BV-SMBJ58C2H-ES
BV-SMBJ58C2H-ES
    ELECSUPER(静芯微)
    SMB(DO-214AA)
    极性:双向 单路路保护 反向关断电压(典型值):58V(MAX) 击穿电压(最小值):62.4V 钳位电压:85V 10/700US 4KV
BV-SMBJ58C2H-ES 数据手册
BV-SMBJ58C2H-ES Rev-1.1 www.elecsuper.com SuperTVS –3500W Transient Voltage Suppressor 1. Features For surface mounted applications in order  Fast response time to optimize board space  Typical IR less than 1μA above 58V  Low profile package  Plastic package has underwriters laboratory  Built-in strain relief  Glass passivated junction  Low inductance  Excellent clamping capability  flammability 94V-0 High Temperature soldering: 260℃/10  seconds at terminals 2. Mechanical Data  Low clamping voltage  Small package: SMB  IEC 61000-4-2(ESD)±15KV(air)  Moisture sensitivity level:Level 1  Max surge capability:4KV@10/700us  DC-48V ±8KV(contact) 3. Application Information  POE 4. Ordering Information Part Number BV-SMBJ58C2H-E S Packag e Marking Materia l Packin g Quantit y per reel SMB BV-SMBJ58C2H-E S /LOT Haloge n free Tape & Reel 3,000 PCS Flammabilit y Rating Reel Sizes UL 94V-0 13 Inche s Table-1 Ordering Information Copyright© ElecSuper Incorporated Contact Us 1 / 5 BV-SMBJ58C2H-ES Rev-1.1 www.elecsuper.com 5. Outline and Circuit Diagram Outline Circuit Diagram LOT ES58C2H 6. Maximum Ratings and Characteristics Rating Symbol Value Units Peak pulse power dissipation at 10/1000us waveform PPP 3500 W Peak pulse current of at 10/1000us waveform IPP 40 A Peak surge voltage on 10/700us waveform VPP 4000 V ESD (IEC61000-4-2 air discharge) @25℃ VESD ±15 kV ESD (IEC61000-4-2 contact discharge) @25℃ VESD ±8 kV TJ, TSTG -55 to 150 ℃ Operating junction and Storage Temperature Range Table-2 Absolute Maximum rating 7. Electrical Characteristics At TA = 25℃ unless otherwise noted Part Number VR IR@VR VBR@IT IT Bi-polar (V) μA min(V) max(V) mA max(V) Max (V) BV-SMBJ58C2H-ES 58 1 1 85 85 62.4 Table-3 71.2 VC@10/700μs1 VC@10/1000μs Electrical Characteristics Note: 1:Ri=40Ω Copyright© ElecSuper Incorporated Contact Us 2 / 5 BV-SMBJ58C2H-ES Symbol Rev-1.1 www.elecsuper.com Description VC Clamping Voltage Ipp Surge Waveform VR Stand-off Voltage VBR Breakdown Voltage IR Reverse Leakage Current It Test Current Copyright© ElecSuper Incorporated IPP VC VBR VR IR It IR It VR VBR VC V IPP Contact Us 3 / 5 BV-SMBJ58C2H-ES Rev-1.1 www.elecsuper.com 8. Dimension (SMB/DO-214AA) H A A1 B D C G F REF Millimeters MIN MAX A 2.15 2.45 A1 2.10 B C REF Millimeters MIN MAX D 1.90 2.10 2.30 F 0.90 1.30 3.40 3.80 G 0.00 0.20 4.25 4.65 H 5.10 5.50 REF mm A 5.45 B 2.45 C 2.15 Recommended Soldering Pad Copyright© ElecSuper Incorporated Contact Us 4 / 5 BV-SMBJ58C2H-ES Rev-1.1 www.elecsuper.com DISCLAIMER ELECSUPER SUPERTVS PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products. Copyright© ElecSuper Incorporated Contact Us 5 / 5
BV-SMBJ58C2H-ES 价格&库存
很抱歉,暂时无法提供与“BV-SMBJ58C2H-ES”相匹配的价格&库存,您可以联系我们找货
