SMB15J20CA
SMB15J20CA
    ZHIDE(志得)
    SMB(DO-214AA)
    双向TVS 20V截止 峰值浪涌电流:32.4A@10/1000US
SMB15J20CA 数据手册
SMB15Jxx(C)A Series Surface Mount Transient Voltage Suppressor Rectifiers Reverse Voltage 5.0 ~ 220 V 1500 Watt Peak Pulse Power DO214AA/(SMB) Features ● Glass passivated chip ● 1500 W peak pulse power capability with a 10/1000 us waveform, repetitive rate (duty cycle):0.01 % ● Excellent clamping capability ● Low reverse leakage ● Very fast response time ● Lead and body according with RoHS standard Mechanical Data ● Case: DO214AA/(SMB) Molded plastic ● Lead: Solderable per MIL-STD-750, method 2026 ● Epoxy: UL 94V-0 rate flame retardant ● Polarity: Color band denotes cathode end except Bipolar Unit: inch (mm) ● Mounting position: Any Maximum Ratings & Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Symbols Value Unit Peak power dissipation with a 10/1000 us waveform(1) PPP 1500 W Peak pulse current wih a 10/1000 us waveform(1) IPP See Next Table A Power dissipation on infinite heatsink at TL = 75 °C PD 5.0 W IFSM 100 A VF 3.5/6.5 V TJ,TSTG -55 to +150 ℃ Parameter Peak forward surge current, 8.3 ms single half sinewave unidirectional only(2) Maximum instantaneous forward voltage at 50 A for unidirectional only(3) Operating junction and storage temperature range Note: 1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1; 2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum; 3)VF
SMB15J20CA 价格&库存
很抱歉,暂时无法提供与“SMB15J20CA”相匹配的价格&库存,您可以联系我们找货
SMB15J20CA
    • 5+1.04739
    • 50+0.82966
    • 150+0.73635
    • 500+0.61992
    • 3000+0.56808
    • 6000+0.53698
    库存:198
