SMAJ15CA
SMAJ15CA
    ME-TECH(美台高科)
    SMA(DO-214AC)
    双向TVS 15V截止 峰值脉冲电流:16A
SMAJ15CA 数据手册
SMAJ××A(CA) Features  400 watts Peak Pulse Power (10/1000 μs)  Unidirectional and Bidirectional Protection  Fast Response Time : Typically < 1ps  Excellent Clamping Capability  Glass Passivated Junction  Built-in Strain relief  Low inductance  Low profile package  High temperature solder:260℃/20 seconds at terminal SMA (JEDEC DO-214AC) Mechanical Characteristics Applications  JEDEC DO-214AC(SMAJ) package  I/O Interfaces  Molding compound flammability rating:  Power lines UL 94V-0  Automotive and Telecommunication  Marking : Marking Code  Computers &Consumer Electronics  Packaging : Tape and Reel per EIA 481  Industrial Electronics  RoHS/WEEE Compliant Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power (tp =10/1000μs) (see Note1,2& 3) PPPM 400 Watts Peak pulse current (10/1000 μs) (see Note2&3) IPPM See Electrical Characteristics A Peak Forward surge current (see Note4&5) IFSM 40 A Power Dissipation on infinite heat sink TA = 50 °C (Fig5) PD 1.0 W Operating Junction Temperature range TJ -65 to + 150 ℃ TSTG -65 to + 150 ℃ Storage Temperature range Note1: Peak Pulse Power Rating as Pulse Width ,per Fig1. Note2: Peak Pusle Power or Current Derated above TA=25℃ Per Fig. 2 and Non-Repetitive Current Pulse,Per Fig.3. 2 Note3: Mounted on 5.0x5.0mm copper pad to each terminal. Note4: 8.3ms Single Half Sine Wave or Equivalent Square Wave. Note5: Maximum Forward Surge Current only for Unidirectional Device per Fig6. 1 SMAJ××A(CA) Electrical Characteristics Part Number Reverse Stand off Voltage VRWM Breakdown Voltage VBR(Volts)@IT Test IT Maximum Clamping Voltage Vc@IPP Maximum PeakPulse Current Ipp Maximum Reverse Leakage IR@VRWM (Volts) (Amps) (μA) Current UNI-POLAR BI-POLAR (Volts) MIN MAX (mA) SMAJ5.0A SMAJ5.0CA 5.0 6.40 7.07 10 9.2 43.5 800 SMAJ6.0A SMAJ6.0CA 6.0 6.67 7.37 10 10.3 38.8 800 SMAJ6.5A SMAJ6.5CA 6.5 7.22 7.98 10 11.2 35.7 500 SMAJ7.0A SMAJ7.0CA 7.0 7.78 8.60 10 12.0 33.3 200 SMAJ7.5A SMAJ7.5CA 7.5 8.33 9.21 1 12.9 31.0 100 SMAJ8.0A SMAJ8.0CA 8.0 8.89 9.83 1 13.6 29.4 50 SMAJ8.5A SMAJ8.5CA 8.5 9.44 10.40 1 14.4 27.8 20 SMAJ9.0A SMAJ9.0CA 9.0 10.00 11.10 1 15.4 26.0 10 SMAJ10A SMAJ10CA 10 11.10 12.30 1 17.0 23.5 5 SMAJ11A SMAJ11CA 11 12.20 13.50 1 18.2 22.0 5 SMAJ12A SMAJ12CA 12 13.30 14.7 1 19.9 20.1 5 SMAJ13A SMAJ13CA 13 14.40 15.90 1 21.5 18.6 1 SMAJ14A SMAJ14CA 14 15.60 17.20 1 23.2 17.2 1 SMAJ15A SMAJ15CA 15 16.70 18.50 1 24.4 16.4 1 SMAJ16A SMAJ16CA 16 17.80 19.70 1 26.0 15.4 1 SMAJ17A SMAJ17CA 17 18.90 20.90 1 27.6 14.5 1 SMAJ18A SMAJ18CA 18 20.00 22.10 1 29.2 13.7 1 SMAJ20A SMAJ20CA 20 22.20 24.50 1 32.4 12.3 1 SMAJ22A SMAJ22CA 22 24.40 26.90 1 35.5 11.3 1 SMAJ24A SMAJ24CA 24 26.70 29.50 1 38.9 10.3 1 SMAJ26A SMAJ26CA 26 28.90 31.90 1 42.1 9.5 1 SMAJ28A SMAJ28CA 28 31.10 34.40 1 45.4 8.8 1 SMAJ30A SMAJ30CA 30 33.30 36.80 1 48.4 8.3 1 SMAJ33A SMAJ33CA 33 36.70 40.60 1 53.3 7.5 1 SMAJ36A SMAJ36CA 36 40.00 44.20 1 58.1 6.9 1 SMAJ40A SMAJ40CA 40 44.40 49.10 1 64.5 6.2 1 SMAJ××A(CA) Electrical Characteristics (Cont.) Part Number UNI-POLAR BI-POLAR Reverse Stand off Voltage VRWM Breakdown Voltage VBR(Volts)@IT Test IT Maximum Clamping Voltage Vc@IPP Maximum PeakPulse Current Ipp Maximum Reverse Leakage IR@VRWM Current (Volts) MIN MAX (mA) (Volts) (Amps) (μA) SMAJ43A SMAJ43CA 43 47.80 52.80 1 69.4 5.8 1 SMAJ45A SMAJ45CA 45 50.00 55.30 1 72.7 5.5 1 SMAJ48A SMAJ48CA 48 53.30 58.90 1 77.4 5.2 1 SMAJ51A SMAJ51CA 51 56.70 62.70 1 82.4 4.9 1 SMAJ54A SMAJ54CA 54 60.00 66.30 1 87.1 4.6 1 SMAJ58A SMAJ58CA 58 64.40 71.20 1 93.6 4.3 1 SMAJ60A SMAJ60CA 60 66.70 73.70 1 96.8 4.1 1 SMAJ64A SMAJ64CA 64 71.10 78.60 1 103 3.9 1 SMAJ70A SMAJ70CA 70 77.80 86.00 1 113 3.5 1 SMAJ75A SMAJ75CA 75 83.30 92.10 1 121 3.3 1 SMAJ78A SMAJ78CA 78 86.70 95.80 1 126 3.2 1 SMAJ85A SMAJ85CA 85 94.40 104 1 137 2.9 1 SMAJ90A SMAJ90CA 90 100 111 1 146 2.7 1 SMAJ100A SMAJ100CA 100 111 123 1 162 2.5 1 SMAJ110A SMAJ110CA 110 122 135 1 177 2.3 1 SMAJ120A SMAJ120CA 120 133 147 1 193 2.0 1 SMAJ130A SMAJ130CA 130 144 159 1 209 1.9 1 SMAJ150A SMAJ150CA 150 167 185 1 243 1.6 1 SMAJ160A SMAJ160CA 160 178 197 1 259 1.5 1 SMAJ170A SMAJ170CA 170 189 209 1 275 1.4 1 SMAJ188A SMAJ188CA 188 209 231 1 328 1.2 1 3 SMAJ××A(CA) Typical Characteristics Figure 1: Peak Pulse Power Rating Curve Figure 2: Pulse Derating Curve PPPM – Peak Pulse Power - KW 100 Percent of Rated Power or Ipp 110 10 600W 10/1000µs Waveform 1 100 0.1 0.1 1 10 100 1000 90 80 70 60 50 40 30 20 10 0 0 10,000 25 td – Pulse Width - µs Cj – Junction Capacitance ( pF) IppM Percent IPPM /2– Half Value 50 td – Pulse Width 10/1000µs Waveform as defined by R.E.A 0 0 1.0 150 2.0 t - Time (ms) 3.0 Bidirectional VR=0V Unidirectional VR=0V 1000 Unidirectional @VRWM 100 Bidirectional @VRWM 10 4.0 1 10 100 1000 VBR –Reverse Breakdown Voltage (V) Figure 5: Steady State Power Dissipation Derating Curve Figure 6: Maximum Non-Repetitive Forward Surge Current Only Unidirectional 180 5.5 5.0 4.5 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 0 25 50 75 100 125 150 Peak Forward Surge Current IFSM (A) Steady State Power Dissipation PM(AV) ( W) 125 10000 IPPM – Peak Value 100 100 Figure 4: Typical Junction Capacitance Tj =25℃ Pulse Width(td ) is defined as the point where the peak current decays to 50% of IPPM tr =10µs– Rise Time 75 Ambient Temperature - TA (℃) Figure 3: Pulse Waveform 150 50 160 140 120 100 80 60 40 20 0 1 Ambient Temperature - TA (℃) 10 Number of Cycles at 60HZ 4 100 SMAJ××A(CA) Outline Drawing – SMAJ(DO-214AC) Ref.(mm) Millimeters Min. Max. A 1.980 2.290 A1 - 0.203 B 1.250 1.650 E 3.990 4.500 E1 0.152 0.305 D 2.540 2.790 L 0.780 1.520 5
SMAJ15CA
1. 物料型号:SMAJ××A(CA),其中“××”代表不同的额定电压值。
2. 器件简介: - 400瓦特峰值脉冲功率(10/1000微秒)。 - 单向和双向保护。 - 快速响应时间:典型值小于1皮秒。 - 出色的钳位能力。 - 玻璃钝化结。 - 内置应力释放。 - 低电感。 - 低轮廓封装。
3. 引脚分配:SMA(JEDEC DO-214AC)封装,高温焊接:260℃/20秒在终端。
4. 参数特性: - 机械特性:JEDEC DO-214AC(SMAJ)封装,UL 94V-0阻燃等级,标记代码,EIA 481胶带和卷轴包装,符合RoHS/WEEE。 - 应用领域:1/O接口、电源线、汽车和电信、计算机与消费电子、工业电子。
5. 功能详解: - 绝对最大额定值:包括峰值脉冲功率、峰值脉冲电流、峰值正向浪涌电流、无限热沉上的功率耗散、工作结温范围、存储温度范围等。
6. 应用信息:适用于1/O接口、电源线、汽车和电信、计算机与消费电子、工业电子等领域。
7. 封装信息:提供了SMAJ(DO-214AC)的外形图和尺寸参考。
SMAJ15CA 价格&库存
很抱歉,暂时无法提供与“SMAJ15CA”相匹配的价格&库存,您可以联系我们找货
