P6SMB6.8CA
P6SMB6.8CA
    REALCHIP(正芯)
    SMB(DO-214AA)
P6SMB6.8CA 数据手册
RoHS P6SMB SERIES  COMPLIANT Surface Mount Transient Voltage Suppressors Uni-directional Features ● For surface mounted applications ● Low-profile package ● Ideal for automated placement ● Available in Unidirectional and Bidirectional ● 600 W peak pulse power capability with a 10/1000 μs waveform ● Low incremental surge resistance, excellent clamping capability ● Very fast response time ● High temperature soldering guaranteed: 260 °C/10 s at terminals Bi-directional ● Meets MSL level 1 ● Component in accordance to RoHS Typical Applications Use in sensitive electronics protection against voltage transients induced by inductive load switching and lighting on ICs, MOSFET, signal lines of sensor units for consumer, computer, industrial, telecommunication. Mechanical Data ● Package: DO-214AA (SMB) Molding compound meets UL 94 V-0 flammability rating, RoHS-compliant, halogen-free ● Terminals: Matte tin plated leads, solderable per J-STD-002B and JESD22-B102D ● Polarity: For uni-directional types the band denotes cathode end, no marking on bi-directional types ■Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT Max Peak power dissipation, with a 10/1000us waveform (1) (2) (Fig.1) PPPM W 600 Peak pulse current, with a 10/1000us waveform(1) IPPM A See Next Table Peak forward surge current, 8.3 ms single half sine-wave unidirectional only (2) IFSM A 100 TJ,TSTG ℃ -55 to +150 SYMBOL UNIT VALUE VF V 3.5 Operating junction and storage temperature range ■Electrical Characteristics(Ta=25℃ Unless otherwise specified) PARAMETER Maximum instantaneous forward voltage @ at 50A for unidirectional only (3) 1/5 P6SMB SERIES  ■Thermal Characteristics (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT Conditions VALUE RθJL ℃/W junction to lead 20 RθJA ℃/W junction to ambient 100 Thermal resistance(Typical) Notes: (1) Non-repetitive current pulse, per Fig. 3 and derated above TA= 25℃per Fig.2. (2) Mounted on 0.2 x 0.2" (5.0 x 5.0 mm) copper pads to each terminal. (3) VF
P6SMB6.8CA 价格&库存
很抱歉,暂时无法提供与“P6SMB6.8CA”相匹配的价格&库存,您可以联系我们找货
