P6SMAJ22CA
P6SMAJ22CA
    LIOWN(里阳)
    SMA(DO-214AC)
    双向TVS 22V截止 16.9A峰值脉冲
P6SMAJ22CA 数据手册
TVS Diodes Datasheet P6SMAJ Series Surface Mount – 600W Description The P6SMAJ series is designed specifically to protect sensitive electronic equipment from voltage transients induced by lightning and other transient voltage events. For surface mounted applications in order to optimize SMA board space. Features Additional Information Maximum Ratings and Characteristics (TA=25℃) Rating Symbol Value Peak pulse power dissipation at 10/1000μs waveform(Note1, Note2, Fig.1) PPPM 600W Peak pulse current of at 10/1000 μs waveform (Note 1, Fig.3) IPPM See Table(A) Steady state power dissipation at TA=50℃ (Fig.5) PM(AV) 5.0W Maximum Instantaneous Forward Voltage at 25A for Unidirectional Only VF 3.5V Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Ranges Typical thermal resistance junction to lead Typical thermal resistance junction to ambient  Halogen free and RoHS compliant  Low profile package  Built-in strain relief design  Low inductance  Excellent clamping capability  600W peak pulse power capability at 10/1000 μ s waveform, repetition rate (duty cycle): 0.01%  Fast response time  Typical IR less than 1μA above 10V devices  Peak 260 ℃ high temperature Reflow Soldering withstanding  Meet MSL level1, per J-STD-020  IEC-61000-4-2 ESD 30kV(Air), 30kV (Contact)  Unit Weight: 0.07g Applications TVS components are ideal for the protection of I/O Interfaces, VCC bus and other vulnerable circuits used in telecom, computer, Industrial and consumer electronic IFSM 60A TJ、TSTG -55℃ to +150℃ RθJL 30℃/W RθJA 120℃/W applications. Functional Diagram Notes: 1. Non-repetitive current pulse, per Fig.3 and derating above TA=25℃ per Fig.2. 2. Each terminal is surface Mounted on the 5.0mm×5.0mm(0.03mm thick) copper pads. 3. 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minutes maximum. 1 © 2023 Liown Semiconductor Co., Ltd. Specifications are subject to change without notice. Version: V4 TVS Diodes Datasheet P6SMAJ Series Surface Mount – 600W Electrical Characteristics (TA=25℃) Part Number Device Reverse Breakdown Marking Stand-Off Voltage Code Voltage @IT Maximum Test Clamping Current Voltage @IPP Peak Reverse Pulse Leakage Current @VR Uni. Bi. Uni. Bi. VR(V) VB MIn.(V) VB Max.(V) IT(mA) VC(V) IPP(A) IR(μA) P6SMAJ5.0A P6SMAJ5.0CA KE AE 5.0 6.40 7.00 10 9.2 65.3 800 P6SMAJ6.0A P6SMAJ6.0CA KG AG 6.0 6.67 7.37 10 10.3 58.3 800 P6SMAJ6.5A P6SMAJ6.5CA KK AK 6.5 7.22 7.98 10 11.2 53.6 500 P6SMAJ7.0A P6SMAJ7.0CA KM AM 7.0 7.78 8.60 10 12.0 50.0 200 P6SMAJ7.5A P6SMAJ7.5CA KP AP 7.5 8.33 9.21 1 12.9 46.6 100 P6SMAJ8.0A P6SMAJ8.0CA KR AR 8.0 8.89 9.83 1 13.6 44.2 50 P6SMAJ8.5A P6SMAJ8.5CA KT AT 8.5 9.44 10.40 1 14.4 41.7 20 P6SMAJ9.0A P6SMAJ9.0CA KV AV 9.0 10.00 11.10 1 15.4 39.0 10 P6SMAJ10A P6SMAJ10CA KX AX 10.0 11.10 12.30 1 17.0 35.3 5 P6SMAJ11A P6SMAJ11CA KZ AZ 11.0 12.20 13.50 1 18.2 33.0 1 P6SMAJ12A P6SMAJ12CA LE BE 12.0 13.30 14.70 1 19.9 30.2 1 P6SMAJ13A P6SMAJ13CA LG BG 13.0 14.40 15.90 1 21.5 28.0 1 P6SMAJ14A P6SMAJ14CA LK BK 14.0 15.60 17.20 1 23.2 25.9 1 P6SMAJ15A P6SMAJ15CA LM BM 15.0 16.70 18.50 1 24.4 24.6 1 P6SMAJ16A P6SMAJ16CA LP BP 16.0 17.80 19.70 1 26.0 23.1 1 P6SMAJ17A P6SMAJ17CA LR BR 17.0 18.90 20.90 1 27.6 21.8 1 P6SMAJ18A P6SMAJ18CA LT BT 18.0 20.00 22.10 1 29.2 20.6 1 P6SMAJ20A P6SMAJ20CA LV BV 20.0 22.20 24.50 1 32.4 18.6 1 P6SMAJ22A P6SMAJ22CA LX BX 22.0 24.40 26.90 1 35.5 16.9 1 P6SMAJ24A P6SMAJ24CA LZ BZ 24.0 26.70 29.50 1 38.9 15.5 1 P6SMAJ26A P6SMAJ26CA ME CE 26.0 28.90 31.90 1 42.1 14.3 1 P6SMAJ28A P6SMAJ28CA MG CG 28.0 31.10 34.40 1 45.4 13.3 1 P6SMAJ30A P6SMAJ30CA MK CK 30.0 33.30 36.80 1 48.4 12.4 1 P6SMAJ33A P6SMAJ33CA MM CM 33.0 36.70 40.60 1 53.3 11.3 1 P6SMAJ36A P6SMAJ36CA MP CP 36.0 40.00 44.20 1 58.1 10.4 1 P6SMAJ40A P6SMAJ40CA MR CR 40.0 44.40 49.10 1 64.5 9.3 1 2 © 2023 Liown Semiconductor Co., Ltd. Specifications are subject to change without notice. Version: V4 TVS Diodes Datasheet P6SMAJ Series Surface Mount – 600W Part Number Device Reverse Breakdown Marking Stand-Off Voltage Code Voltage @IT Maximum Test Clamping Current Voltage @IPP Peak Reverse Pulse Leakage Current @VR Uni. Bi. Uni. Bi. VR(V) VB MIn.(V) VB Max.(V) IT(mA) VC(V) IPP(A) IR(μA) P6SMAJ43A P6SMAJ43CA MT CT 43.0 47.80 52.80 1 69.4 8.7 1 P6SMAJ45A P6SMAJ45CA MV CV 45.0 50.00 55.30 1 72.7 8.3 1 P6SMAJ48A P6SMAJ48CA MX CX 48.0 53.30 58.90 1 77.4 7.8 1 P6SMAJ51A P6SMAJ51CA MZ CZ 51.0 56.70 62.70 1 82.4 7.3 1 P6SMAJ54A P6SMAJ54CA NE DE 54.0 60.00 66.30 1 87.1 6.9 1 P6SMAJ58A P6SMAJ58CA NG DG 58.0 64.40 71.20 1 93.6 6.5 1 3 © 2023 Liown Semiconductor Co., Ltd. Specifications are subject to change without notice. Version: V4 TVS Diodes Datasheet P6SMAJ Series Surface Mount – 600W Ratings and Characteristic Curves (TA=25℃) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve Figure 3. Pulse Waveform Figure 4. Typical Junction Capacitance Figure 5. Steady State Power Dissipation Derating Curve Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional 4 © 2023 Liown Semiconductor Co., Ltd. Specifications are subject to change without notice. Version: V4 TVS Diodes Datasheet P6SMAJ Series Surface Mount – 600W Soldering Parameters Reflow Condition Pre Heat -Temperature Min (TS min) 150°C -Temperature Max (TS max) 200°C -Time (min to max) ( tS) 60 – 180 secs Average ramp-up rate (TL to TP) 3°C/second max. TS max to TL-Ramp-up Rate 3°C/second max. Time -Temperature (TL) 217°C -Time (tL) 60-150 seconds maintained above: Peak Temperature (TP) Time within 5°C of actual Peak Temperature (tP) Reflow Soldering Lead–free 260°C 20-40 seconds Ramp-down Rate 6°C/second max. Time 25°C to Peak Temperature 8 minutes max. Dimensions (SMA/DO-214AC) Symbol 5 Millimeters Inches Min. Max. Min. Max. A 1.250 1.650 0.049 0.065 B 3.990 4.600 0.157 0.181 C 2.400 2.790 0.095 0.110 D 1.900 2.290 0.075 0.090 E 0.780 1.520 0.030 0.060 F - 0.203 - 0.008 G 4.800 5.280 0.189 0.208 H 0.152 0.305 0.006 0.012 I 1.800 - 0.070 - J 2.100 - 0.082 - K - 2.300 - 0.090 © 2023 Liown Semiconductor Co., Ltd. Specifications are subject to change without notice. Version: V4 TVS Diodes Datasheet P6SMAJ Series Surface Mount – 600W Part Number Code and Marking Code Packaging Specification Tape 13 Inches Reel For Uni-Devices Quantity:5000pcs/reel 6 © 2023 Liown Semiconductor Co., Ltd. Specifications are subject to change without notice. Version: V4
P6SMAJ22CA 价格&库存
很抱歉,暂时无法提供与“P6SMAJ22CA”相匹配的价格&库存,您可以联系我们找货
