P6SMB SERIES
Transient Voltage Suppressor Diodes
Features
Uni-directional
● For surface mounted applications
● Low-profile package
● Ideal for automated placement
● Available in Unidirectional and Bidirectional
● 600 W peak pulse power capability with a 10/1000 μs
waveform
● Low incremental surge resistance, excellent clamping
capability
● Very fast response time
● High temperature soldering guaranteed: 260 °C/10 s at
terminals
● Meets MSL level 1
Bi-directional
● Component in accordance to RoHS
Typical Applications
Use in sensitive electronics protection against voltage transients
induced by inductive load switching and lighting on ICs, MOSFET,
signal lines of sensor units for consumer, computer, industrial,
telecommunication.
Mechanical Data
● Package: DO-214AA (SMB)
Molding compound meets UL 94 V-0 flammability
rating, RoHS-compliant, halogen-free
● Terminals: Matte tin plated leads, solderable per
J-STD-002B and JESD22-B102D
● Polarity: For uni-directional types the band denotes cathode
end, no marking on bi-directional types
■Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL
UNIT
Max
Peak power dissipation, with a 10/1000us waveform (1) (2) (Fig.1)
PPPM
W
600
Peak pulse current, with a 10/1000us waveform(1)
IPPM
A
See Next Table
Peak forward surge current, 8.3 ms single half sine-wave unidirectional
only (2)
IFSM
A
100
TJ,TSTG
-55 to +150
SYMBOL
UNIT
VALUE
VF
V
3.5
Operating junction and storage temperature range
■Electrical Characteristics(Ta=25℃ Unless otherwise specified)
PARAMETER
Maximum instantaneous forward voltage
@ at 50A for unidirectional only (3)
■Thermal Characteristics (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL
UNIT
Conditions
VALUE
RθJL
℃/W
junction to lead
RθJA
℃/W
junction to ambient
100
Thermal resistance(Typical)
Notes:
(1)
Non-repetitive current pulse, per Fig. 3 and derated above TA= 25℃per Fig.2.
(2)
Mounted on 0.2 x 0.2" (5.0 x 5.0 mm) copper pads to each terminal.
(3)
VF
很抱歉,暂时无法提供与“P6SMB6.8CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.37908
- 100+0.29960
- 300+0.25996
- 3000+0.23015
- 6000+0.20639
- 9000+0.19440
