SMBJ33CA
SMBJ33CA
    HONGJIACHENG(宏嘉诚)
    SMB(DO-214AA)
    ESD抑制器/TVS二极管 双向 33V 11.26A 600W SMB(DO-214AA)
SMBJ33CA 数据手册
� �D� 宏迦橙 SMBJ SERIES 600W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSORS Description Transient Voltage Suppressors (TVS) Data Sheet www.ichjc.com Breakdown Voltage 3.3 to 440 V Peak Pulse Power 600 W The SMBJ series is designed specifically to protect sensitive electronic equipment from voltage transients induced by lightning and other transient voltage events Features •For surface mounted applications in order to optimize board space •Low leakage DO-214AA(SMB) •Glass passivated junction •Low inductance •Excellent clamping capability •600W peak pulse power capability at 10/1000μs waveform •Fast response time •Typical IR less than 5μA above 12V •High Temperature soldering: 260℃ /40 seconds at terminals •Typical maximum temperature coefficient ΔVBR = 0.1% ×VBR@25℃ ×ΔT •Plastic package has Underwriters Laboratory Flammability 94V-0 •Matte tin lead–free Plated •Halogen free and RoHS compliant •Typical failure mode is short from over-specified voltage or current •Whisker test is conducted based on JEDEC JESD201A per its table 4a and 4c •IEC 61000-4-2 ESD 30KV(Air),30KV(contact) Applications TVS devices are ideal for the protection of I/O interfaces, VCC bus and other vulnerable circuits used in Telecom, Computer, Industrial and Consumer electronic applications Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER Peak Pulse Power Dissipation with a 10/1000µs waveform (Fig.1)(Note 1), (Note 2) SYMBOL VALUE SYMBOL IPP See Next Table A IFSM 100 PPPM Peak Pulse Current with a 10/1000μs waveform.(Note1,Fig.3) Power Dissipation on Infinite Heat Sink at TL=75° C PM(AV) Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3) Maximum Instantaneous Forward Voltage at 25A for Unidirectional Only(Note 4) Operating junction and Storage Temperature Range Typical thermal resistance junction to lead W 3.5/5.0 V -55 to +150 RθJ-A 100 Note : (1) Non-repetitive current pulse, per Fig. 3 and derated above Ta = 25℃ per Fig. 2. (2) Mounted on 5.0mm x 5.0mm (0.03mm thick) Copper Pads to each terminal. (3) 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum. (4) VF
SMBJ33CA 价格&库存
很抱歉,暂时无法提供与“SMBJ33CA”相匹配的价格&库存,您可以联系我们找货
SMBJ33CA
    • 1+0.43340
    • 200+0.27940
    • 1500+0.24310
    • 3000+0.21450
    SMBJ33CA
    • 10+0.22475
    • 100+0.21025
    • 500+0.19575
    • 2000+0.17400
    • 5000+0.16675
    • 10000+0.16240
    库存:4820
    SMBJ33CA
    • 10+0.33318
    • 100+0.26784
    • 300+0.23523
    • 3000+0.19710
    • 6000+0.17745
    • 9000+0.16773
    库存:386444
