P6SMB350A
P6SMB350A
    JINGDAO(晶导微电子)
    SMB(DO-214AA)
    TVS 300V截止 峰值浪涌电流:1.3A@10/1000US
P6SMB350A 数据手册
山东晶导微电子股份有限公司 P6SMB Series Jingdao Microelectronics co.LTD Surface mount transient voltage suppressor power 600 watts PINNING Stand-Off Voltage:6.8V~550V PIN FEATURES • For surface mounted applications in order to optimize board space. • Low profile package • Glass passivated junction • Low inductance • Plastic package has Underwriters Laboratory Flammability DESCRIPTION 1 Cathode 2 Anode 2 Unipolar 1 Bipolar MECHANICAL DATA • Case: SMB • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.1g / 0.0034oz Simplified outline SMB and symbol Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Parameter Peak Pulse Power Dissipation on 10/1000 s waveform ( Note1,Note2, Fig.1). Symbol Value Unit P PPM 600 W 100 A Peak Forward Surge Current,8.3ms Single Half Sine-Wave Superimposed on Rated Load, (JEDEC Method) (Note 3,Fig4). (UNI) Peak Pulse Current on 10/1000 us waveform (Note 1, Fig 3) I PPM see Table 1 A Typical Junction capacitance at VR=4V, f=1MHz CJ 390 pF I FSM V ESD1 V ESD2 30 30 kV Typical Thermal Resistance Junction to Ambient(Note 2) RθJA 100 °C/W Operating Junction Temperature and Storage Temperature Range T j , T stg -65 ~ +150 °C Contact Air ESD Voltage per IEC6100-4-2 NOTES: 1. Non-repetitive current pulse, per Fig.3 and derated above T A = 25°C per Fig. 2. 2 2. Mounted on 5 mm (0.13mm thick) land areas. 3. Measured on 8.3ms,single half sine-wave or equivalent square wave,duty cycle=4 pulses per minute maximum. 4. Peak pulse power waveform is 10/1000μS. 2017.01 SMB-TVS-P6SMB Series-600W Page 1 of 4 山东晶导微电子股份有限公司 P6SMB Series Jingdao Microelectronics co.LTD Characteristics at Ta=25°C Reverse Stand-off Voltage Type UNI Table 1 BI Package:SMB Breakdown Voltage Test Current V BR @ I T IT Maximum Reverse Leakage Max. Clamp Peak Pulse Current Voltage I PP V C @ I PP V RMW Min Max V V V mA μA V A Device Marking Ccode UNI BI 600W Transient Voltage Suppresso P6SMB6.8A P6SMB6.8CA 5.8 6.45 7.14 10 1000 10.5 58.1 6V8A 6V8C P6SMB7.5A P6SMB7.5CA 6.4 7.13 7.88 10 500 11.3 54 7V5A 7V5C P6SMB8.2A P6SMB8.2CA 7.02 7.79 8.61 10 200 12.1 50.4 8V2A 8V2C P6SMB9.1A P6SMB9.1CA 7.78 8.65 9.55 1 50 13.4 45.5 9V1A 9V1C P6SMB10A P6SMB10CA 8.55 9.5 10.5 1 10 14.5 42.1 10A 10C P6SMB11A P6SMB11CA 9.4 10.5 11.6 1 5 15.6 39.1 11A 11C P6SMB12A P6SMB12CA 10.2 11.4 12.6 1 5 16.7 36.5 12A 12C P6SMB13A P6SMB13CA 11.1 12.4 13.7 1 1 18.2 33.5 13A 13C P6SMB15A P6SMB15CA 12.8 14.3 15.8 1 1 21.2 28.8 15A 15C P6SMB16A P6SMB16CA 13.6 15.2 16.8 1 1 22.5 27.1 16A 16C P6SMB18A P6SMB18CA 15.3 17.1 18.9 1 1 25.5 24.2 18A 18C P6SMB20A P6SMB20CA 17.1 19 21 1 1 27.7 22 20A 20C P6SMB22A P6SMB22CA 18.8 20.9 23.1 1 1 30.6 19.9 22A 22C P6SMB24A P6SMB24CA 20.5 22.8 25.2 1 1 33.2 18.4 24A 24C P6SMB27A P6SMB27CA 23.1 25.7 28.4 1 1 37.5 16.3 27A 27C P6SMB30A P6SMB30CA 25.6 28.5 31.5 1 1 41.4 14.7 30A 30C P6SMB33A P6SMB33CA 28.2 31.4 34.7 1 1 45.7 13.3 33A 33C P6SMB36A P6SMB36CA 30.8 34.2 37.8 1 1 49.9 12.2 36A 36C 39A 39C P6SMB39A P6SMB39CA 33.3 37.1 41 1 1 53.9 11.3 P6SMB43A P6SMB43CA 36.8 40.9 45.2 1 1 59.3 10.3 43A 43C P6SMB47A P6SMB47CA 40.2 44.7 49.4 1 1 64.8 9.4 47A 47C P6SMB51A P6SMB51CA 43.6 48.5 53.6 1 1 70.1 8.7 51A 51C P6SMB56A P6SMB56CA 47.8 53.2 58.8 1 1 77 7.9 56A 56C P6SMB58A P6SMB58CA 52.78 55.1 60.9 1 1 79.8 7.7 58A 58C P6SMB62A P6SMB62CA 53 58.9 65.1 1 1 85 7.2 62A 62C P6SMB68A P6SMB68CA 58.1 64.6 71.4 1 1 92 6.6 68A 68C P6SMB75A P6SMB75CA 64.1 71.3 78.8 1 1 103 5.9 75A 75C 82C P6SMB82A P6SMB82CA 70.1 77.9 86.1 1 1 113 5.4 82A P6SMB91A P6SMB91CA 77.8 86.5 95.5 1 1 125 4.9 91A 91C P6SMB100A P6SMB100CA 85.5 95 105 1 1 137 4.5 100A 100C P6SMB110A P6SMB110CA 94 105 116 1 1 152 4 110A 110C P6SMB120A P6SMB120CA 102 114 126 1 1 165 3.7 120A 120C P6SMB130A P6SMB130CA 111 124 137 1 1 179 3.4 130A 130C P6SMB150A P6SMB150CA 128 143 158 1 1 207 2.9 150A 150C P6SMB160A P6SMB160CA 136 152 168 1 1 219 2.8 160A 160C P6SMB170A P6SMB170CA 145 162 179 1 1 234 2.6 170A 170C P6SMB180A P6SMB180CA 154 171 189 1 1 246 2.5 180A 180C P6SMB200A P6SMB200CA 171 190 210 1 1 274 2.2 200A 200C P6SMB220A P6SMB220CA 185 209 231 1 1 328 1.9 220A 220C P6SMB250A P6SMB250CA 214 237 263 1 1 344 1.8 250A 250C P6SMB300A P6SMB300CA 256 285 315 1 1 414 1.5 300A 300C P6SMB350A P6SMB350CA 300 332 368 1 1 482 1.3 350A 350C P6SMB400A P6SMB400CA 342 380 420 1 1 548 1.1 400A 400C P6SMB440A P6SMB440CA 376 418 462 1 1 602 1 440A 440C P6SMB480A P6SMB480CA 408 456 504 1 1 658 0.9 480A 480C P6SMB510A P6SMB510CA 434 485 535 1 1 698 0.9 510A 510C P6SMB530A P6SMB530CA 451 503.5 556.5 1 1 725 0.8 530A 530C P6SMB540A P6SMB540CA 460 513 567 1 1 740 0.8 540A 540C P6SMB550A P6SMB550CA 468 522.5 577.5 1 1 760 0.8 550A 550C 山东晶导微电子股份有限公司 P6SMB Series Jingdao Microelectronics co.LTD Fig.2 Forward Current Derating Curve 100 Non-Repetive Pulse.Wavefom Shown in Figure.3 T A=25°C 10 1.0 0.1 0.1 1 10 100 1000 10000 PEAK PULSE POWER(PPP)OR CURRENT(Ipp) DERATINGIN PERCENTAGE% P PPM ,PEAK PULSE FORWARD ,kW Fig.1 Peak Pulse Power Rating Curve 100 80 60 40 20 0 25 I ppm ,Peak Pulse Current (%) Peak Value Pulse Width (td) is Defined as the Point where the Peak. Current Decayst to 50% of Ipp I ppm 80 Half Value-I pp /2 60 10/1000usec Waveform as Defined bye R.E.A. 40 20 0 0 1.0 2.0 3.0 4.0 I FSM ,PEAK FORWARD SURGE CURRENT, AMPERES T A =25°C 100 125 150 175 120 100 80 60 40 20 T,TIME,ms 2017.01 100 Fig.4 Maximum Non-Repetitive Peak Forward Surge Current Fig.3 Pulse Waveform t f =10usec 75 T A ,AMBIENT TEMPERATURE,°C td,PULSE WIDTH ,us 120 50 T J =T J max 8.3ms Single Half Sinepwave JEDEC Method 0 1 10 100 Number of Cycles at 60Hz www.sdjingdao.com Page 3 of 4 山东晶导微电子股份有限公司 P6SMB Series Jingdao Microelectronics co.LTD PACKAGE OUTLINE SMB Plastic surface mounted package; 2 leads L A A1 C A b D E E1 VM A SMB mechanical data UNIT mm mil A1 L C b 5.59 0.20 1.5 0.305 2.11 3.3 5.08 0.05 0.8 0.152 1.91 155 220 7.9 59 12 83 200 2.0 32 6 75 E1 A E D max 2.44 4.70 3.94 min 2.13 4.06 max 96 185 min 84 160 130 The recommended mounting pad size 2.2 (86) 2.4 (94) 2.8 (110) 2.4 (94) mm Unit : (mil) 2017.01 JD 80404 7B2/8B4/9B5 Page 4 of 4
P6SMB350A 价格&库存
很抱歉,暂时无法提供与“P6SMB350A”相匹配的价格&库存,您可以联系我们找货
