SMAJ5.0CA
SMAJ5.0CA
    SINO-IC(光宇睿芯)
    SMA(DO-214AC)
    双向TVS 5V截止 43.5A峰值脉冲
SMAJ5.0CA 数据手册
SHANGHAI MARCH 2008 MICROELECTRONICS CO., LTD. SMAJ Seires Surface Mount TVS Revision:B Features Mechanical Data z For surface mounted application in order Case: JESEC DO214AC. Molded plastic over glass to optimize board space passivated junction z Low profile package Polarity: Color band denoted positive end z Built-in strain relief except Bidirectional z Glass passivated junction z Low inductance z Excellent clamping capability z Fast response time: typically less than 1.0ps z from 0 Vllts to VBR (cathode) for unidirectional types Typical IR less than 1 μ A above 10V z Absolute Maximum Ratings @ 25°C Unless Otherwise Specified Parameter Peak Pulse Power Dissipation on 10/1000 Symbol μ s Value Units PPPM 400 W PM(AV) See Table 1 A IFSM 40 A TJ, TSTG -55 to 150 °C waveform (Note 1,2, FIG,1) Peak Pulse Current of on 101000 μ s waveform ( Note 1, FIG,3) Peak Forward Surge Current,8.3ms Single Half Sine-Wave Superimposed on Rated Load,(JEDEC Method)(Note 2,3) Operating Junction and Storage Temperature Range Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2. 2. Mounted on 5.0mm x 5.0mm (0.03mm thick) Copper Pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulse per minutes maximum. ShangHai Sino-IC Microelectronics Co., Ltd. 1. Electrical Characteristics Per Line @ 25°C Unless Otherwise Specified PART NUMBER V(BR)@IT VRWM (V) min max (V) (V) IT VC@ IPP IPP (mA) (V) (A) IR@ VRWM ( μ A) UNI-POLAR BI-POLAR SMAJ5.0A SMAJ5.0CA 5.0 6.40 7.25 10 9.2 43.5 800 SMAJ6.0A SMAJ6.0CA 6.0 6.67 7.67 10 10.3 38.8 800 SMAJ6.5A SMAJ6.5CA 6.5 7.22 7.98 10 11.2 35.7 500 SMAJ7.0A SMAJ7.0CA 7.0 7.78 8.95 10 12.0 33.3 200 SMAJ7.5A SMAJ7.5CA 7.5 8.33 9.58 1 12.9 31.0 100 SMAJ8.0A SMAJ8.0CA 8.0 8.89 10.23 1 13.6 29.4 50 SMAJ8.5A SMAJ8.5CA 8.5 9.44 10.82 1 14.4 27.7 20 SMAJ9.0A SMAJ9.0CA 9.0 10.00 11.50 1 15.4 26.0 10 SMAJ10A SMAJ10CA 10 11.10 12.80 1 17.0 23.5 5 SMAJ11A SMAJ11CA 11 12.20 14.00 1 18.2 22.0 5 SMAJ12A SMAJ12CA 12 13.30 15.30 1 19.9 20.1 5 SMAJ13A SMAJ13CA 13 14.40 16.50 1 21.5 18.6 5 SMAJ14A SMAJ14CA 14 15.60 17.90 1 23.2 17.2 5 SMAJ15A SMAJ15CA 15 16.70 18.50 1.0 24.4 16.4 5 SMAJ16A SMAJ16CA 16 17.80 19.70 1.0 26.0 15.4 5 SMAJ17A SMAJ17CA 17 18.90 20.90 1.0 27.6 14.5 5 SMAJ18A SMAJ18CA 18 20.00 22.10 1.0 29.2 13.7 5 SMAJ20A SMAJ20CA 20 22.20 24.50 1.0 32.4 12.3 5 SMAJ22A SMAJ22CA 22 24.40 26.90 1.0 35.5 11.3 5 SMAJ24A SMAJ24CA 24 26.70 29.50 1.0 38.9 10.3 5 SMAJ26A SMAJ26CA 26 28.90 31.90 1.0 42.1 9.5 5 SMAJ28A SMAJ28CA 28 31.10 34.40 1.0 45.4 8.8 5 SMAJ30A SMAJ30CA 30 33.30 36.80 1.0 48.4 8.3 5 SMAJ33A SMAJ33CA 33 36.70 40.60 1.0 53.3 7.5 5 SMAJ36A SMAJ36CA 36 40.00 44.20 1.0 58.1 6.9 5 SMAJ40A SMAJ40CA 40 44.40 49.10 1.0 64.5 6.2 5 SMAJ43A SMAJ43CA 43 47.80 52.80 1.0 69.4 5.8 5 SMAJ45A SMAJ45CA 45 50.00 55.30 1.0 72.7 5.5 5 SMAJ48A SMAJ48CA 48 53.30 58.90 1.0 77.4 5.2 5 SMAJ51A SMAJ51CA 51 56.70 62.70 1.0 82.4 4.9 5 SMAJ54A SMAJ54CA 54 60.00 66.30 1.0 87.1 4.6 5 SMAJ58A SMAJ58CA 58 64.40 71.20 1.0 93.6 4.3 5 SMAJ60A SMAJ60CA 60 66.70 73.70 1.0 96.8 4.1 5 SMAJ64A SMAJ64CA 64 71.10 78.60 1.0 103 3.9 5 SMAJ70A SMAJ70CA 70 77.80 86.00 1.0 113 3.5 5 SMAJ75A SMAJ75CA 75 83.30 92.10 1.0 121 3.3 5 SMAJ78A SMAJ78CA 78 86.70 95.80 1.0 126 3.2 5 SMAJ85A SMAJ85CA 85 94 104 1.0 137 2.9 5 SMAJ90A SMAJ90CA 90 100 111 1.0 146 2.7 5 SMAJ100A SMAJ100CA 100 111 123 1.0 162 2.5 5 SMAJ110A SMAJ110CA 110 122 135 1.0 177 2.3 5 SMAJ120A SMAJ120CA 120 133 147 1.0 193 2.0 5 ShangHai Sino-IC Microelectronics Co., Ltd. 2. Rating And Characteristic Curves@ 25°C Unless Otherwise Specified Fig.1 Peak Pulse Power Rating Curve Fig.3 Fig.5 Pulse Waveform Steady State Power Derating Curve ShangHai Sino-IC Microelectronics Co., Ltd. Fig.2 Fig.4 Power Derating Curve Maximum Non-Repetitive Forward Surge Current Uni-Directional Only Fig.6 Capacitance 3. PACKAGE DIMENSIONS (DO-214AC) The SINO-IC logo is a registered trademark of ShangHai Sino-IC Microelectronics Co., Ltd. © 2005 SINO-IC – Printed in China – All rights reserved. SHANGHAI SINO-IC MICROELECTRONICS CO., LTD Add: Building 3, Room 3401-03, No.200 Zhangheng Road, ZhangJiang Hi-Tech Park, Pudong, Shanghai 201203, China Phone: +86-21-33932402 33932403 33932405 33933508 33933608 Fax: +86-21-33932401 Email:szrxw002@126.com Website: http://www.sino-ic.net ShangHai Sino-IC Microelectronics Co., Ltd. 4.
SMAJ5.0CA 价格&库存
很抱歉,暂时无法提供与“SMAJ5.0CA”相匹配的价格&库存,您可以联系我们找货
