东沃电子
DOWOSEMI
P6SMB SERIES
DATA SHEET
TRANSIENT VOLTAGE SUPPRESSORS – P6SMB SERIES
FEATURE
For surface mounted applications in order to optimize board space.
Low profile package.
Built-in strain relief.
Glass passivated junction.
Low inductance.
Excellent clamping capability.
SMB/DO-214AA
Repetition Rate (duty cycle):0.01%.
Fast response time: typically less than 1.0ps from 0 Volts to VBR for unidirectional types.
Typical IR less than 1μA above 10V.
High Temperature soldering: 260°C/10 seconds at terminals.
MECHANICAL DATE
Case: JEDEC DO214AA. Molded plastic over glass passivated junction.
Terminal: Solder plated, solderable per MIL-STD-750, Method 2026.
Polarity: Color band denoted positive end (cathode) except Bidirectional.
Standard Packaging: 12mm tape (EIA STD RS-481).
Weight: 0.003 ounce, 0.093 grams.
DEVICES FOR BIPOLAR APPLICATION
For bidirectional use CA suffix for types P6SMB6.8CA thru types P6SMB550CA, electrical characteristics apply
in both directions.
MAXIMUM RATINGS AND CHARACTERISTICS
Ratings at 25ć ambient temperature unless otherwise specified.
RATING
SYMBOL
VALUE
UNITS
Peak Pulse Power Dissipation on 10/1000ȝs waveform
(Note1,Note2, Fig.1).
PPPM
Minimum 600
Watts
Peak Pulse Current of on 10/1000ȝs waveform.(Note1,Fig.3)
IPPM
See Table
Amps
Steady State Power Dissipation at TL =75ć,Lead lengths.375”,
(9.5mm) (Note2,Fig.5).
PM(AV)
5.0
Watts
Peak Forward Surge Current,8.3ms Single Half Sine-Wave
Superimposed on Rated Load, (JEDEC Method) (Note 3,Fig6).
IFSM
100
Amps
TJ , TSTG
-65 to +150
ć
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25ć per Fig. 2.
2. Mounted on 5.0mm x 5.0mm (0.03mm thick) Copper Pads to each terminal.
3. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum.
www.dowosemi.com
东沃电子
DOWOSEMI
P6SMB SERIES
DIMENSIONS
t
Cathode Band
s
D1 D
d
T1
T
L
SMB/DO-214AA
Millimeters
Item
Inches
Min.
Max.
Min.
Max.
L
4.06
4.57
0.160
0.180
D
3.30
3.94
0.130
0.155
D1
1.95
2.20
0.077
0.086
T
5.21
5.59
0.205
0.220
T1
0.76
1.52
0.030
0.060
d
0.203
0.008
s
2.13
2.44
0.084
0.096
t
0.152
0.305
0.006
0.012
ELECTRICAL CHARACTERISTICS
Part Number
Device
Reverse
Breakdown
Breakdown
Marking
Stand-Off
Voltage
Voltage
Code
Voltage
NIN.@IT
MAX.@IT
Test
Current
Maximum
Peak
Reverse
Clamping
Pulse
Leakage
Voltage @IPP
Current
@VRWM
UNT-POLAR
BI-POLAR
UNI
BI
VRWM(V)
VBR MIN.(V)
VBR MAX.(V)
IT(mA)
VC(V)
IPP(A)
IR(ȝA)
P6SMB6.8A
P6SMB6.8CA
6V8A
6V8C
5.80
6.45
7.14
10
10.5
58.1
1000
P6SMB7.5A
P6SMB7.5CA
7V5A
7V5C
6.40
7.13
7.88
10
11.3
54.0
500
P6SMB8.2A
P6SMB8.2CA
8V2A
8V2C
7.02
7.79
8.61
10
12.1
50.4
200
P6SMB9.1A
P6SMB9.1CA
9V1A
9V1C
7.78
8.65
9.55
1
13.4
45.5
50
P6SMB10A
P6SMB10CA
10A
10C
8.55
9.50
10.50
1
14.5
42.1
10
P6SMB11A
P6SMB11CA
11A
11C
9.40
10.50
11.60
1
15.6
39.1
5
P6SMB12A
P6SMB12CA
12A
12C
10.20
11.40
12.60
1
16.7
36.5
5
P6SMB13A
P6SMB13CA
13A
13C
11.10
12.40
13.70
1
18.2
33.5
1
P6SMB15A
P6SMB15CA
15A
15C
12.80
14.30
15.80
1
21.2
28.8
1
P6SMB16A
P6SMB16CA
16A
16C
13.60
15.20
16.80
1
22.5
27.1
1
P6SMB18A
P6SMB18CA
18A
18C
15.30
17.10
18.90
1
25.2
24.2
1
P6SMB20A
P6SMB20CA
20A
20C
17.10
19.00
21.00
1
27.7
22.0
1
P6SMB22A
P6SMB22CA
22A
22C
18.80
20.90
23.10
1
30.6
19.9
1
P6SMB24A
P6SMB24CA
24A
24C
20.50
22.80
25.20
1
33.2
18.4
1
P6SMB27A
P6SMB27CA
27A
27C
23.10
25.70
28.40
1
37.5
16.3
1
www.dowosemi.com
东沃电子
DOWOSEMI
P6SMB SERIES
Part Number
Device
Reverse
Breakdown
Breakdown
Marking
Stand-Off
Voltage
Voltage
Code
Voltage
NIN.@IT
MAX.@IT
Test
Current
Maximum
Peak
Reverse
Clamping
Pulse
Leakage
Voltage @IPP
Current
@VRWM
UNT-POLAR
BI-POLAR
UNI
BI
VRWM(V)
VBR MIN.(V)
VBR MAX.(V)
IT(mA)
VC(V)
IPP(A)
IR(ȝA)
P6SMB30A
P6SMB30CA
30A
30C
25.60
28.50
31.50
1
41.4
14.7
1
P6SMB33A
P6SMB33CA
33A
33C
28.20
31.40
34.70
1
45.7
13.3
1
P6SMB36A
P6SMB36CA
36A
36C
30.80
34.20
37.80
1
49.9
12.2
1
P6SMB39A
P6SMB39CA
39A
39C
33.30
37.10
41.00
1
53.9
11.3
1
P6SMB43A
P6SMB43CA
43A
43C
36.80
40.90
45.20
1
59.3
10.3
1
P6SMB47A
P6SMB47CA
47A
47C
40.20
44.70
49.40
1
64.8
9.4
1
P6SMB51A
P6SMB51CA
51A
51C
43.60
48.50
53.60
1
70.1
8.7
1
P6SMB56A
P6SMB56CA
56A
56C
47.80
53.20
58.80
1
77.0
7.9
1
P6SMB62A
P6SMB62CA
62A
62C
53.00
58.90
65.10
1
85.0
7.2
1
P6SMB68A
P6SMB68CA
68A
68C
58.10
64.60
71.40
1
92.0
6.6
1
P6SMB75A
P6SMB75CA
75A
75C
64.10
71.30
78.80
1
103.0
5.9
1
P6SMB82A
P6SMB82CA
82A
82C
70.10
77.90
86.10
1
113.0
5.4
1
P6SMB91A
P6SMB91CA
91A
91C
77.80
86.50
95.50
1
125.0
4.9
1
P6SMB100A
P6SMB100CA
100A
100C
85.50
95.00
105.00
1
137.0
4.5
1
P6SMB110A
P6SMB110CA
110A
110C
94.00
105.00
116.00
1
152.0
4.0
1
P6SMB120A
P6SMB120CA
120A
120C
102.00
114.00
126.00
1
165.0
3.7
1
P6SMB130A
P6SMB130CA
130A
130C
111.00
124.00
137.00
1
179.0
3.4
1
P6SMB150A
P6SMB150CA
150A
150C
128.00
143.00
158.00
1
207.0
2.9
1
P6SMB160A
P6SMB160CA
160A
160C
136.00
152.00
168.00
1
219.0
2.8
1
P6SMB170A
P6SMB170CA
170A
170C
145.00
162.00
179.00
1
234.0
2.6
1
P6SMB180A
P6SMB180CA
180A
180C
154.00
171.00
189.00
1
246.0
2.5
1
P6SMB200A
P6SMB200CA
200A
200C
171.00
190.00
210.00
1
274.0
2.2
1
P6SMB220A
P6SMB220CA
220A
220C
185.00
209.00
231.00
1
328.0
1.9
1
P6SMB250A
P6SMB250CA
250A
250C
214.00
237.00
263.00
1
344.0
1.8
1
P6SMB300A
P6SMB300CA
300A
300C
256.00
285.00
315.00
1
414.0
1.5
1
P6SMB350A
P6SMB350CA
350A
350C
300.00
332.00
368.00
1
482.0
1.3
1
P6SMB400A
P6SMB400CA
400A
400C
342.00
380.00
420.00
1
548.0
1.1
1
P6SMB440A
P6SMB440CA
440A
440C
376.00
418.00
462.00
1
602.0
1.0
1
P6SMB480A
P6SMB480CA
480A
480C
408.00
456.00
504.00
1
658.0
0.9
1
P6SMB510A
P6SMB510CA
510A
510C
434.00
485.00
535.00
1
698.0
0.9
1
P6SMB530A
P6SMB530CA
530A
530C
450.00
503.50
556.50
1
725.0
0.8
1
P6SMB540A
P6SMB540CA
540A
540C
459.00
513.00
567.00
1
740.0
0.8
1
P6SMB550A
P6SMB550CA
550A
550C
467.00
522.50
577.50
1
760.0
0.8
1
Notes: For bidirectional type having VRWM of 10 volts and less, the IR limit is double.
www.dowosemi.com
东沃电子
DOWOSEMI
P6SMB SERIES
RATINGS AND CHARACTERISTIC CURVES
Figure 1 - Peak Pulse Power Rating Curve
(TA=25ć unless otherwise noted)
Figure 2 - Pulse Derating Curve
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
PPPM-Peak Pulse Power (kW)
100
10
1
0.2x0.2" (5.0x5.0mm)
Copper Pad Area
0.1
100
75
50
25
0.00001
0.0001
0.001
td-Pulse Width (sec.)
75
100
125
150
175
Figure 4 - Typical Junction Capacitance
10000
150
tr=10μsec
TJ=25°C
Pulse Width(td) is defined
as the point where the peak
current decays to 50% of IPPM
Peak Value
IPPM
100
Bi-directional V=0V
1000
Cj (pF)
IPPM- Peak Pulse Current, % IRSM
50
TA - Ambient Temperature (ºC)
Figure 3 - Pulse Waveform
Half Value
IPPM IPPM
Uni-directional V=0V
Uni-directional @VR
100
2
Bi-directional @VR
50
10/1000μsec. Waveform
as defined by R.E.A
10
Tj=25C
f=1.0MHz
Vsig=50mVp-p
td
1.0
3.0
1
1.0
4.0
10.0
100.0
1000.0
VBR - Reverse Breakdown Voltage (V)
t-Time (ms)
Figure 5 - Steady State Power Dissipation Derating Curve
Figure 6 - Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
6
120
IFSM - Peak Forward Surge Current (A)
PM(AV), Steady State Power Dissipation (W)
25
5
4
3
2
1
80
60
40
50
75
100
125
150
175
1
10
100
Number of Cycles at 60 Hz
www.dowosemi.com
很抱歉,暂时无法提供与“P6SMB15CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.24310
- 200+0.15840
- 1500+0.13640
- 3000+0.12100
