P0300SC
P0300SC
    JINGYANG(晶扬电子)
    SMB(DO-214AA)
P0300SC 数据手册
PxxxxSC Series Thyristors Solid Protection Device PxxxxSC Series Thyristors Solid Protection Device Bidirectional transient voltage suppressors Features  For surface mounted applications to optimize board space  Low profile package  Bidirectional crowbar protection  Low leakage current : I = 5uA max  Low on-state voltage  Low Capacitance  Response Time is < 1us  YD/T 950 IEC 61000-4-5  YD/T 993 ITU K.20/21  YD/T 1082 TIA-968-A  GR 1089 Intra-building  Solid-state silicon technology  Meets MSL 1 Requirements  ROHS compliant SMB Ordering Information Device Qty per Reel Reel Size PxxxxSC 2500 13 Inch Schematic Diagram Maximum Ratings and Electrical Characteristics Symbol IPP VPP VESD Parameter Value 10/1000 us 100 5/310 us 150 8/20 us 400 10/700us 6000 Non-repetitive peak pulse current Non-repetitive peak pulse voltage ESD Rating per IEC61000-4-2: Contact 8 Air 15 Unit A V KV Ts Storage temperature range -40 to +150 ℃ Tj Maximum junction temperature 150 ℃ Maximum ratings are those values beyond which device damage can occur. Maximum ratings applied to the device are individual stress limit values (not normal operating conditions) and are not valid simultaneously. If these limits are exceeded, device functional operation is not implied,damage may occur and reliability may be affected. *Other voltages may be available upon request. REV: C1 1 of 6  service@jy-electronics.com.cn  www.jy-electronics.com.cn PxxxxSC Series Thyristors Solid Protection Device Electrical Parameters (Tamb=25℃) VRM Type IRM Min. VBO IBO Max. Max. VT IT Max. CO IH Tpy. Tpy. V μA V mA V A pF mA P0080SC 6 5 25 800 4 2.2 100 50 P0220SC 15 5 35 800 4 2.2 100 50 P0300SC 25 5 40 800 4 2.2 100 50 P0640SC 58 5 77 800 4 2.2 100 150 P0720SC 65 5 88 800 4 2.2 100 150 P0900SC 75 5 98 800 4 2.2 90 150 P1100SC 90 5 130 800 4 2.2 90 150 P1300SC 120 5 160 800 4 2.2 90 150 P1500SC 140 5 180 800 4 2.2 85 150 P1800SC 170 5 220 800 4 2.2 85 150 P2000SC 180 5 220 800 4 2.2 85 150 P2300SC 190 5 260 800 4 2.2 150 150 P2600SC 220 5 300 800 4 2.2 150 150 P3100SC 275 5 350 800 4 2.2 80 150 P3500SC 320 5 400 800 4 2.2 65 150 P3800SC 340 5 800 4 2.2 32 50 P4200SC 400 5 450 540 800 4 2.2 32 50 P4500SC 420 750 5 540 800 4 2.2 65 50 5 940 800 4 2.2 25 50 P8500SC Notes: • All measurements are made at an ambient temperature of 25℃. IPP applies to -40℃ through +85℃ temperature range. • Off-state capacitance (CO) is measured at 1 MHz with a 2 V bias and is typical value. Symbol Parameter VRM Stand-off voltage VBR Breakdown voltage VBO Switching Voltage IBO Break over current IRM Leakage current at VRM IPP Peak pulse current IH Holding current VT On-state Voltage at IT CO Off-state Capacitance REV: C1 I Ih IBO VBO VRWM IR IR VRWM VBO V IBO Ih 2 of 6  service@jy-electronics.com.cn  www.jy-electronics.com.cn PxxxxSC Series Thyristors Solid Protection Device Typical electrical characterist applications Rating and Characteristics Curves 1 Repetitive peak current %IPP 100 Tj=25℃ C[VR]/C[VR=1V] F=1MHZ Tr=rise time(us) 0.8 VRM S=1V Tp =pulse duration time (us) 0.6 0.4 50 0.2 VR(V) 0 tr 1 tp 2 5 10 20 50 100 300 Fig. 2 Relation Variation Of Junction Capacitance Fig.1 Pulse Waveform (5/310us) Versus Reverse Voltage Applied (Typical Values) 100 40 IT(A) Tj=25℃ F=50HZ Tj=25℃ ITSM(A) 30 20 10 t(s) VT(V) 0 10 1.E-02 1.E-01 1.E+01 1.E+00 1.E+02 0 1.E+03 Fig.3 Non Repetitive Surge Peek On-State Current Versus Overload Duration 1.08 1.07 1.06 1.05 1.04 1.03 1.02 1.01 1.00 0.99 0.98 0.97 0.96 0.95 0.94 -40 IH(TJ)/IH[Tj=25℃] 1.0 Tj(℃) 0 -20 0 20 40 60 80 100 120 130 3 4 5 6 7 8 VBO[Tj]/V BO[Tj=25℃] Tj(℃) -20 0 20 40 60 80 100 120 130 Fig.6 Relative Variation of Break Over Voltage Versus Junction Temperature Fig.5 Relative Variation of Hold Current Versus Junction Temperature REV: C1 2 Fig.4 On-State Voltage Versus On-State Current (Typical Values) 2.0 -40 1 3 of 6  service@jy-electronics.com.cn  www.jy-electronics.com.cn PxxxxSC Series Thyristors Solid Protection Device Typical electrical characterist applications Rating and Characteristics Curves 1.E+03 1.0 IR[Tj]/IR[Tj=25℃] 0.9 VR=243V 0.8 ZTH(j-a)/RTH(j-a) 0.7 1.E+02 0.6 0.5 0.4 1.E+01 0.3 0.2 Tp(s) 0.1 Tj(℃) 0 1.E+00 25 50 75 100 125 Fig.7 Relative Variation Of Leakage Current Versus Reverse Voltage (Typical Values) 1.E-02 1.E-01 1.E+00 1.E+01 1.E+02 1.E+03 Fig.8 Variation Of Thermal Impedance Junction To Ambient Versus Pulse Duration SOLDERING PARAMETERS Reflow Condition -Temperature Min (Ts(min)) -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. TL Critical Zone TL to TP Ramp-up tL TS(max) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ REV: C1 tp TP Average ramp up rate (Liquid us Temp (TL)to peak) Reflow Reflow condition +150℃ 4 of 6 Temperature Pre Heat Pb-Free assembly Ramp-down Preheat TS(min) 25 ts time to peak temperatue (t 25℃ to peak) Time  service@jy-electronics.com.cn  www.jy-electronics.com.cn PxxxxSC Series Thyristors Solid Protection Device Package information SMB SMB Mechanical Data  Case: SMB  Case Material:  Classification Rating 94V-0  Polarity Indicator: Cathode Band (Note: Bi-directional devices have no polarity indicator.)  Weight: Molded Plastic. UL Flammability 0.003 ounces, 0.093 gram C Inches Millimeters B A DIM Nom Max Min Nom Max A 3.30 3.62 3.94 0.130 0.142 0.155 B 1.95 2.08 2.20 0.077 0.082 0.087 C 4.06 4.40 4.57 0.160 0.173 0.180 D 0.125 0.20 0.305 0.005 0.008 0.012 E 0.76 1.14 1.52 0.030 0.045 0.06 F 4.95 5.40 5.59 0.194 0.213 0.22 G 2.05 2.30 2.50 0.080 0.090 0.098 G G D F Min E B SMB SMB Reel Dim E P0 K P2 D T W F D1 A0 B0 B1 K0 P1 A0 B0 B1 D D1 E F K0 T W P0 P1 P2 4.0 5.9 6.1 1.5 1.5 1.75 5.5 3.0 0.50 12.0 4.0 8.0 2.0 Dimension is in mm Leader and Trailer Direction of Feed Tape Leader No Components 30 components in length Components Tape Trailer (Connected To Reel Hub) No Components 50 components in length The LEADER is a minimum of 30 components in length and it consists of empty cavities with sealed cover tape The TRAILER is a minimum of 50 components in length and it consists of empty cavities with sealed cover tape. REV: C1 5 of 6  service@jy-electronics.com.cn  www.jy-electronics.com.cn PxxxxSC Series Thyristors Solid Protection Device Marking Codes Or Pxxxx Pxxxx YWWXX XXXYY Note: (1) "Pxxxx" is part number,fixed. Note: (1) "Pxxxx" is part number,fixed. (2) "YWW" is Date code, "XX" is internal code. (2) "XXX" is the last 3 characters of the wafer's Lot No., "YY" is internal code. REV: C1 6 of 6  service@jy-electronics.com.cn  www.jy-electronics.com.cn
P0300SC 价格&库存
很抱歉,暂时无法提供与“P0300SC”相匹配的价格&库存,您可以联系我们找货
