SMAJ Series
Transient Voltage Suppressors
Working Voltage: 5.0 to 440 V
Peak Pulse Power: 400 W
Features
SMA/ DO-214AC
Glass passivated chip
400 W peak pulse power capability with a
10/1000 ȝs waveform, repetitive rate (duty
cycle):0.01 %
Low leakage
Uni and Bidirectional unit
Excellent clamping capability
Very fast response time
RoHS compliant
Mechanical Data
Case: Molded plastic
Epoxy: UL 94V-0 rate flame retardant
Lead: Solderable per MIL-STD-750, method
2026
Polarity: Color band denotes cathode end
except Bipolar
Mounting position: Any
Maximum Ratings(TA=25ɗ unless otherwise noted)
Parameter
(1)
Peak power dissipation with a 10/1000ȝs waveform
Peak pulse current wih a 10/1000ȝs waveform(1)
Power dissipation on infinite heatsink at TL = 75 °C
Peak forward surge current, 8.3 ms single half sine(2)
wave unidirectional only
Maximum instantaneous forward voltage at 25 A for
(3)
unidirectional only
Operating junction and storage temperature range
Value
Symbol
PPP
400
IPP
See Next Table
PD
1.0
UNIT
W
A
W
IFSM
40
A
VF
3.5/5.0
V
TJ, TSTG
–55 to +150
°C
Note:
(1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1
(2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum
(3)VF
很抱歉,暂时无法提供与“SMAJ18CA”相匹配的价格&库存,您可以联系我们找货
