SMBJ51CA
SMBJ51CA
    HXY(华轩阳)
    SMB(DO-214AA)
    TVS 51V截止 7.3A峰值脉冲
SMBJ51CA 数据手册
HUAXUANYANG HXY ELECTRONICS CO.,LTD SMBJ5.0(C)A-SMBJ440(C)A TRANSIENT VOLTAGE SUPPRESSOR Features For surface mounted applications in order to optimize board space Low profile package Built-in strain relief Glass passivated junction Low inductance Excellent clamping capability 600W peak pulse power capability at 10/1000μs waveform, SMB repetition rate (duty cycle): 0.01% Fast response time Typical IR less than 1μA above 10V High Temperature soldering: 260℃/10 seconds at terminals Plastic package has underwriters laboratory flammability 94V-0 Mechanical Data Case : JEDEC DO-214AA/SMB molded plastic body Terminals : Solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Part Number Code SMBJ XXX C A 5% VBR Voltage Tolerance Bidirectional Mounting Position : Any Weight : 0.003 ounce, 0.095 grams Voltage Series Code Standard Packaging: 12mm tape (EIA STD RS-481) Applications I/O interface AC/DC power supply Low frequency signal transmission line (RS232, RS485, etc.) MAXIMUM RATINGS AND CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2, Fig.1) PPPM Minimum 600 W Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table A PM(AV) 5.0 W IFSM 100 A TJ,TSTG -65 to +150 ℃ Typical thermal resistance junction to lead RθJL 20 ℃/W Typical thermal resistance junction to ambient RθJA 100 ℃/W Steady state power dissipation at TA=50℃ (Fig.5) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Range. Notes:1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2. 2. Mounted on 5.0mm×5.0mm (0.03mm thick) copper pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HUAXUANYANG SMBJ5.0(C)A-SMBJ440(C)A HXY ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR Electrical Characteristics (TA=25℃) Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) SMBJ5.0A SMBJ5.0CA KE KE 5.0 6.40~7.00 10 9.2 65.3 800 SMBJ6.0A SMBJ6.0CA KG KG 6.0 6.67~7.37 10 10.3 58.3 800 SMBJ6.5A SMBJ6.5CA KK AK 6.5 7.22~7.98 10 11.2 53.6 500 SMBJ7.0A SMBJ7.0CA KM KM 7.0 7.78~8.60 10 12.0 50.0 200 SMBJ7.5A SMBJ7.5CA KP AP 7.5 8.33~9.21 1 12.9 46.6 100 SMBJ8.0A SMBJ8.0CA KR AR 8.0 8.89~9.83 1 13.6 44.2 50 SMBJ8.5A SMBJ8.5CA KT AT 8.5 9.44~10.40 1 14.4 41.7 20 SMBJ9.0A SMBJ9.0CA KV AV 9.0 10.00~11.10 1 15.4 39.0 10 SMBJ10A SMBJ10CA KX AX 10.0 11.10~12.30 1 17.0 35.3 5 SMBJ11A SMBJ11CA KZ KZ 11.0 12.20~13.50 1 18.2 33.0 1 SMBJ12A SMBJ12CA LE BE 12.0 13.30~14.70 1 19.9 30.2 1 SMBJ13A SMBJ13CA LG LG 13.0 14.40~15.90 1 21.5 28.0 1 SMBJ14A SMBJ14CA LK BK 14.0 15.60~17.20 1 23.2 25.9 1 SMBJ15A SMBJ15CA LM BM 15.0 16.70~18.50 1 24.4 24.6 1 SMBJ16A SMBJ16CA LP LM 16.0 17.80~19.70 1 26.0 23.1 1 SMBJ17A SMBJ17CA LR LR 17.0 18.90~20.90 1 27.6 21.8 1 SMBJ18A SMBJ18CA LT BT 18.0 20.00~22.10 1 29.2 20.6 1 SMBJ20A SMBJ20CA LV LV 20.0 22.20~24.50 1 32.4 18.6 1 SMBJ22A SMBJ22CA LX BX 22.0 24.40~26.90 1 35.5 16.9 1 SMBJ24A SMBJ24CA LZ BZ 24.0 26.70~29.50 1 38.9 15.5 1 Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HUAXUANYANG SMBJ5.0(C)A-SMBJ440(C)A HXY ELECTRONICS CO.,LTD Part Number TRANSIENT VOLTAGE SUPPRESSOR Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) SMBJ26A SMBJ26CA ME CE 26.0 28.90~31.90 1 42.1 14.3 1 SMBJ28A SMBJ28CA MG MG 28.0 31.10~34.40 1 45.4 13.3 1 SMBJ30A SMBJ30CA MK CK 30.0 33.30~36.80 1 48.4 12.4 1 SMBJ33A SMBJ33CA MM CM 33.0 36.70~40.60 1 53.3 11.3 1 SMBJ36A SMBJ36CA MP CP 36.0 40.00~44.20 1 58.1 10.4 1 SMBJ40A SMBJ40CA MR CR 40.0 44.40~49.10 1 64.5 9.3 1 SMBJ43A SMBJ43CA MT CT 43.0 47.80~52.80 1 69.4 8.7 1 SMBJ45A SMBJ45CA MV MV 45.0 50.00~55.30 1 72.7 8.3 1 SMBJ48A SMBJ48CA MX MX 48.0 53.30~58.90 1 77.4 7.8 1 SMBJ51A SMBJ51CA MZ MZ 51.0 56.70~62.70 1 82.4 7.3 1 SMBJ54A SMBJ54CA NE NE 54.0 60.00~66.30 1 87.1 6.9 1 SMBJ58A SMBJ58CA NG NG 58.0 64.40~71.20 1 93.6 6.5 1 SMBJ60A SMBJ60CA NK NK 60.0 66.70~73.70 1 96.8 6.2 1 SMBJ64A SMBJ64CA NM NM 64.0 71.10~78.60 1 103.0 5.9 1 SMBJ70A SMBJ70CA NP NP 70.0 77.80~86.00 1 113.0 5.3 1 SMBJ75A SMBJ75CA NR NR 75.0 83.30~92.10 1 121.0 5.0 1 SMBJ78A SMBJ78CA NT NT 78.0 86.70~95.80 1 126.0 4.8 1 SMBJ85A SMBJ85CA NV NV 85.0 94.40~104.00 1 137.0 4.4 1 SMBJ90A SMBJ90CA NX NX 90.0 100.00~111.00 1 146.0 4.1 1 SMBJ100A SMBJ100CA NZ NZ 100.0 111.00~123.00 1 162.0 3.7 1 SMBJ110A SMBJ110CA PE PE 110.0 122.00~135.00 1 177.0 3.4 1 SMBJ120A SMBJ120CA PG EG 120.0 133.00~147.00 1 193.0 3.1 1 SMBJ130A SMBJ130CA PK PK 130.0 144.00~159.00 1 209.0 2.9 1 SMBJ150A SMBJ150CA PM PM 150.0 167.00~185.00 1 243.0 2.5 1 SMBJ160A SMBJ160CA PP PP 160.0 178.00~197.00 1 259.0 2.3 1 SMBJ170A SMBJ170CA PR PR 170.0 189.00~209.00 1 275.0 2.2 1 SMBJ188A SMBJ188CA PS PS 180.0 201.00~222.00 1 292.0 2.1 1 SMBJ190A SMBJ190CA PA EC 190.0 211.00~233.00 1 308.0 2.0 1 SMBJ200A SMBJ200CA PV EV 200.0 224.00~247.00 1 324.0 1.9 1 SMBJ210A SMBJ210CA PB ED 210.0 237.00~263.00 1 340.0 1.8 1 SMBJ220A SMBJ220CA PX EX 220.0 246.00~272.00 1 356.0 1.7 1 SMBJ250A SMBJ250CA PZ EZ 250.0 279.00~309.00 1 405.0 1.5 1 SMBJ300A SMBJ300CA QE FE 300.0 335.00~371.00 1 486.0 1.3 1 SMBJ350A SMBJ350CA QG FG 350.0 391.00~432.00 1 567.0 1.1 1 SMBJ400A SMBJ400CA QK FK 400.0 447.00~494.00 1 648.0 0.9 1 SMBJ440A SMBJ440CA QM FM 440.0 492.00~543.00 1 713.0 0.9 1 Notes: For bidirectional type having VRWM of 10V and less, the IR limit is double. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HUAXUANYANG SMBJ5.0(C)A-SMBJ440(C)A HXY ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve 100 80 60 40 20 0 0 25 50 75 100 125 150 175 TA-Ambient Temperature (℃) Figure 4. Typical Junction Capacitance Figure 3. Pulse Waveform 150 tr=10µs TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM Peak Value IPPM 100 Half Value IPPM (IPPM/2) 50 10/1000µs Waveform as defined by R.E.A td 0 0 1.0 2.0 3.0 4.0 t-Time (ms) Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional Only PM(AV), Steady State Power Dissipation (W) Figure 5. Steady State Power Dissipation Derating Curve Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HUAXUANYANG SMBJ5.0(C)A-SMBJ440(C)A HXY ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR SMB Package Outline Dimensions 0.155(3.94) 0.130(3.30) 0.087 (2.20) 0.071 (1.80) 0.180(4.57) 0.160(4.06) 0.012(0.305) 0.006(0.152) 0.096(2.44) 0.084(2.13) 0.060(1.52) 0.030(0.76) 0.008(0.203)MAX. 0.220(5.59) 0.205(5.21) Dimensions in inches and (millimeters) Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HUAXUANYANG SMBJ5.0(C)A-SMBJ440(C)A HXY ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR Attention ■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein in such applications. ■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein. ■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. ■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design. ■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA XUAN YANG ELECTRONICS CO.,LTD. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com
SMBJ51CA 价格&库存
很抱歉,暂时无法提供与“SMBJ51CA”相匹配的价格&库存,您可以联系我们找货
SMBJ51CA
  • 3000+0.11270
库存:360000
