SMAJ30CA
SMAJ30CA
    YJSEMI(元捷)
    SMA(DO-214AC)
    TVS 30V截止 峰值脉冲电流:8.26A
SMAJ30CA 数据手册
山东元捷电子科技 Shan dong YuanJie Electronic Technology Technical Information SMAJ SERIES Surface Mount Transient Voltage Suppressor Diodes )HDWXUHV ƹ Excellent clamping capability ◆ Low dynamic impedance ◆ Solder dip 260 °C max. 10 s, per JESD 22-B106 0HFKDQLFDO'DWD &DVHDO-214AC (SMA) Molded plastic body Terminals: Tin plated leads, solderable per J-STD- 002 and JESD22-B102 0RXQWLQJ3RVLWLRQAny 0D[LPXP5DWLQJV (OHFWULFDO&KDUDFWHULVWLFV Ratings at TA = 25°C unless otherwise specified PARAMETER SYMBOL Peak power dissipation, with a 10/1000us waveform(1)(2 ) Power dissipation, on infinite heat sink at TL=75℃(2) Peak forward surge current, 8.3 ms single half sine-wave unidirectional only (2) Operating junction and storage temperature range Maximum instantaneous forward voltage at 25A for unidirectional only(3) Junction to ambient Junction to lead UNIT Max PPPM W 400 PD W 1.0 IFSM A 40 TJ,TST G ℃ -55 to +150 VFM V 3.5/5.0 RθJ-A ℃/W 120 RθJ-L ℃/W 30 Notes: (1) Non-repetitive current pulse, per Fig. 3 and derated above TA= 25℃per Fig.2. (2) Mounted on 0.2 x 0.2" (5.0 x 5.0 mm) copper pads to each terminal (3) VF=3.5V Max for devices of VBR≤220v,and VF=5.0v Max for devices of VBR>220v. Revision:2018-12-12 1 www.yjsemi.com.cn 山东元捷电子科技 Shan dong YuanJie Electronic Technology Technical Information SMAJ SERIES Surface Mount Transient Voltage Suppressor Diodes Part No. SMAJ5.0A SMAJ6.0A SMAJ6.5A SMAJ7.0A SMAJ7.5A SMAJ8.0A SMAJ8.5A SMAJ9.0A SMAJ10A SMAJ11A SMAJ12A SMAJ13A SMAJ14A SMAJ15A SMAJ16A SMAJ17A SMAJ18A SMAJ19A SMAJ20A SMAJ22A SMAJ24A SMAJ26A SMAJ28A SMAJ30A SMAJ33A SMAJ36A SMAJ40A SMAJ43A SMAJ45A SMAJ48A SMAJ51A SMAJ54A SMAJ58A SMAJ60A SMAJ64A SMAJ70A SMAJ75A SMAJ78A SMAJ80A SMAJ85A SMAJ90A SMAJ100A SMAJ110A SMAJ120A SMAJ130A SMAJ140A SMAJ150A SMAJ160A SMAJ170A SMAJ180A SMAJ190A SMAJ200A SMAJ220A SMAJ250A SMAJ300A SMAJ350A SMAJ400A SMAJ440A Peak Power Dissipation 10/1000μ sec(W) Reverse Stand-Off Voltage VRWM(V) Breakdown Voltage VBR (V) Min @ IT Breakdown Voltage VBR (V) Max @ IT Test Current IT (mA) Max Clamping Voltage VC (V)@ IPP Peak Pulse Current IPP (A) Reverse Leakage IR (μA) @ VRWM 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 5.0 6.0 6.5 7.0 7.5 8.0 8.5 9.0 10.0 11.0 12.0 13.0 14.0 15.0 16.0 17.0 18.0 19.0 20.0 22.0 24.0 26.0 28.0 30.0 33.0 36.0 40.0 43.0 45.0 48.0 51.0 54.0 58.0 60.0 64.0 70.0 75.0 78.0 80.0 85.0 90.0 100.0 110.0 120.0 130.0 140.0 150.0 160.0 170.0 180.0 190.0 200.0 220.0 250.0 300.0 350.0 400.0 440.0 6.40 6.67 7.22 7.78 8.33 8.89 9.44 10.00 11.10 12.20 13.30 14.40 15.60 16.70 17.80 18.90 20.00 21.10 22.20 24.40 26.70 28.90 31.10 33.30 36.70 40.00 44.40 47.80 50.00 53.30 56.70 60.00 64.40 66.70 71.10 77.80 83.30 86.70 88.80 94.40 100.00 111.00 122.00 133.00 144.00 155.00 167.00 178.00 189.00 200.00 211.00 224.00 246.00 279.00 335.00 391.00 447.00 492.00 7.00 7.37 7.98 8.60 9.21 9.83 10.40 11.10 12.30 13.50 14.70 15.90 17.20 18.50 19.70 20.90 22.10 23.30 24.50 26.90 29.50 31.90 34.40 36.80 40.60 44.20 49.10 52.80 55.30 58.90 62.70 66.30 71.20 73.70 78.60 86.00 92.10 95.80 97.60 104.00 111.00 123.00 135.00 147.00 159.00 171.00 185.00 197.00 209.00 220.00 232.00 247.00 272.00 309.00 371.00 432.00 494.00 543.00 10 10 10 10 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 9.2 10.3 11.2 12.0 12.9 13.6 14.4 15.4 17.0 18.2 19.9 21.5 23.2 24.4 26.0 27.6 29.2 30.8 32.4 35.5 38.9 42.1 45.4 48.4 53.3 58.1 64.5 69.4 72.7 77.4 82.4 87.1 93.6 96.8 103.0 113.0 121.0 126.0 129.6 137.0 146.0 162.0 177.0 193.0 209.0 226.8 243.0 259.0 275.0 291.6 307.8 324.0 356.0 405.0 486.0 567.0 648.0 713.0 43.47 38.83 35.71 33.33 31.00 29.41 27.77 25.97 23.53 21.98 20.10 18.60 17.24 16.39 15.38 14.49 13.70 13.00 12.35 11.27 10.28 9.50 8.81 8.26 7.50 6.88 6.20 5.76 5.50 5.17 4.85 4.59 4.27 4.13 3.88 3.54 3.31 3.17 3.09 2.92 2.74 2.47 2.26 2.07 1.91 1.76 1.65 1.54 1.45 1.37 1.30 1.23 1.12 0.99 0.82 0.71 0.62 0.56 800 800 500 200 100 50 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 SMAJ5.0CA SMAJ6.0CA SMAJ6.5CA SMAJ7.0CA SMAJ7.5CA SMAJ8.0CA SMAJ8.5CA SMAJ9.0CA SMAJ10CA SMAJ11CA SMAJ12CA SMAJ13CA SMAJ14CA SMAJ15CA SMAJ16CA SMAJ17CA SMAJ18CA SMAJ19CA SMAJ20CA SMAJ22CA SMAJ24CA SMAJ26CA SMAJ28CA SMAJ30CA SMAJ33CA SMAJ36CA SMAJ40CA SMAJ43CA SMAJ45CA SMAJ48CA SMAJ51CA SMAJ54CA SMAJ58CA SMAJ60CA SMAJ64CA SMAJ70CA SMAJ75CA SMAJ78CA SMAJ80CA SMAJ85CA SMAJ90CA SMAJ100CA SMAJ110CA SMAJ120CA SMAJ130CA SMAJ140CA SMAJ150CA SMAJ160CA SMAJ170CA SMAJ180CA SMAJ190CA SMAJ200CA SMAJ220CA SMAJ250CA SMAJ300CA SMAJ350CA SMAJ400CA SMAJ440CA Revision:2018-12-12 2 www.yjsemi.com.cn 山东元捷电子科技 Shan dong YuanJie Electronic Technology Technical Information SMAJ SERIES Surface Mount Transient Voltage Suppressor Diodes  Typical Characteristics 1 00 100 Non-Repetitive Pulse Waveform shown in Fige.3 TA=25℃ PPP or IPP(%) 75 PPPM(KW) 10 50 1.0 25 0.2×0.2"(5.0×5.0mm) Copper Pad Areas 0.1 1μs 0.1μs 0 10μs 100μs 1.0ms 0 10ms 25 50 75 td(μs) 200 TJ=25℃ Pulse Width(td) is defined as the Point where the Peak Current Decays to 50% of IPPM Peak Value IPPM Half Value - IPP Rth(℃/W) IPPM(%) 175 1000 tr=10μs 100 150 FIG2: Pulse Power or Current vs. Initial Junction Temperature FIG1:Peak Pulse Power Rating Curve 150 100 125 TJ(℃) IPPM 50 100 10 10/1000μs Waveform as Defined by R.E.A. td 0 1.0 0 2.0 3.0 1 4.0 0.001 T(ms) 0.01 0.1 1 tp(s) 10 100 1000 FIG4:Typical Transient Thermal Impedance FIG3: Pulse Waveform 100 80 TJ=TJMax. 8.3ms Single Half Sine-Wave IFSM(A) 60 40 20 10 0 5 10 100 Number of Cycles FIG5: Maximum Non-Repetitive Surge Current Revision:2018-12-12 3 www.yjsemi.com.cn 山东元捷电子科技 Technical Information Shan dong YuanJie Electronic Technology Surface Mount Transient Voltage Suppressor Diodes SMAJ SERIES  3DFNDJH2XWOLQH'LPHQVLRQV(unit:mm) DO-214AC (SMA) 0RXQWLQJ3DG/D\RXW(unit:mm) P2 Q2 P3 Q1 P1 Revision:2018-12-12 4 Dim Millimeters P1 6.50 P2 4.00 P3 1.50 Q1 2.50 Q2 1.70 www.yjsemi.com.cn
SMAJ30CA 价格&库存
很抱歉,暂时无法提供与“SMAJ30CA”相匹配的价格&库存,您可以联系我们找货
