SMBJ180CA
SMBJ180CA
    LIOWN(里阳)
    SMB(DO-214AA)
    双向TVS 180V截止 峰值浪涌电流:2.1A
SMBJ180CA 数据手册
TVS Diodes Datasheet SMBJ Series Surface Mount – 600W Description The SMBJ series is designed specifically to protect sensitive electronic equipment from voltage transients induced by lightning and other transient voltage events. For surface mounted applications in order to optimize board space. SMB Features Additional Information Maximum Ratings and Characteristics (TA=25℃) Rating Symbol Value Peak pulse power dissipation at 10/1000μs waveform(Note1, Note2, Fig.1) PPPM 600W Peak pulse current of at 10/1000 μs waveform (Note 1, Fig.3) IPPM See Table(A) Steady state power dissipation at TA=50℃ (Fig.5) PM(AV) 5.0W Maximum Instantaneous Forward Voltage at 50A for Unidirectional Only VF 3.5V/5.0V Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Ranges Typical thermal resistance junction to lead Typical thermal resistance junction to ambient  Halogen free and RoHS compliant  Low profile package  Built-in strain relief design  Low inductance  Excellent clamping capability  600W peak pulse power capability at 10/1000 μ s waveform, repetition rate (duty cycle): 0.01%  Fast response time  Typical IR less than 1μA above 10V devices  Peak 260 ℃ high temperature Reflow Soldering withstanding  Meet MSL level1, per J-STD-020  IEC-61000-4-2 ESD 30kV(Air), 30kV (Contact)  Unit Weight: 0.10g Applications TVS components are ideal for the protection of I/O Interfaces, VCC bus and other vulnerable circuits used in telecom, computer, Industrial and consumer electronic IFSM 60A TJ、TSTG -55℃ to +150℃ RθJL 20℃/W RθJA 100℃/W applications. Functional Diagram Notes: 1. Non-repetitive current pulse, per Fig.3 and derating above TA=25℃ per Fig.2. 2. Each terminal is surface Mounted on the 5.0mm×5.0mm(0.03mm thick) copper pads. 3. 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minutes maximum. 4. VF
SMBJ180CA 价格&库存
很抱歉,暂时无法提供与“SMBJ180CA”相匹配的价格&库存,您可以联系我们找货
