� �D�
宏迦橙
SMBJ SERIES
600W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSORS
Description
Transient Voltage Suppressors (TVS) Data Sheet
www.ichjc.com
Breakdown Voltage
3.3 to 440 V
Peak Pulse Power
600 W
The SMBJ series is designed specifically to protect sensitive electronic
equipment from voltage transients induced by lightning and other transient
voltage events
Features
•For surface mounted applications in order to optimize board space
•Low leakage
DO-214AA(SMB)
•Glass passivated junction
•Low inductance
•Excellent clamping capability
•600W peak pulse power capability at 10/1000μs waveform
•Fast response time
•Typical IR less than 5μA above 12V
•High Temperature soldering: 260℃ /40 seconds at terminals
•Typical maximum temperature coefficient ΔVBR = 0.1% ×VBR@25℃ ×ΔT
•Plastic package has Underwriters Laboratory Flammability 94V-0
•Matte tin lead–free Plated
•Halogen free and RoHS compliant
•Typical failure mode is short from over-specified voltage or current
•Whisker test is conducted based on JEDEC JESD201A per its table 4a and 4c
•IEC 61000-4-2 ESD 30KV(Air),30KV(contact)
Applications
TVS devices are ideal for the protection of I/O interfaces, VCC bus and other vulnerable circuits used in Telecom, Computer,
Industrial and Consumer electronic applications
Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
Peak Pulse Power Dissipation with a 10/1000µs waveform (Fig.1)(Note 1), (Note 2)
SYMBOL
VALUE
SYMBOL
IPP
See Next Table
A
IFSM
100
PPPM
Peak Pulse Current with a 10/1000μs waveform.(Note1,Fig.3)
Power Dissipation on Infinite Heat Sink at TL=75° C
PM(AV)
Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3)
Maximum Instantaneous Forward Voltage at 25A for Unidirectional Only(Note 4)
Operating junction and Storage Temperature Range
Typical thermal resistance junction to lead
W
3.5/5.0
V
-55 to +150
RθJ-A
100
Note :
(1) Non-repetitive current pulse, per Fig. 3 and derated above Ta = 25℃ per Fig. 2.
(2) Mounted on 5.0mm x 5.0mm (0.03mm thick) Copper Pads to each terminal.
(3) 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum.
(4) VF
很抱歉,暂时无法提供与“SMBJ18CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.37142
- 50+0.30532
- 150+0.27227
- 500+0.24754
- 3000+0.20391
- 6000+0.19397
