ES2DB
ES2DB
    HXY(华轩阳)
    SMB(DO-214AA)
    耐压:200V 电流:2A
ES2DB 数据手册
HXY ES2AB-ES2JB ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR HUAXUANYANG Features z Average Forward Current:IF(AV) =2A z Polarity: Color band denotes cathode Package Marking and Ordering Information Product ID Pack ES2AB-ES2JB SMA * Marking Qty(PCS) * 2000 ES2 SMB :From A-J Maxmim Ratings (Ta=25℃ unless otherwise noted) Item Symbol Unit Test Conditions ES2 AB BB CB DB EB Repetitive Peak Reverse Voltage VRRM V 50 100 150 200 300 Maximum RMS Voltage V RMS V 35 70 Average Forward Current IF(AV) A 60Hz Half-sine wave, Resistance load,Ta=110 ℃ 2.0 Surge(Non-repetitive)Forward Current IFSM A 60Hz Half-sine wave, 1 cycle,Ta=25℃ 50 Operation Junction and Storage Temperature Range TJ,TSTG ℃ Symbol Unit Peak Forward Voltage VF V Maximum reverse recovery time trr ns Peak Reverse Current Thermal Resistance(Typical) Juction Capacitance (Typical) IRRM1 IRRM2 RθJ-A μA ℃/ W RθJ-L Cj pF 400 500 600 105 140 210 280 350 420 -55 ~ +150 Electrcal Charcteristics (Ta=25 ℃unless otherwise specified) Item GB HB JB Test Condition IF =2.0A 0.95 IF=0.5A,IR=1.0A,Irr=0.25A VRM=VRRM ES2 AB BB CB DB EB 1.25 1.7 35 Ta =25℃ 5.0 Ta =125℃ 50 Between junction and ambient 65 Between junction and terminal 18 Measured at 1MHZ and Applied Reverse Voltage of 4.0 V.D.C GB HB JB 26 20 Notes: Thermal resistance from junction to ambient and from junction to lead mounted on P.C.B. with 0.27" x 0.27" (7.0 mm x 7.0 mm) copper pad areas Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY ES2AB-ES2JB ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR HUAXUANYANG Typical Characteristics C U R V E F IG 2 : MAXIUNO-REPTVFWDSGC 50 IFSM(A) IF (A ) F IG .1 : F O R W A R D C U R R E N T D E R A T IN G 2 .0 1 .6 40 1 .2 30 0 .8 20 0 .4 10 0 .0 0 2 5 5 0 7 5 1 0 0 1 2 5 0 T L (℃ ) 1 1 5 0 1 0 ES2A-ES2D F IG .3 : T Y P IC A L F O R W A R D ES2A-ES2D C H A R A C T E R IS T IC S F IG .4 T Y P C A L R E V E R S E C H A R A C T E R IS T IC S IR (u A ) IF (A ) 1 0 Tj=75℃ Tj=125℃ Tj=25℃ 1 1 0 0 NumberOfCycls 1 0 Tj=125℃ Tj=75℃ Tj=25℃ 1 0 .1 0 .0 1 0 .1 0 .0 0 1 0 .0 1 0 .2 0 .4 0 .6 0 .8 1 .0 1 .2 1 .4 V F (V ) Shenzhen HuaXuanYang Electronics CO.,LTD 1 E -4 0 2 0 4 0 6 0 8 0 1 0 0 V R (% ) HXY ES2AB-ES2JB ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR HUAXUANYANG SMB Package Outline Dimensions 0.155(3.94) 0.130(3.30) 0.087 (2.20) 0.071 (1.80) 0.180(4.57) 0.160(4.06) 0.012(0.305) 0.006(0.152) 0.096(2.44) 0.084(2.13) 0.060(1.52) 0.030(0.76) 0.008(0.203)MAX. 0.220(5.59) 0.205(5.21) Dimensions in inches and (millimeters) Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY ES2AB-ES2JB ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR HUAXUANYANG ES2EB-ES2GB ES2EB-ES2GB FIG.5:TYPCALORWDHES FIG.6TYPCALREVSH IF(A) Tj=75℃ Tj=125℃ 1 Tj=125℃ Tj=75℃ Tj=25℃ 10 IR(uA) 10 1 Tj=25℃ 0.1 0.1 0.1 0.1 1E-4 0.1 0 0.46812 20 40 60 80 10 VR(%) VF() ES2HB-ES2JB ES2HB-ES2JB FIG.7:TYPCALORWDHES IF (A ) 1 FIG.8TYPCALREVSH Tj=125℃ 50 IR(uA) Tj=75℃ Tj=125℃ 10 10 Tj=25℃ Tj=75℃ 1 Tj=25℃ 0.1 0.1 0.1 0.1 0.46812 0 VF() Shenzhen HuaXuanYang Electronics CO.,LTD 20 40 60 80 10 VR(%) HXY ES2AB-ES2JB ELECTRONICS CO.,LTD SCHOTTKY RECTIFIER DIODES HUAXUANYANG SMB Package Outline Dimensions 0.155(3.94) 0.130(3.30) 0.087 (2.20) 0.071 (1.80) 0.180(4.57) 0.160(4.06) 0.012(0.305) 0.006(0.152) 0.096(2.44) 0.084(2.13) 0.060(1.52) 0.030(0.76) 0.008(0.203)MAX. 0.220(5.59) 0.205(5.21) Dimensions in inches and (millimeters) Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY ES2AB-ES2JB ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR HUAXUANYANG Attention ■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein in such applications. ■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein. ■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. ■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design. ■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA XUAN YANG ELECTRONICS CO.,LTD. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com
ES2DB 价格&库存
很抱歉,暂时无法提供与“ES2DB”相匹配的价格&库存,您可以联系我们找货
ES2DB
  • 3000+0.05923
库存:360000
