SMBJ SERIES
Rev-1.1
www.elecsuper.com
SuperTVS – 600W Transient Voltage Suppressor
1. Features
For surface mounted applications in order
600W peak pulse power capability at
to optimize board space
10/1000μs waveform, repetition rate (duty
Low profile package
cycle): 0.01%
Built-in strain relief
Fast response time
Glass passivated junction
Typical IR less than 1μA above 10V
Low inductance
Plastic package has underwriters laboratory
Excellent clamping capability
Meets MSL level 1, per J-STD-020
flammability 94V-0
High Temperature soldering: 260℃/10
seconds at terminals
2. Mechanical Data
Case: JEDEC DO-214AA. Molded plastic
over glass passivated junction
Polarity: Color band denotes cathode except
bi-directional models
Terminal: Solder plated, solderable per
Standard Packaging: 12mm tape
MIL-STD-750, Method 2026
Weight: 0.10g
3. Maximum Ratings and Characteristics
Ratings at 25°ambient temperature unless otherwise specified
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000us waveform(Note1,2)
PPPM
600
W
Peak pulse current of at 10/1000us waveform(Note1)
IPPM
See Table
A
PM(AV)
5.0
W
IFSM
100
A
TJ, TSTG
-65 to 150
Typical thermal resistance junction to lead
RθJL
℃/W
Typical thermal resistance junction to ambient
RθJA
100
℃/W
Steady state power dissipation at TA=50℃
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load (JEDEC Method)(Note3)
Operating junction and Storage Temperature Range
Copyright© ElecSuper Incorporated
Contact Us
1 / 7
SMBJ SERIES
Rev-1.1
www.elecsuper.com
Notes:
1.
Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
2.
Mounted on 5.0mm×5.0mm copper pads to each terminal.
3.
8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
4. Electrical Characteristics (TA=25℃)
Reverse
Maximum
Maximum
Stand
Part
Test
Part
Maximum
Peak
Clamping
Marking
Number
Breakdown
off
Voltage VBR (Volts)
Current
Voltage
@ IT
IT
Number
Reverse
Pulse
Voltage
Leakage
ROHS2.0
Current
VC @ Ipp
VR
IR @ VR
Ipp
UNI
BI
UNI
BI
(V)
(mA)
(V)
SMBJ5.0A
SMBJ5.0CA
KE
AE
5
6.4
7
10
9.2
65.3
400
y
SMBJ6.0A
SMBJ6.0CA
KG
AG
6
6.67
7.37
10
10.3
58.3
400
y
SMBJ6.5A
SMBJ6.5CA
KK
AK
6.5
7.22
7.98
10
11.2
53.6
250
y
SMBJ7.0A
SMBJ7.0CA
KM
AM
7
7.78
8.6
10
12
50
100
y
SMBJ7.5A
SMBJ7.5CA
KP
AP
7.5
8.33
9.21
1
12.9
46.6
80
y
SMBJ8.0A
SMBJ8.0CA
KR
AR
8
8.89
9.83
1
13.6
44.2
50
y
SMBJ8.5A
SMBJ8.5CA
KT
AT
8.5
9.44
10.4
1
14.4
41.7
y
SMBJ9.0A
SMBJ9.0CA
KV
AV
9
10
11.1
1
15.4
39
10
y
SMBJ10A
SMBJ10CA
KX
AX
10
11.1
12.3
1
17
35.3
5
y
SMBJ11A
SMBJ11CA
KZ
AZ
11
12.2
13.5
1
18.2
33
1
y
SMBJ12A
SMBJ12CA
LE
BE
12
13.3
14.7
1
19.9
30.2
1
y
SMBJ13A
SMBJ13CA
LG
BG
13
14.4
15.9
1
21.5
28
1
y
SMBJ14A
SMBJ14CA
LK
BK
14
15.6
17.2
1
23.2
25.9
1
y
SMBJ15A
SMBJ15CA
LM
BM
15
16.7
18.5
1
24.4
24.6
1
y
SMBJ16A
SMBJ16CA
LP
BP
16
17.8
19.7
1
26
23.1
1
y
SMBJ17A
SMBJ17CA
LR
BR
17
18.9
20.9
1
27.6
21.8
1
y
SMBJ18A
SMBJ18CA
LT
BT
18
1
29.2
20.6
1
y
SMBJ20A
SMBJ20CA
LV
BV
24.5
1
32.4
18.6
1
y
SMBJ22A
SMBJ22CA
LX
BX
22
24.4
26.9
1
35.5
16.9
1
y
SMBJ24A
SMBJ24CA
LZ
BZ
24
26.7
29.5
1
38.9
15.5
1
y
SMBJ26A
SMBJ26CA
ME
CE
26
28.9
31.9
1
42.1
14.3
1
y
SMBJ28A
SMBJ28CA
MG
CG
28
31.1
34.4
1
45.4
13.3
1
y
SMBJ30A
SMBJ30CA
MK
CK
30
33.3
36.8
1
48.4
12.4
1
y
SMBJ33A
SMBJ33CA
MM
CM
33
36.7
40.6
1
53.3
11.3
1
y
SMBJ36A
SMBJ36CA
MP
CP
36
40
44.2
1
58.1
10.4
1
y
SMBJ40A
SMBJ40CA
MR
CR
40
44.4
49.1
1
64.5
9.3
1
y
SMBJ43A
SMBJ43CA
MT
CT
43
47.8
52.8
1
69.4
8.7
1
y
MIN
MAX
Contact Us
(A)
(µA)
2 / 7
SMBJ SERIES
Rev-1.1
www.elecsuper.com
Maximum
Reverse
Test
Part
Part
Number
Number
Stand
Breakdown
off
Voltage VBR (Volts)
Current
Marking
@ IT
UNI
BI
(Volts)
SMBJ45A
SMBJ45CA
MV
CV
SMBJ48A
SMBJ48CA
MX
SMBJ51A
SMBJ51CA
SMBJ54A
Reverse
Pulse
Leakage
Current
IR @ VR
Ipp (A)
(µA)
ROHS2.0
(V)
VR
BI
Peak
VC @ Ipp
(mA)
UNI
Maximum
Voltage
IT
Voltage
Maximum
Clamping
MIN
MAX
(mA)
(V)
45
50
55.3
1
72.7
8.3
1
y
CX
48
53.3
58.9
1
77.4
7.8
1
y
MZ
CZ
51
56.7
62.7
1
82.4
7.3
1
y
SMBJ54CA
NE
DE
54
60
66.3
1
87.1
6.9
1
y
SMBJ58A
SMBJ58CA
NG
DG
58
64.4
71.2
1
93.6
6.5
1
y
SMBJ60A
SMBJ60CA
NK
DK
60
66.7
73.7
1
96.8
6.2
1
y
SMBJ64A
SMBJ64CA
NM
DM
64
71.1
78.6
1
103
5.9
1
y
SMBJ70A
SMBJ70CA
NP
DP
70
77.8
86
1
113
5.3
1
y
SMBJ75A
SMBJ75CA
NR
DR
75
83.3
92.1
1
121
5
1
y
SMBJ78A
SMBJ78CA
NT
DT
78
86.7
95.8
1
126
4.8
1
y
SMBJ85A
SMBJ85CA
NV
DV
85
94.4
104
1
137
4.4
1
y
SMBJ90A
SMBJ90CA
NX
DX
90
100
111
1
146
4.1
1
y
SMBJ100A
SMBJ100CA
NZ
DZ
100
111
123
1
162
3.7
1
y
SMBJ110A
SMBJ110CA
PE
EE
110
122
135
1
177
3.4
1
y
SMBJ120A
SMBJ120CA
PG
EG
120
133
147
1
193
3.1
1
y
SMBJ130A
SMBJ130CA
PK
EK
130
144
159
1
209
2.9
1
y
SMBJ150A
SMBJ150CA
PM
EM
150
167
185
1
243
2.5
1
y
SMBJ160A
SMBJ160CA
PP
EP
160
178
197
1
259
2.3
1
y
SMBJ170A
SMBJ170CA
PR
ER
170
189
209
1
275
2.2
1
y
SMBJ180A
SMBJ180CA
PT
ET
180
201
222
1
292
2.1
1
y
SMBJ200A
SMBJ200CA
PV
EV
200
224
247
1
324
1.9
1
y
SMBJ220A
SMBJ220CA
PX
EX
220
246
272
1
356
1.7
1
y
SMBJ250A
SMBJ250CA
PZ
EZ
250
279
309
1
405
1.5
1
y
SMBJ300A
SMBJ300CA
QE
FE
300
335
371
1
486
1.3
1
y
SMBJ350A
SMBJ350CA
QG
FG
350
391
432
1
567
1.1
1
y
SMBJ400A
SMBJ400CA
QK
FK
400
447
494
1
648
0.9
1
y
SMBJ440A
SMBJ440CA
QM
FM
440
492
543
1
713
0.9
1
y
For bidirectional type having VRWM of 10 volts and less, the IR limit is double.
Contact Us
3 / 7
SMBJ SERIES
Rev-1.1
www.elecsuper.com
5. Ratings and Characteristic Curves (TA =25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 2 Pulse Derating Curve
Figure 3 Pulse Waveform
Figure 4 Typical Junction Capacitance
Figure 5 Steady State Power Dissipation Derating Curve
Figure 6 Maximum Non-Repetitive Forward Surge Current
Uni-Directional Only
Contact Us
4 / 7
SMBJ SERIES
Rev-1.1
www.elecsuper.com
6. Dimension (SMB/DO-214AA)
Dimensions
Inches
Millimeters
Min
Max
A
0.077
0.086
1.95
2.2
B
0.16
0.18
4.06
4.57
C
0.13
0.155
3.3
3.94
D
0.084
0.096
2.13
2.44
E
0.03
0.06
0.76
1.52
F
0.008
0.203
G
0.205
0.22
5.21
5.59
H
0.006
0.012
0.152
0.305
I
0.089
2.26
J
0.085
2.16
K
0.107
2.74
L
0.085
2.16
Contact Us
Min
Max
5 / 7
SMBJ SERIES
Rev-1.1
www.elecsuper.com
7. Packaging
Symbol
Dimension
W
12.0±0.20
P0
4.0±0.10
P1
8.00±0.10
P2
2.0±0.10
D0
φ1.55±0.10
D1
φ1.5±0.10
E
1.75±0.10
F
5.50±0.10
A0
3.86±0.15
B0
5.65±0.10
K0
2.75±0.15
T
0.25±0.05
D2
φ178.0±2.0
D3
φ50.0min.
D4
φ13.0±0.5
W1
16.0±2.0
Quantity: 500PCS
D5
330.0±2.0
D6
13.5±0.5
H
2.5±1.0
W2
16.0±2.0
Quantity: 3000PCS
Contact Us
6 / 7
SMBJ SERIES
Rev-1.1
www.elecsuper.com
DISCLAIMER
ELECSUPER SUPERTVS PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN
RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION,
AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED,
INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR
PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS.
These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for
(1) selecting the appropriate ElecSuper products for your application;
(2) designing, validating and testing your application;
(3) ensuring your application meets applicable standards, and any other safety, security, or other requirements.
These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for
development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of
these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party
intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives
against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are
provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in
conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter
ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products.
Contact Us
7 / 7
很抱歉,暂时无法提供与“SMBJ33CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.29830
- 100+0.22292
- 300+0.18533
- 3000+0.15704
