SMA6J Series
Surface Mount Transient
Voltage Suppressors
Reverse Voltage: 5.0 to 58 V
Peak Pulse Power: 600 W
Features
SMA/ DO-214AC
Glass passivated chip
600 W peak pulse power capability with a
10/1000 μs waveform, repetitive rate (duty
cycle):0.01 %
Low leakage
Uni and Bidirectional unit
Excellent clamping capability
Very fast response time
RoHS compliant
0.109 2.76
0.099 2.51
0.179 4.55
0.162 4.10
Mechanical Data
0.064 1.63
0.049 1.23
Case: Molded plastic
Epoxy: UL 94V-0 rate flame retardant
Lead: Solderable per MIL-STD-750, method
2026
Polarity: Color band denotes cathode end
except Bipolar
Mounting position: Any
0.012 0.30
0.006 0.15
0.089 2.26
0.077 1.96
0.206 5.22
0.192 [4.87]
0.06 1.51
0.03 0.75
0.008 0.20
Dimensions : inch [ mm ]
Maximum Ratings(TA=25℃ unless otherwise noted)
Parameter
(1)
Peak power dissipation with a 10/1000μs waveform
Peak pulse current wih a 10/1000μs waveform(1)
Power dissipation on infinite heatsink at TL = 75 °C
Peak forward surge current, 8.3 ms single half sinewave unidirectional only(2)
Maximum instantaneous forward voltage at 25 A for
(3)
unidirectional only
Operating junction and storage temperature range
Value
Symbol
PPP
600
IPP
See Next Table
PD
3.0
UNIT
W
A
W
IFSM
60
A
VF
3.5
V
TJ, TSTG
–55 to +150
°C
Note:
(1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1
(2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum
Revision:20170701-P1
ht t p : //
www.lgesem i .c o m
mail:lge@lgesemi.com
SMA6J Series
Voltage Suppressors
Ratings and Characteristics Curves (TA=25℃ unless otherwise noted)
80
25
100
175
Peak Forward Surge Current, (A)
Peak Pulse Derating in Percentage of Peak
Power or Current, (%)
AVERAGE
FORWARD
CURRENT, (A)
AMBIENT
TEMPERATURE
100
50
25
50
75
100
125
150
175
60 8.3 ms Single Half Sine-Wave
100
60
18
40
TJ = TJ max.
1
200
1
10
Ambient Temperature ,TA (℃)
Fig. 1 - Pulse Derating Curve
Fig. 2 - Maximum Non-Repetitive
Surge Current
100
3.0
3
0.1
30
73
3
10000
0.22
Steady State Power Dissipation, (W)
10
1.0
0.0
1
50
75
100
125
150
175
0.1
200
0.1
1
10
Lead Temperature , TL (℃)
TJ = 25 °C
Pulse Width (td) is defined as the
point where the peak current
decays to 50 % of Ipp
1000
0.2
100
Half Value = Ipp
0.5 2 76
1
50
1.5
33
μsec. Waveform
210/1000
23
as defined by R.E.A.
3
13
4
10
50
td
1
2
10000
3
4
450
3000
50
5
450
Bi-directional
@zero bias
Uni-directional
@zero bias
Uni-directional
2000 @V
22RWM
100
5
10
1
1650
4
5
450
1400
5
TJ=25 °C
f=1.0MHz
1
10
Bi-directional @VRWM
100
1000
Reverse Breakdown Voltage,VBR (V)
Time , (ms)
Fig. 5 - Pulse Waveform
5
Junction Capacitance,CJ (pF)
Peak Pulse Current , (% )
100
1000
Fig. 4 - Peak Pulse Power Rating Curve
10000
Tr=10μs
Peak Value
(Ipp)
100
Pulse Width ,td (μs)
Fig. 3 - Steady State Power Derating Curve
Number of Cycles at 60 Hz
ht t p : //
Fig. 6 - Typical Junction Capacitance
www.lgesem i .c o m
SMA6J Series
Voltage Suppressors
Electrical Characteristics(TA=25℃ unless otherwise noted)
Part Number Part Number
(Uni)
(Bi)
SMA6J5.0A
SMA6J6.0A
SMA6J6.5A
SMA6J7.0A
SMA6J7.5A
SMA6J8.0A
SMA6J8.5A
SMA6J9.0A
SMA6J10A
SMA6J11A
SMA6J12A
SMA6J13A
SMA6J14A
SMA6J15A
SMA6J16A
SMA6J17A
SMA6J18A
SMA6J19A
SMA6J20A
SMA6J22A
SMA6J24A
SMA6J26A
SMA6J28A
SMA6J30A
SMA6J33A
SMA6J36A
SMA6J40A
SMA6J43A
SMA6J45A
SMA6J48A
SMA6J51A
SMA6J54A
SMA6J58A
SMA6J5.0CA
SMA6J6.0CA
SMA6J6.5CA
SMA6J7.0CA
SMA6J7.5CA
SMA6J8.0CA
SMA6J8.5CA
SMA6J9.0CA
SMA6J10CA
SMA6J11CA
SMA6J12CA
SMA6J13CA
SMA6J14CA
SMA6J15CA
SMA6J16CA
SMA6J17CA
SMA6J18CA
SMA6J19CA
SMA6J20CA
SMA6J22CA
SMA6J24CA
SMA6J26CA
SMA6J28CA
SMA6J30CA
SMA6J33CA
SMA6J36CA
SMA6J40CA
SMA6J43CA
SMA6J45CA
SMA6J48CA
SMA6J51CA
SMA6J54CA
SMA6J58CA
Device
Marking
Code
Uni
Bi
KE
KG
KK
KM
KP
KR
KT
KV
KX
KZ
LE
LG
LK
LM
LP
LR
LT
LB
LV
LX
LZ
ME
MG
MK
MM
MP
MR
MT
MV
MX
MZ
NE
NG
WE
AG
AK
AM
AP
AR
AT
AV
AX
AZ
BE
BG
BK
BM
BP
BR
BT
BB
BV
BX
BZ
CE
CG
CK
CM
CP
CR
CT
CV
CX
CZ
DE
DG
Maximum
Reverse
Breakdown Voltage VBR @IT
Leakage IR
@VRWM
Min (V) Max (V) IT (mA)
(uA)
6.40
6.67
7.22
7.78
8.33
8.89
9.44
10.00
11.10
12.20
13.30
14.40
15.60
16.70
17.80
18.90
20.00
21.10
22.20
24.40
26.70
28.90
31.10
33.30
36.70
40.00
44.40
47.80
50.00
53.30
56.70
60.00
64.40
7.00
7.37
7.98
8.60
9.21
9.83
10.40
11.10
12.30
13.50
14.70
15.90
17.20
18.50
19.70
20.90
22.10
23.30
24.50
26.90
29.50
31.90
34.40
36.80
40.60
44.20
49.10
52.80
55.30
58.90
62.70
66.30
71.20
10
10
10
10
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
800
800
500
200
100
50
10
5.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
Working
Peak
Reverse
Voltage
VRWM
(V)
5.0
6.0
6.5
7.0
7.5
8.0
8.5
9.0
10.0
11.0
12.0
13.0
14.0
15.0
16.0
17.0
18.0
19.0
20.0
22.0
24.0
26.0
28.0
30.0
33.0
36.0
40.0
43.0
45.0
48.0
51.0
54.0
58.0
Maximum Maximum
Clamping
Reverse
Voltage VC
Surge
Current IPP
@IPP
(A)
(V)
65.2
58.3
53.6
50.0
46.5
44.1
41.7
39.0
35.3
33.0
30.2
27.9
25.9
24.6
23.1
21.7
20.5
19.5
18.5
16.9
15.4
14.3
13.2
12.4
11.3
10.3
9.30
8.65
8.25
7.75
7.28
6.89
6.41
9.2
10.3
11.2
12.0
12.9
13.6
14.4
15.4
17.0
18.2
19.9
21.5
23.2
24.4
26.0
27.6
29.2
30.8
32.4
35.5
38.9
42.1
45.4
48.4
53.3
58.1
64.5
69.4
72.7
77.4
82.4
87.1
93.6
Note:
1. Suffix 'A ' denotes 5% tolerance device. Without 'A' denotes 10% tolerance device
2. Add suffix 'C 'or ' CA ' after part number to specify Bi-directional devices
3. For Bi-Directional devices having VR of 10 volts and under, the IR limit is double
ht t p : //
www.lgesem i .c o m
很抱歉,暂时无法提供与“SMAJ48A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.33124
- 100+0.26363
- 300+0.22983
- 1000+0.20445
- 5000+0.17572
- 10000+0.16557
