P6SMBXXXA(CA)(MS)
Product specification
P6SMBXXXA(CA)(MS)
Features
Mechanical Data
For surface mounted applications in order to optimize board
Case : JEDEC DO-214AA/SMB molded plastic body
space Low profile package
Terminals : Solderable per MIL-STD-750,Method
Built-in strain relief
Glass passivated junction
2026
Low inductance
Excellent clamping capability
Mounting Position : Any
Polarity : Polarity symbol marking on body
Weight : 0.003 ounce, 0.095 grams
600W peak pulse power capability at 10/1000μswaveform,
Fast response time
Typical IR less than 1μA above 12V
High Temperature soldering: 260℃/ 40 seconds at terminals
Plastic package has underwriters laboratory flammability
repetition rate (duty cycle): 0.01%
Applications
I/O interface
AC/DC power supply
Industrial and Consumer electronic applications.
94V-0
Reference News
PACKAGE OUTLINE
PIN CONFIGURATION
Marking Information
***A
S
Unipolar
J
***C
Bipolar
Copyright© Msksemi Incorporated
www.msksemi.com
P6SMBXXXA(CA)(MS)
Maximum Ratings And Electrical Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Peak Pulse Power Dissipation at TA=25℃ by 10x1000μs waveform
(Fig.1) (Note 1), (Note 2)
Power Dissipation on infinite heat sink at TA=50℃
P PP M
600
Watt s
P M( AV )
5.0
Watt s
Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3)
I FSM
100
Amps
Maximum Instantaneous Forward Voltage at 50A for Unidirectionalonly (Note 4)
VF
3.5V/5.0
V
Operating Junction and Storage Temperature Range
T J ,T ST G
-6 5 to +1 5 0
Typical Thermal Resistance Junction to Lead
R θ JL
℃ /W
Typical Thermal Resistance Junction to Ambient
R θ JA
100
℃ /W
NOTES:
1.Non-repetitive current pulse , per Fig. 3 and derated above TA = 25℃per Fig. 2.
2.Mounted on copper pad area of 0.2x0.2” (5.0 x 5.0mm) to each terminal.
3.Measured on 8.3ms single half sine wave or equivalent square
wave for unidirectional device only,duty cycle=4 per minute maximum.
4.VF
很抱歉,暂时无法提供与“P6SMB100A(MS)”相匹配的价格&库存,您可以联系我们找货
