SMAJ Series
400W Surface MountTransinet Voltage Suppression
Features
SMA
Peak power disspation 400W@10 x 1000 us Pluse
Low incremental surge resistance
Excellent clamping capability
Glass passivated junction
Fast response time
Typical IR less than 1uA above 10V
Halogen free and RoHS compliant
Mechanical Data
CASE: SMAJ(DO-214AC) Molded Plastic
Polarity: By cathode band denites uni-directional decice,
none cathode band denotes bi-directional device
Mounting Position:Any
Symbol
Making Code & information
Package
Packing Description
Packing Quantity
Tape/Reel,11" reel
5000
SMAJ
XXX A
SMA
SMAJ XXX C A
5% VBR Voltage Tolerance
SMAJ
Bidirectional
XXX CA
VRWM Voltage
Series Code
Maximum Ratings & Thermal Characteristics
(Ratings at 25℃ ambient temperature unless otherwise specified.)
Parameter
Peak Pulse Power Dissipation on 10/1000 us Waveform
(Note 1, 2, FIG.1)
Power Dissipation on Infinite Heat Sink at TL=50°C
Peak Pulse Current of on 10/1000us Waveform
(Note 1, FIG.3)
Peak Forward Surge Current, 8.3ms Single Half Sine-Wave (Note 2. 3)
Operating Junction Temperature Range
Storage Temperature Range
Symbol
Value
Units
PPPM
Min 400
W
PD
3.3
W
IPPM
See Table 1
A
IFSM
40
A
TJ
-55 to 150
°C
TSTG
-55 to 150
°C
Notes:
1. Non-repetitive current pulse, per Fig.3 and derated above TA=25°C per Fig.2.
2. Mounted on 5.0x5.0mm 2 (0.03mm thick) Copper Pads to each terminal.
3. Measured on 8.3ms single half sine-wave, or equivalent square wave, for Unidirectional device only.
Rev 2: Nov 2018
派克微电子(深圳)有限公司
www.pakermicro.com
Page 1 of 3
SMAJ Series
Electrical Characteristics
( Ratings at 25℃ ambient temperature unless otherwise specified).
Type Number
Reverse
Stand-Off
Voltage
Breakdown
Voltage
Min. @IT
Breakdown
Voltage
Max. @ IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRMW
(Uni)
(Bi)
VRMW(V)
VBR MIN(V)
VBR MAX(V)
IT (mA)
VC(V)
IPP(A)
IR(uA)
SMAJ5.0A
SMAJ6.0A
SMAJ6.5A
SMAJ7.0A
SMAJ7.5A
SMAJ8.0A
SMAJ8.5A
SMAJ9.0A
SMAJ10A
SMAJ11A
SMAJ5.0CA
SMAJ6.0CA
SMAJ6.5CA
SMAJ7.0CA
SMAJ7.5CA
SMAJ8.0CA
SMAJ8.5CA
SMAJ9.0CA
SMAJ10CA
SMAJ11CA
5.0
6.0
6.5
7.0
7.5
8.0
8.5
9.0
10.0
11.0
6.40
6.67
7.22
7.78
8.33
8.89
9.44
10.0
11.10
12.20
7.00
7.37
7.98
8.60
9.21
9.83
10.40
11.10
12.30
13.50
10
10
10
10
1
1
1
1
1
1
9.2
10.3
11.2
12.0
12.9
13.6
14.4
15.4
17.0
18.2
43.5
38.8
35.7
33.3
31.0
29.4
27.8
26.0
23.5
22.0
500
500
300
200
100
50
5
1
SMAJ12A
SMAJ13A
SMAJ14A
SMAJ15A
SMAJ16A
SMAJ17A
SMAJ18A
SMAJ20A
SMAJ22A
SMAJ24A
SMAJ12CA
SMAJ13CA
SMAJ14CA
SMAJ15CA
SMAJ16CA
SMAJ17CA
SMAJ18CA
SMAJ20CA
SMAJ22CA
SMAJ24CA
12.0
13. 0
14.0
15.0
16.0
17.0
18.0
20.0
22.0
24.0
13.30
14. 40
15.60
16.70
17.80
18.90
20.00
22.20
24.40
26.70
14.70
15. 90
17.20
18.50
19.70
20.90
22.10
24.50
26.90
29.50
1
1
1
1
1
1
1
1
1
1
19.9
21. 5
23.2
24.4
26.0
27.6
29.2
32.4
35.5
38.9
20.1
18. 6
17.2
16.4
15.4
14.5
13.7
12.3
11.3
10.3
1
1
1
1
1
1
1
1
1
1
SMAJ26A
SMAJ28A
SMAJ30A
SMAJ33A
SMAJ36A
SMAJ40A
SMAJ43A
SMAJ45A
SMAJ48A
SMAJ51A
SMAJ26CA
SMAJ28CA
SMAJ30CA
SMAJ33CA
SMAJ36CA
SMAJ40CA
SMAJ43CA
SMAJ45CA
SMAJ48CA
SMAJ51CA
26.0
28.0
30.0
33.0
36.0
40.0
43.0
45.0
48.0
51.0
28.90
31.10
33.30
36.70
40.00
44.40
47.80
50.00
53.30
56.70
31.90
34.40
36.80
40.60
44.20
49.10
52.80
55.30
58,90
62.70
1
1
1
1
1
1
1
1
1
1
42.1
45.4
48.4
53.3
58.1
64.5
69.4
72.7
77.4
82.4
9.5
8.8
8.3
7.5
6.9
6.2
5.8
5.5
5.2
4.9
1
1
1
1
1
1
1
1
1
1
SMAJ54A
SMAJ58A
SMAJ60A
SMAJ64A
SMAJ70A
SMAJ75A
SMAJ78A
SMAJ85A
SMAJ90A
SMAJ100A
SMAJ54CA
SMAJ58CA
SMAJ60CA
SMAJ64CA
SMAJ70CA
SMAJ75CA
SMAJ78CA
SMAJ85CA
SMAJ90CA
SMAJ100CA
54.0
58.0
60.0
64.0
70.0
75.0
78.0
85.0
90.0
100.0
60.00
64.40
66.70
71.10
77.80
83.30
86.70
94.40
100.00
111.00
66.30
71.20
73.70
78.60
86.00
92.10
95.80
104.00
111.00
123.00
1
1
1
1
1
1
1
1
1
1
87.1
93.6
96.8
103.0
113.0
121.0
126.0
137.0
146.0
162.0
4.6
4.3
4.1
3.9
3.5
3.3
3.2
2.9
2.7
2.5
1
1
1
1
1
1
1
1
1
1
SMAJ110A
SMAJ120A
SMAJ130A
SMAJ150A
SMAJ160A
SMAJ170A
SMAJ180A
SMAJ190A
SMAJ200A
SMAJ210A
SMAJ110CA
SMAJ120CA
SMAJ130CA
SMAJ150CA
SMAJ160CA
SMAJ170CA
SMAJ180CA
SMAJ190CA
SMAJ200CA
SMAJ210CA
110.0
120.0
130.0
150.0
160.0
170.0
180.0
190 0
200.0
210.0
122.00
133.00
144.00
167.00
178.00
189.00
201.00
211 00
224.00
237.00
135.00
147.00
159.00
185.00
197.00
209.00
222.00
233 00
247.00
263.00
1
1
1
1
1
1
1
1
1
1
177.0
193.0
209.0
243.0
259.0
275.0
292.0
308.0
324.0
340.0
2.3
2.1
1.9
1.6
1.5
1.5
1.4
1.3
1.2
1.2
1
1
1
1
1
1
1
1
1
1
SMAJ220A
SMAJ250A
SMAJ300A
SMAJ350A
SMAJ400A
SMAJ440A
SMAJ220CA
SMAJ250CA
SMAJ300CA
SMAJ350CA
SMAJ400CA
SMAJ440CA
220.0
250.0
300.0
350.0
400.0
440.0
246.00
272.00
1
356.0
279.00
309.00
1
405.0
335.00
371.00
1
486.0
391.00
432.00
1
567.0
447.00
494.00
1
648.0
492.00
543.00
1
713.0
NOTE: For Bi-directional type having VRWM of 10 Volts and less, the IR limit is double.
1.1
1.0
0.8
0.7
0.6
0.6
1
1
1
1
1
1
For parts without A, the VBR is ± 10% and VC is 5% higher than with A parts.
Rev 2: Nov 2018
派克微电子(深圳)有限公司
www.pakermicro.com
Page 2 of 3
SMAJ Series
Ratings and Characteristic Curves
Fig.1 Peak Pulse Power Rating
Fig.2 Pulse Derating Cure
Fig.3 Pulse Waveform
Fig.4 Typical Junction Capacitance
Package Outline Dimensions: SMA(DO-214AC)
Dim
T
Rev 2: Nov 2018
Millimeters
Inches
Min
Max
Min
Max
L
4.1
4.3
0.161
0.169
D
2.5
2.7
0.098
0.106
D1
1.3
1.5
0.051
0.059
T
4.8
5.2
0.189
0.205
T1
0.9
1.5
0.035
0.060
d
0.2
0.008
H
2.05
2.35
0.081
0.093
H1
2.0
2.2
0.079
0.087
派克微电子(深圳)有限公司
www.pakermicro.com
Page 3 of 3
很抱歉,暂时无法提供与“SMAJ6.5CA”相匹配的价格&库存,您可以联系我们找货
