SMBJ Series
Rev.B Sep.-2023
DATA SHEET
Descriptions
表面贴装瞬态电压抑制器功率:600W,反向浪涌电压:5.0V~440V,SMB 封装。
Surface mount transient voltage suppressor power 600 watts,Stand-Off Voltage:5.0V~440V ,SMB
package.
特征
/ Features
玻璃钝化,低电感,适用表面贴装,无卤产品。
Glass passivated junction, Low inductance, For surface mounted applications,HF Product.
用途
Applications
一般用途。
General purpose.
内部等效电路
/ Equivalent Circuit
引脚排列
/ Pinning
印章代码
/ Marking
见印章说明。
See Marking Instructions.
http://www.fsbrec.com
1/9
SMBJ Series
Rev.B Sep.-2023
极限参数
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
参数
Parameter
符号
Symbol
数值
Rating
单位
Unit
PPPM
600
W
100
A
IPPM
see Table 1
A
CJ
390
pF
Contact
VESD1
±30
KV
Air
VESD2
±30
KV
RθJA
100
℃/W
Tj, Tstg
-65 ~ +150
Peak Pulse Power Dissipation on 10/1000 s waveform
( Note1,Note2, Fig.1).
Peak Forward Surge Current,8.3ms Single Half Sine-Wave
Superimposed on Rated Load, (JEDEC Method) (Note 3,Fig4).
Peak Pulse Current on 10/1000 us waveform (Note 1, Fig 3)
Typical Junction capacitance at VR=4V, f=1MHz
IFSM
(UNI)
ESD Voltage per IEC6100-4-2
Typical Thermal Resistance Junction to Ambient(Note 2)
Operating Junction Temperature and Storage Temperature
Range
Note:
1. Non-repetitive current pulse, per Fig.3 and derated above TA = 25°C per Fig. 2.
2. Mounted on 5 mm2 (0.13mm thick) land areas.
3. Measured on 8.3ms,single half sine-wave or equivalent square wave,duty cycle=4 pulses per minute maximum
4. Peak pulse power waveform is 10/1000μS.
2/9
SMBJ Series
Rev.B Sep.-2023
电性能参数
DATA SHEET
/ Electrical Characteristics(Ta=25℃)
Reverse
Stand-off
Voltage
Type
Breakdown
Voltage
Test
Current
Reverse
Leakage
Max.
Clamp
Voltage
Peak
Pulse
Current
Package
IT
IR @ VRRM
VC @ IPP
IPP
SMB
Device Marking
Ccode
VBR @ IT
VRRM
Min
Max
UNI
BI
V
V
V
mA
uA
V
A
UNI
BI
SMBJ5.0A
SMBJ5.0CA
5
6.4
7
10
800
9.2
65.3
KE
AE
SMBJ6.0A
SMBJ6.0CA
6
6.67
7.37
10
800
10.3
58.3
KG
AG
SMBJ6.5A
SMBJ6.5CA
6.5
7.22
7.98
10
500
11.2
53.6
KK
AK
SMBJ7.0A
SMBJ7.0CA
7
7.78
8.6
10
200
12.0
KM
AM
SMBJ7.5A
SMBJ7.5CA
7.5
8.33
9.21
1
100
12.9
46.6
KP
AP
SMBJ8.0A
SMBJ8.0CA
8
8.89
9.83
1
50
13.6
44.2
KR
AR
SMBJ8.5A
SMBJ8.5CA
8.5
9.44
10.4
1
41.7
KT
AT
SMBJ9.0A
SMBJ9.0CA
9
10
11.1
1
10
15.4
39.0
KV
AV
SMBJ10A
SMBJ10CA
10
11.1
12.3
1
5
17.0
35.3
KX
AX
SMBJ11A
SMBJ11CA
11
12.2
13.5
1
1
18.2
33.0
KZ
AZ
SMBJ12A
SMBJ12CA
12
13.3
14.7
1
1
19.9
30.2
LE
BE
SMBJ13A
SMBJ13CA
13
14.4
15.9
1
1
21.5
28.0
LG
BG
SMBJ14A
SMBJ14CA
14
15.6
17.2
1
1
23.2
25.9
LK
BK
SMBJ15A
SMBJ15CA
15
16.7
18.5
1
1
24.4
24.6
LM
BM
SMBJ16A
SMBJ16CA
16
17.8
19.7
1
1
26.0
23.1
LP
BP
SMBJ17A
SMBJ17CA
17
18.9
20.9
1
1
27.6
21.8
LR
BR
SMBJ18A
SMBJ18CA
18
1
1
29.2
20.6
LT
BT
SMBJ20A
SMBJ20CA
24.5
1
1
32.4
18.6
LV
BV
SMBJ22A
SMBJ22CA
22
24.4
26.9
1
1
35.5
16.9
LX
BX
SMBJ24A
SMBJ24CA
24
26.7
29.5
1
1
38.9
15.5
LZ
BZ
SMBJ26A
SMBJ26CA
26
28.9
31.9
1
1
42.1
14.3
ME
CE
SMBJ28A
SMBJ28CA
28
31.1
34.4
1
1
45.4
13.3
MG
CG
SMBJ30A
SMBJ30CA
30
33.3
36.8
1
1
48.4
12.4
MK
CK
SMBJ33A
SMBJ33CA
33
36.7
40.6
1
1
53.3
11.3
MM
CM
SMBJ36A
SMBJ36CA
36
40
44.2
1
1
58.1
10.4
MP
CP
SMBJ40A
SMBJ40CA
40
44.4
49.1
1
1
64.5
9.3
MR
CR
SMBJ43A
SMBJ43CA
43
47.8
52.8
1
1
69.4
8.7
MT
CT
50.0
3/9
SMBJ Series
Rev.B Sep.-2023
电性能参数
DATA SHEET
Reverse
Stand-off
Voltage
Type
Breakdown
Voltage
Test
Current
Reverse
Leakage
Max.
Clamp
Voltage
Peak
Pulse
Current
IT
IR @
VRRM
VC @ IPP
IPP
VBR @ IT
VRRM
Min
Max
Package
SMB
Device Marking
Ccode
UNI
BI
UNI
BI
V
V
V
mA
uA
V
A
SMBJ45A
SMBJ45CA
45
50
55.3
1
1
72.7
8.3
MV
CV
SMBJ48A
SMBJ48CA
48
53.3
58.9
1
1
77.4
7.8
MX
CX
SMBJ51A
SMBJ51CA
51
56.7
62.7
1
1
82.4
7.3
MZ
CZ
SMBJ54A
SMBJ54CA
54
60
66.3
1
1
87.1
6.9
NE
DE
SMBJ58A
SMBJ58CA
58
64.4
71.2
1
1
93.6
6.5
NG
DG
SMBJ60A
SMBJ60CA
60
66.7
73.7
1
1
96.8
6.2
NK
DK
SMBJ64A
SMBJ64CA
64
71.1
78.6
1
1
103.0
5.9
NM
DM
SMBJ70A
SMBJ70CA
70
77.8
86
1
1
113.0
5.3
NP
DP
SMBJ75A
SMBJ75CA
75
83.3
92.1
1
1
121.0
5.0
NR
DR
SMBJ78A
SMBJ78CA
78
86.7
95.8
1
1
126.0
4.8
NT
DT
SMBJ85A
SMBJ85CA
85
94.4
104
1
1
137.0
4.4
NV
DV
SMBJ90A
SMBJ90CA
90
100
111
1
1
146.0
4.1
NX
DX
SMBJ100A
SMBJ100CA
100
111
123
1
1
162.0
3.7
NZ
DZ
SMBJ110A
SMBJ110CA
110
122
135
1
1
177.0
3.4
PE
EE
SMBJ120A
SMBJ120CA
120
133
147
1
1
193.0
3.1
PG
EG
SMBJ130A
SMBJ130CA
130
144
159
1
1
209.0
2.9
PK
EK
SMBJ150A
SMBJ150CA
150
167
185
1
1
243.0
2.5
PM
EM
SMBJ160A
SMBJ160CA
160
178
197
1
1
259.0
2.3
PP
EP
SMBJ170A
SMBJ170CA
170
189
209
1
1
275.0
2.2
PR
ER
SMBJ180A
SMBJ180CA
180
201
222
1
1
292.0
2.1
PT
ET
SMBJ188A
SMBJ188CA
188
209
231
1
1
304.0
2.0
PB
EB
SMBJ200A
SMBJ200CA
200
224
247
1
1
324.0
1.9
PV
EV
SMBJ220A
SMBJ220CA
220
246
272
1
1
356.0
1.7
PX
EX
SMBJ250A
SMBJ250CA
250
279
309
1
1
405.0
1.5
PZ
EZ
SMBJ300A*
SMBJ300CA*
300
335
371
1
1
486.0
1.3
QE
FE
SMBJ350A*
SMBJ350CA*
350
391
432
1
1
567.0
1.1
QG
FG
SMBJ400A*
SMBJ400CA*
400
447
494
1
1
648.0
0.6
QK
FK
SMBJ440A*
SMBJ440CA*
440
492
543
1
1
713.0
0.9
QM
FM
4/9
SMBJ Series
Rev.B Sep.-2023
电参数曲线图
DATA SHEET
/ Electrical Characteristic Curve
5/9
SMBJ Series
Rev.B Sep.-2023
外形尺寸图
DATA SHEET
/ Package Dimensions
6/9
SMBJ Series
Rev.B Sep.-2023
印章说明
DATA SHEET
KE
说明:
KE
为型号代码
: 为生产批号代码,随生产批号变化
Note:
KE
Product Type Code
Lot No. Code, code change with Lot No
7/9
SMBJ Series
Rev.B Sep.-2023
印章说明
DATA SHEET
AE
说明:
AE
: 为型号代码
: 为生产批号代码,随生产批号变化
Note:
AE
Product Type Code
8/9
SMBJ Series
Rev.B Sep.-2023
DATA SHEET
回流焊温度曲线图(无铅)
Temperature Profile for IR Reflow Soldering(Pb-Free)
350
Temperature(℃)
300
245±5℃
250
5±0.5 sec
200
150
60~90 sec
100
50
60
80
100
120
140
160
180
200
220
240
260
280
Time(sec)
说明:
Note:
1、预热温度 150~180℃,时间 60~90sec;
1.Preheating:150~180℃, Time:60~90sec.
2、峰值温度 245±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:245±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件
Resistance to Soldering Heat Test Conditions
温度:260±5℃
包装规格
Time:10±1 sec
/ REEL
Package Type
封装形式
使用说明
Temp.:260±5℃
/ Packaging SPEC.
卷盘包装
SMB
时间:10±1 sec.
Units 包装数量
Dimension
包装尺寸
(unit:mm3)
Units/Reel
只/卷盘
Reels/Inner Box
卷盘/盒
Units/Inner Box
只/盒
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
Reel
Inner Box 盒
Outer Box 箱
3,000
2
6,000
7
42,000
13〞×12
336X336X40
380X335X366
/ Notices
9/9
很抱歉,暂时无法提供与“SMBJ12CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.32221
- 100+0.25472
- 300+0.22097
- 3000+0.19566
- 6000+0.17537
- 9000+0.16523
