TVS Diodes Datasheet
SMBJ Series
Surface Mount – 600W
Description
The SMBJ series is designed specifically to protect
sensitive electronic equipment from voltage transients
induced by lightning and other transient voltage events.
For surface mounted applications in order to optimize
board space.
SMB
Features
Additional Information
Maximum Ratings and Characteristics
(TA=25℃)
Rating
Symbol
Value
Peak pulse power dissipation at
10/1000μs waveform(Note1,
Note2, Fig.1)
PPPM
600W
Peak pulse current of at 10/1000
μs waveform (Note 1, Fig.3)
IPPM
See
Table(A)
Steady state power dissipation at
TA=50℃ (Fig.5)
PM(AV)
5.0W
Maximum Instantaneous Forward
Voltage at 50A for Unidirectional
Only
VF
3.5V/5.0V
Peak forward surge current,
8.3ms single half sine-wave
superimposed on rated load,
(JEDEC Method) (Note3, Fig.6)
Operating junction and Storage
Temperature Ranges
Typical thermal resistance
junction to lead
junction to ambient
Halogen free and RoHS compliant
Low profile package
Built-in strain relief design
Low inductance
Excellent clamping capability
600W peak pulse power capability at 10/1000 μ s
waveform, repetition rate (duty cycle): 0.01%
Fast response time
Typical IR less than 1μA above 10V devices
Peak 260 ℃ high temperature Reflow Soldering
withstanding
Meet MSL level1, per J-STD-020
IEC-61000-4-2 ESD 30kV(Air), 30kV (Contact)
Unit Weight: 0.10g
Applications
TVS components are ideal for the protection of I/O
Interfaces, VCC bus and other vulnerable circuits used in
telecom, computer, Industrial and consumer electronic
IFSM
60A
TJ、TSTG
-55℃ to
+150℃
RθJL
20℃/W
RθJA
100℃/W
applications.
Functional Diagram
Notes:
1. Non-repetitive current pulse, per Fig.3 and derating above TA=25℃ per Fig.2.
2. Each terminal is surface Mounted on the 5.0mm×5.0mm(0.03mm thick) copper pads.
3. 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per
minutes maximum.
4. VF
很抱歉,暂时无法提供与“SMBJ8.5A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.15482
- 100+0.12329
- 300+0.10757
- 3000+0.09575
- 6000+0.08630
- 9000+0.08160
