 08 February 2021 © WeEn Semiconductors Co., Ltd. 2021. All rights reserved 4/7 SMAJ series WeEn Semiconductors 400W Transient Voltage Suppressor 7. Package outline SMA SMAJ series Product data sheet All information provided in this document is subject to legal disclaimers. 08 February 2021 © WeEn Semiconductors Co., Ltd. 2021. All rights reserved 5/7 SMAJ series WeEn Semiconductors 400W Transient Voltage Suppressor Right to make changes — WeEn Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 8. Legal information Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Product [short] data sheet Production This document contains the product specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. WeEn Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. [1 ] [2] [3] Definition Suitability for use — WeEn Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an WeEn Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. WeEn Semiconductors and its suppliers accept no liability for inclusion and/or use of WeEn Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ween-semi.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. WeEn Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local WeEn Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between WeEn Semiconductors and its customer, unless WeEn Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the WeEn Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, WeEn Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. WeEn Semiconductors takes no responsibility for the content in this document if provided by an information source outside of WeEn Semiconductors. In no event shall WeEn Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, WeEn Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of WeEn Semiconductors. SMAJ series Product data sheet Customers are responsible for the design and operation of their applications and products using WeEn Semiconductors products, and WeEn Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the WeEn Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. WeEn Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using WeEn Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). WeEn does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific WeEn Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. WeEn Semiconductors accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without WeEn Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond WeEn Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies WeEn Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond WeEn Semiconductors’ standard warranty and WeEn Semiconductors’ product specifications. All information provided in this document is subject to legal disclaimers. 08 February 2021 © WeEn Semiconductors Co., Ltd. 2021. All rights reserved 6/7 SMAJ series WeEn Semiconductors 400W Transient Voltage Suppressor Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. SMAJ series Product data sheet All information provided in this document is subject to legal disclaimers. 08 February 2021 © WeEn Semiconductors Co., Ltd. 2021. All rights reserved 7/7
SMAJ28AJ 价格&库存
很抱歉,暂时无法提供与“SMAJ28AJ”相匹配的价格&库存,您可以联系我们找货
