SMAJ Series
Transient Voltage Suppressors (TVS) Data Sheet
Features
Glass passivated junction
Low zener impedance
Excellent clamping capability
400W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle):0.01%
Fast response time
Typical IR less than 1μA above 13V.
Plastic package has underwriters laboratory flammability 94V-0
Meets MSL level 1, per J-STD-020.
Mechanical Data
Case: JEDEC DO-214AC Moulded plastic
Terminal:solderplated, solderable per MIL-STD-750, Method 2026
Polarity: Color band denotes cathode except bi-directional models
Mounting Position: Any
Applications
■ I/O interface
■ AC/DC power supply
■ Low frequency signal transmission line (RS232, RS485, etc.)
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Fig.1)
PPPM
Minimum 400
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
3.3
Watts
IFSM
40
Amps
TJ,TSTG
-55 to +150
Typical thermal resistance junction to lead
RθJL
30
℃/W
Typical thermal resistance junction to ambient
RθJA
120
℃/W
Steady state power dissipation at TL=75℃ (Fig.4)
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note2)
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
2. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
Revision:10-May-18
1/6
www.ftrqg.com
SMAJ Series
Dimensions (DO-214AC/SMA)
Millimeters
Inches
Symbol
D1 D
L
H
d
T1
T
Min.
Max.
Min.
Max.
L
3.90
4.50
0.154
0.177
D
2.40
2.80
0.094
0.110
D1
1.30
1.70
0.051
0.067
T
4.80
5.30
0.189
0.208
T1
0.76
1.52
0.030
0.060
d
0.10
0.20
0.003
0.008
H
2.00
2.50
0.078
0.098
Electrical Characteristics (TA=25℃)
Part Number
Unidirectional
Bidirectional
Device
Marking
Code
Reverse
Stand-O
ff
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage@
IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMAJ5.0A
SMAJ5.0CA
AE
WE
5.0
6.4~7.0
10
9.2
43.5
800
SMAJ6.0A
SMAJ6.0CA
AG
WG
6.0
6.7~7.4
10
10.3
38.8
800
SMAJ6.5A
SMAJ6.5CA
AK
WK
6.5
7.2~8.0
10
11.2
35.7
500
SMAJ7.0A
SMAJ7.0CA
AM
WM
7.0
7.8~8.6
10
12.0
33.3
200
SMAJ7.5A
SMAJ7.5CA
AP
WP
7.5
8.3~9.2
1
12.9
31.0
100
SMAJ8.0A
SMAJ8.0CA
AR
WR
8.0
8.9~9.8
1
13.6
29.4
50
SMAJ8.5A
SMAJ8.5CA
AT
WT
8.5
9.4~10.4
1
14.4
27.8
10
SMAJ9.0A
SMAJ9.0CA
AV
WV
9.0
10.0~11.0
1
15.4
26.0
5
SMAJ10A
SMAJ10CA
AX
WX
10.0
11.1~12.3
1
17.0
23.5
5
SMAJ11A
SMAJ11CA
AZ
WZ
11.0
12.2~13.5
1
18.2
22.0
1
SMAJ12A
SMAJ12CA
BE
XE
12.0
13.3~14.7
1
19.9
20.1
1
SMAJ13A
SMAJ13CA
BG
XG
13.0
14.4~15.9
1
21.5
18.6
1
SMAJ14A
SMAJ14CA
BK
XK
14.0
15.6~17.2
1
23.2
17.2
1
SMAJ15A
SMAJ15CA
BM
XM
15.0
16.7~18.5
1
24.4
16.4
1
SMAJ16A
SMAJ16CA
BP
XP
16.0
17.8~19.7
1
26.0
15.4
1
SMAJ17A
SMAJ17CA
BR
XR
17.0
18.9~20.9
1
27.6
14.5
1
SMAJ18A
SMAJ18CA
BT
XT
18.0
20.0~22.1
1
29.2
13.7
1
SMAJ19A
SMAJ19CA
BW
XW
19.0
21.1~23.3
1
30.8
13.0
1
SMAJ20A
SMAJ20CA
BV
XV
20.0
22.2~24.5
1
32.4
12.4
1
SMAJ22A
SMAJ22CA
BX
XX
22.0
24.4~26.9
1
35.5
11.3
1
SMAJ24A
SMAJ24CA
BZ
XZ
24.0
26.7~29.5
1
38.9
10.3
1
SMAJ26A
SMAJ26CA
CE
YE
26.0
28.9~31.9
1
42.1
9.5
1
Revision:10-May-18
2/6
www.ftrqg.com
SMAJ Series
Part Number
Unidirectional
Bidirectional
Device
Marking
Code
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
Maximum
Clamping
Voltage@
IPP
VC(V)
Test
Current
Peak
Pulse
Current
Reverse
Leakage
@VRWM
IPP(A)
IR(μA)
SMAJ28A
SMAJ28CA
CG
YG
28.0
31.1~34.4
1
45.4
8.8
1
SMAJ30A
SMAJ30CA
CK
YK
30.0
33.3~36.8
1
48.4
8.3
1
SMAJ33A
SMAJ33CA
CM
YM
33.0
36.7~40.6
1
53.3
7.5
1
SMAJ36A
SMAJ36CA
CP
YP
36.0
40.0~44.2
1
58.1
6.9
1
SMAJ40A
SMAJ40CA
CR
YR
40.0
44.4~49.1
1
64.5
6.2
1
SMAJ43A
SMAJ43CA
CT
YT
43.0
47.8~52.8
1
69.4
5.8
1
SMAJ45A
SMAJ45CA
CV
YV
45.0
50.0~55.3
1
72.7
5.5
1
SMAJ48A
SMAJ48CA
CX
YX
48.0
53.3~58.9
1
77.4
5.2
1
SMAJ51A
SMAJ51CA
CZ
YZ
51.0
56.7~62.7
1
82.4
4.9
1
SMAJ54A
SMAJ54CA
RE
ZE
54.0
60.0~66.3
1
87.1
4.6
1
SMAJ58A
SMAJ58CA
RG
ZG
58.0
64.4~71.2
1
93.6
4.3
1
SMAJ60A
SMAJ60CA
RK
ZK
60.0
66.7~73.7
1
96.8
4.1
1
SMAJ64A
SMAJ64CA
RM
ZM
64.0
71.1~78.6
1
103.0
3.9
1
SMAJ70A
SMAJ70CA
RP
ZP
70.0
77.8~86.0
1
113.0
3.5
1
SMAJ75A
SMAJ75CA
RR
ZR
75.0
83.3~92.1
1
121.0
3.3
1
SMAJ78A
SMAJ78CA
RT
ZT
78.0
86.7~95.8
1
126.0
3.2
1
SMAJ80A
SMAJ80CA
RW
ZW
80.0
88.8~97.6
1
129.6
3.1
1
SMAJ85A
SMAJ85CA
RV
ZV
85.0
94.4~104
1
137.0
2.9
1
SMAJ90A
SMAJ90CA
RX
ZX
90.0
100~111
1
146.0
2.7
1
SMAJ100A
SMAJ100CA
RZ
ZZ
100.0
111~123
1
162.0
2.5
1
SMAJ110A
SMAJ110CA
SE
VE
110.0
122~135
1
177.0
2.3
1
SMAJ120A
SMAJ120CA
SG
VG
120.0
133~147
1
193.0
2.1
1
SMAJ130A
SMAJ130CA
SK
VK
130.0
144~159
1
209.0
1.9
1
SMAJ140A
SMAJ140CA
SW
VW
140.0
155~171
1
227.0
1.8
1
SMAJ150A
SMAJ150CA
SM
VM
150.0
167~185
1
243.0
1.7
1
SMAJ160A
SMAJ160CA
SP
VP
160.0
178~197
1
259.0
1.6
1
SMAJ170A
SMAJ170CA
SR
VR
170.0
189~209
1
275.0
1.5
1
SMAJ180A
SMAJ180CA
ST
VT
180.0
200~220
1
291.0
1.4
1
SMAJ190A
SMAJ190CA
SU
VU
190.0
211~232
1
308.0
1.3
1
SMAJ200A
SMAJ200CA
SV
VV
200.0
224~247
1
324.0
1.2
1
SMAJ220A
SMAJ220CA
SX
VX
220.0
246~272
1
356.0
1.1
1
SMAJ250A
SMAJ250CA
SZ
VZ
250.0
279~309
1
405.0
1.0
1
SMAJ300A
SMAJ300CA
TE
UE
300.0
335~371
1
486.0
0.8
1
SMAJ350A
SMAJ350CA
TG
UG
350.0
391~432
1
567.0
0.7
1
SMAJ400A
SMAJ400CA
TK
UK
400.0
447~494
1
648.0
0.6
1
SMAJ440A
SMAJ440CA
TM
UM
440.0
492~543
1
713.0
0.6
1
Notes: For bidirectional type having VRWM of 10V and less, the IR limit is double.
Revision:10-May-18
3/6
www.ftrqg.com
SMAJ Series
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25
to Peak
Time
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TLto TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max)( tS)
150℃
200℃
60-180 seconds
TS maxto TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual PeakTemperature (tP)
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
Revision:10-May-18
20-40 seconds
8 minutes max.
4/6
www.ftrqg.com
SMAJ Series
Partnumber code
SMAJ 18 CA
FTR XXXX
XX
Bidirectional
(A:Uni-directional)
VRWM Voltage
FTR logo
Series Code
Date Code
Marking Code
Ratings and Characteristic Curves (T A=25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 3. Pulse Waveform
Revision:10-May-18
Figure 2. Pulse Derating Curve
Figure 4. Steady State Power Dissipation Derating
Curve
5/6
www.ftrqg.com
SMAJ Series
Packaging
Tape
P0
P1
P2
D0
B
T
E
F
W
B0
A
A
Symbol
Dimension (mm)
W
12.00±0.10
P0
4.00±0.10
P1
4.00±0.10
P2
2.00±0.10
D0
Φ1.55±0.10
E
1.75±0.10
F
5.50±0.10
A0
2.80±0.1
B0
5.30±0.1
K0
2.36±0.1
T
0.25±0.1
D5
Φ330.0±2.0
D6
Φ12.0±0.5
W2
14.0±2.0
K0
B
SECTION B-B
A0
SECTION A-A
Reel
Quantity: 5000PCS
Revision:10-May-18
6/6
www.ftrqg.com
很抱歉,暂时无法提供与“SMAJ33A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.27411
- 100+0.22119
- 300+0.19473
- 1000+0.17486
- 5000+0.14472
- 10000+0.13684
