P4SMA6.8(A) – P4SMA200(A)
Taiwan Semiconductor
400W, 6.8V - 200V Surface Mount Transient Voltage Suppressor
FEATURES
KEY PARAMETERS
Ideal for automated placement
Glass passivated chip junction
Excellent clamping capability
Fast response time: Typically less than 1.0ps
Typical IR less than 1μA above 10V
Meets ISO 7637-2 (Pulse 1/2a/2b/3a/3b)
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VWM
5.5 - 171
V
VBR
PPPM
tp = 10/1000μs waveform
TJ MAX
6.12 - 210
V
400
W
150
°C
Package
DO-214AC (SMA)
Configuration
Single die
APPLICATIONS
Switching mode power supply (SMPS)
Adapters
Lighting application
On-board DC/DC converter
MECHANICAL DATA
Case: DO-214AC (SMA)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.060g (approximately)
DO-214AC (SMA)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Peak power dissipation at TA = 25°C, tp = 1ms (Note 1)
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load
Maximum instantaneous forward voltage at 25A for
unidirectional only
Operating junction temperature range
SYMBOL
VALUE
UNIT
PPK
400
W
IFSM
40
A
VF
3.5
V
TJ
-55 to +150
°C
-55 to +150
°C
Storage temperature range
TSTG
Notes:
1. Non-repetitive current pulse per Fig.5 and derated above TA = 25°C per Fig.2
Devices for Bipolar Applications
1. For bidirectional use C or CA suffix for types P4SMA6.8 - types P4SMA200A
2. Electrical characteristics apply in both directions
1
Version: S2102
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
Breakdown
voltage
Part number
Marking
code
VBR@IT(1)
(V)
P4SMA6.8
P4SMA6.8A
P4SMA7.5
P4SMA7.5A
P4SMA8.2
P4SMA8.2A
P4SMA9.1
P4SMA9.1A
P4SMA10
P4SMA10A
P4SMA11
P4SMA11A
P4SMA12
P4SMA12A
P4SMA13
P4SMA13A
P4SMA15
P4SMA15A
P4SMA16
P4SMA16A
P4SMA18
P4SMA18A
P4SMA20
P4SMA20A
P4SMA22
P4SMA22A
P4SMA24
P4SMA24A
P4SMA27
P4SMA27A
P4SMA30
P4SMA30A
P4SMA33
P4SMA33A
P4SMA36
P4SMA36A
P4SMA39
P4SMA39A
P4SMA43
P4SMA43A
P4SMA47
P4SMA47A
P4SMA51
P4SMA51A
P4SMA56
P4SMA56A
P4SMA62
P4SMA62A
ADJ
AEJ
AFJ
AGJ
AHJ
AKJ
ALJ
AMJ
ANJ
APJ
AQJ
ARJ
ASJ
ATJ
AUJ
AVJ
AWJ
AXJ
AYJ
AZJ
BDJ
BEJ
BFJ
BGJ
BHJ
BKJ
BLJ
BMJ
BNJ
BPJ
BQJ
BRJ
BSJ
BTJ
BUJ
BVJ
BWJ
BXJ
BYJ
BZJ
CDJ
CEJ
CFJ
CGJ
CHJ
CKJ
CLJ
CMJ
Working
Test
stand-off
current
voltage
IT
(mA)
Min
Max
6.12
6.46
6.75
7.13
7.38
7.79
8.19
8.65
9.00
9.50
9.90
10.50
10.80
11.40
11.70
12.40
13.50
14.30
14.40
15.20
16.20
17.10
18.00
19.00
19.80
20.90
21.60
22.80
24.30
25.70
27.00
28.50
29.70
31.40
32.40
34.20
35.10
37.10
38.70
40.90
42.30
44.70
45.90
48.50
50.40
53.20
55.8
58.9
7.48
7.14
8.25
7.88
9.02
8.61
10.00
9.55
11.00
10.50
12.10
11.60
13.20
12.60
14.30
13.70
16.50
15.80
17.60
16.80
19.80
18.90
22.00
21.00
24.20
23.10
26.40
25.20
29.70
28.40
33.00
31.50
36.30
34.70
39.60
37.80
42.90
41.00
47.30
45.20
51.70
49.40
56.10
53.60
61.60
58.80
68.2
65.1
Maximum reverse
VWM
Maximum
Maximum peak
clamping
leakage current
impulse current
IR@VWM(1)
IPPM (A)
(µA)
tp =10/1000 μs
1000
1000
500
500
200
200
50
50
10
10
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
38.0
40.0
35.0
37.0
33.0
34.0
30.0
31.0
28.0
29.0
26.0
27.0
24.0
25.0
22.0
23.0
19.0
20.0
17.8
18.6
16.0
16.5
14.0
15.0
13.0
13.7
12.0
12.6
10.7
11.0
9.6
10.0
8.8
9.0
8.0
8.4
7.4
7.7
6.7
7.0
6.2
6.4
5.7
6.0
5.2
5.4
4.7
5.0
voltage
(V)
10
10
10
10
10
10
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
5.50
5.80
6.05
6.40
6.63
7.02
7.37
7.78
8.10
8.55
8.92
9.40
9.72
10.2
10.5
11.1
12.1
12.8
12.9
13.6
14.5
15.3
16.2
17.1
17.8
18.8
19.4
20.5
21.8
23.1
24.3
25.6
26.8
28.2
29.1
30.8
31.6
33.3
34.8
36.8
38.1
40.2
41.3
43.6
45.4
47.8
50.2
53.0
2
VC@IPPM (V)
tp =10/1000 μs
10.8
10.5
11.7
11.3
12.5
12.1
13.8
13.4
15.0
14.5
16.2
15.6
17.3
16.7
19.0
18.2
22.0
21.2
23.5
22.5
26.5
25.5
29.1
27.7
31.9
30.6
34.7
33.2
39.1
37.5
43.5
41.4
47.7
45.7
52.0
49.9
56.4
53.9
61.9
59.3
67.8
64.8
73.5
70.1
80.5
77.0
89.0
85.0
Maximum
Temperature
Coefficient
of VBR
(%/°C)
0.057
0.057
0.061
0.061
0.065
0.065
0.068
0.068
0.073
0.073
0.075
0.075
0.078
0.078
0.081
0.081
0.084
0.084
0.086
0.086
0.088
0.088
0.090
0.090
0.092
0.092
0.094
0.094
0.096
0.096
0.097
0.097
0.098
0.098
0.099
0.099
0.100
0.100
0.101
0.101
0.101
0.101
0.102
0.102
0.103
0.103
0.104
0.104
Version: S2102
Working
Breakdown
voltage
Part number
Marking
code
VBR@IT(1)
Test
stand-off
current
(V)
Min
Maximum reverse
voltage
IT
(mA)
Max
VWM
Maximum
Maximum peak
clamping
leakage current
impulse current
IR@VWM(1)
IPPM (A)
(µA)
tp =10/1000 μs
voltage
(V)
P4SMA68
CNJ
61.2 74.8
1.0
55.1
1
4.2
P4SMA68A
CPJ
64.6 71.4
1.0
58.1
1
4.5
P4SMA75
CQJ
67.5 82.5
1.0
60.7
1
3.8
P4SMA75A
CRJ
71.3 78.8
1.0
64.1
1
4.0
P4SMA82
CSJ
73.8 90.2
1.0
66.4
1
3.5
P4SMA82A
CTJ
77.9 86.1
1.0
70.1
1
3.7
P4SMA91
CUJ
81.9 100
1.0
73.7
1
3.2
P4SMA91A
CVJ
86.5 95.5
1.0
77.8
1
3.3
P4SMA100
CWJ
90 110
1.0
81.0
1
2.9
P4SMA100A
CXJ
95 105
1.0
85.5
1
3.0
P4SMA110
CYJ
99 121
1.0
89.2
1
2.6
P4SMA110A
CZJ
105 116
1.0
94.0
1
2.7
P4SMA120
RDJ
108 132
1.0
97.2
1
2.4
P4SMA120A
REJ
114 126
1.0
102
1
2.5
P4SMA130
RFJ
117 143
1.0
105
1
2.2
P4SMA130A
RGJ
124 137
1.0
111
1
2.3
P4SMA150
RHJ
135 165
1.0
121
1
1.9
P4SMA150A
RKJ
143 158
1.0
128
1
2.0
P4SMA160
RLJ
144 176
1.0
130
1
1.8
P4SMA160A
RMJ
152 168
1.0
136
1
1.9
P4SMA170
RNJ
153 187
1.0
138
1
1.7
P4SMA170A
RPJ
162 179
1.0
145
1
1.8
P4SMA180
RQJ
162 198
1.0
146
1
1.6
P4SMA180A
RRJ
171 189
1.0
154
1
1.7
P4SMA200
RSJ
180 220
1.0
162
1
1.4
P4SMA200A
RTJ
190 210
1.0
171
1
1.51
Notes:
1. VBR measure after IT applied for 300μs, IT = square wave pulse or equivalent.
2. Surge current waveform per Figure.5 and derate per Figure.2.
3. For bipolar types having VWM of 10 volts and under, the ID limit is doubled.
4. For bidirectional use C or CA suffix for types PS4MA6.8 through P4SMA200A.
5. All terms and symbols are consistent with ANSI/IEEE C62.35.
Maximum
Temperature
Coefficient
of VBR
VC@IPPM (V)
tp =10/1000 μs
98.0
92.0
108
103
118
113
131
125
144
137
158
152
173
165
187
179
215
207
230
219
244
234
258
246
287
274
(%/°C)
0.104
0.104
0.105
0.105
0.105
0.105
0.106
0.106
0.106
0.106
0.107
0.107
0.107
0.107
0.107
0.107
0.108
0.108
0.108
0.108
0.108
0.108
0.108
0.108
0.108
0.108
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
P4SMAx
DO-214AC (SMA)
7,500 / Tape & Reel
Notes:
1. “x” defines voltage from 6.8V(P4SMA6.8) to 200V(P4SMA200A)
3
Version: S2102
CHARACTERISTICS CURVES
Fig.1 Peak Pulse Power Rating Curve
Fig.2 Pulse Derating Curve
PEAK PULSE POWER(PPP) OR CURRENT (IPP)
DERATING IN PERCENTAGE (%)
PPPM, PEAK PULSE POWER (KW)
100
Non-repetitive
pulse waveform
shown in fig.5
10
1
125
100
75
50
25
0.1
1
10
100
tp, PULSE WIDTH (μs)
1000
IFSM, PEAK FORWARD SURGE CURRENT (A)
CJ, JUNCTION CAPACITANCE (pF)
VR=0
1000
Measured at
stand-off
voltage, Vwm
f=1.0MHz
Vsig=50mVp-p
10
1
75
100
125
150
Fig.4 Maximum Non-repetitive Forward Surge
Current
100000
100
50
TA, AMBIENT TEMPERATURE (°C)
Fig.3 Typical Junction Capacitance
10000
25
10
100
50
8.3ms single half sine wave
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
V(BR), BREAKDOWN VOLTAGE (V)
4
Version: S2102
Fig.5 Clamping Power Pulse Waveform
120
IPPM, PEAK PULSE CURRENT (%)
110
Peak value
IPPM
100
Pulse width(td) is defined
as the point where the peak
current decays to 50% of IPPM
90
Rise time tr=10μs to 100% of IPPM
80
70
Half value-IPPM/2
10/1000μs, waveform
as defined by R.E.A.
60
50
40
30
td
10
1
1.5
2
2.5
3
3.5
4
4.5
5
t, TIME (ms)
5
Version: S2102
PACKAGE OUTLINE DIMENSIONS
DO-214AC (SMA)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Cathode band for uni-directional products only
6
Version: S2102
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for
application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to any
intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for
such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale
and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability,
or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers
using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for
any damages resulting from such improper use or sale.
7
Version: S2102
很抱歉,暂时无法提供与“P4SMA36CA HM2”相匹配的价格&库存,您可以联系我们找货
