P6SMB15CA
P6SMB15CA
    ELECSUPER(静芯微)
    SMB(DO-214AA)
    双向TVS 15V截止 峰值脉冲电流:28.8A
P6SMB15CA 数据手册
P6SMB SERIES Rev-1.1 www.elecsuper.com SuperTVS – P6SMB SERIES 1. Features ⚫ For surface mounted applications in order ⚫ 600W peak pulse power capability at to optimize board space 10/1000μs waveform, repetition rate (duty ⚫ Low profile package cycle): 0.01% ⚫ Built-in strain relief ⚫ Fast response time ⚫ Glass passivated junction ⚫ Typical IR less than 1μA above 10V ⚫ Low inductance ⚫ Plastic package has underwriters laboratory ⚫ Excellent clamping capability ⚫ Meets MSL level 1, per J-STD-020 flammability 94V-0 ⚫ High Temperature soldering: 260℃/10 seconds at terminals 2. Mechanical Data ⚫ Case: JEDEC DO-214AA. Molded plastic ⚫ over glass passivated junction ⚫ Polarity: Color band denotes cathode except bi-directional models Terminal: Solder plated, solderable per ⚫ Standard Packaging: 12mm tape MIL-STD-750, Method 2026 ⚫ Weight: 0.10g 3. Maximum Ratings and Characteristics Ratings at 25°ambient temperature unless otherwise specified Rating Symbol Value Units Peak pulse power dissipation at 10/1000us waveform (Note1,2) PPPM 600 W Peak pulse current of at 10/1000us waveform (Note1) IPPM See Table A PM(AV) 5.0 W IFSM 100 A TJ, TSTG -65 to 150 ℃ Typical thermal resistance junction to lead RθJL 20 ℃/W Typical thermal resistance junction to ambient RθJA 100 ℃/W Steady state power dissipation at TA=50℃ Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) (Note3) Operating junction and Storage Temperature Range Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2. 2. Mounted on 5.0mm×5.0mm copper pads to each terminal. Copyright© ElecSuper Incorporated Contact Us 1 / 6 P6SMB SERIES 3. Rev-1.1 www.elecsuper.com 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. 4. Electrical Characteristics (TA=25℃) Reverse Maximum Maximum Part Breakdown Test off Voltage VBR (Volts) Current Voltage @ IT IT Part Maximum Peak Clamping Marking Number Stand Number Reverse Pulse Voltage Leakage VC @ Ipp VR UNI BI UNI BI (V) P6SMB6.8A P6SMB6.8CA 6V8A 6V8C 5.8 P6SMB7.5A P6SMB7.5CA 7V5A 7V5C P6SMB8.2A P6SMB8.2CA 8V2A P6SMB9.1A P6SMB9.1CA P6SMB10A ROHS2.0 Current IR @ VR Ipp MAX (mA) (V) 6.45 7.14 10 10.5 58.1 400 y 6.4 7.13 7.88 10 11.1 54 400 y 8V2C 7.02 7.79 8.61 10 12.1 50.4 200 y 9V1A 9V1C 7.78 8.65 9.55 1 13.4 45.5 50 y P6SMB10CA 10A 10C 8.55 9.5 10.5 1 14.5 42.1 20 y P6SMB11A P6SMB11CA 11A 11C 9.4 10.5 11.6 1 15.6 39.1 10 y P6SMB12A P6SMB12CA 12A 12C 10.2 11.4 12.6 1 16.7 36.5 5 y P6SMB13A P6SMB13CA 13A 13C 11.1 12.4 13.7 1 18.2 33.5 1 y P6SMB15A P6SMB15CA 15A 15C 12.8 14.3 15.8 1 21.2 28.8 1 y P6SMB16A P6SMB16CA 16A 16C 13.6 15.2 16.8 1 22.5 27.1 1 y P6SMB18A P6SMB18CA 18A 18C 15.3 17.1 18.9 1 25.5 24.2 1 y P6SMB20A P6SMB20CA 20A 20C 17.1 19 21 1 27.7 22 1 y P6SMB22A P6SMB22CA 22A 22C 18.8 20.9 23.1 1 30.6 19.9 1 y P6SMB24A P6SMB24CA 24A 24C 20.5 22.8 25.2 1 33.2 18.4 1 y P6SMB27A P6SMB27CA 27A 27C 23.1 25.7 28.4 1 37.5 16.3 1 y P6SMB30A P6SMB30CA 30A 30C 25.6 28.5 31.5 1 41.4 14.7 1 y P6SMB33A P6SMB33CA 33A 33C 28.2 31.4 34.7 1 45.7 13.3 1 y P6SMB36A P6SMB36CA 36A 36C 30.8 34.2 37.8 1 49.9 12.2 1 y P6SMB39A P6SMB39CA 39A 39C 33.3 37.1 41 1 53.9 11.3 1 y P6SMB43A P6SMB43CA 43A 43C 36.8 40.9 45.2 1 59.3 10.3 1 y P6SMB47A P6SMB47CA 47A 47C 40.2 44.7 49.4 1 64.8 9.4 1 y P6SMB51A P6SMB51CA 51A 51C 43.6 48.5 53.6 1 70.1 8.7 1 y P6SMB56A P6SMB56CA 56A 56C 47.8 53.2 58.8 1 77 7.9 1 y P6SMB58A P6SMB58CA 58A 58C 52.78 55.1 60.9 1 79.8 7.7 1 y P6SMB62A P6SMB62CA 62A 62C 53 58.9 65.1 1 85 7.2 1 y P6SMB68A P6SMB68CA 68A 68C 58.1 64.6 71.4 1 92 6.6 1 y P6SMB75A P6SMB75CA 75A 75C 64.1 71.3 78.8 1 103 5.9 1 y Copyright© ElecSuper Incorporated MIN Contact Us (A) (µA) 2 / 6 P6SMB SERIES Rev-1.1 www.elecsuper.com Reverse Maximum Maximum Maximum Part Part Number Number Stand Breakdown Test Clamping Peak off Voltage VBR (Volts) Current Voltage Pulse Reverse Marking Leakage Voltage @ IT IT VC @ Ipp ROHS2.0 Current IR @ VR VR MIN MAX (mA) (V) Ipp (V) (A) UNI BI UNI BI (V) (µA) P6SMB82A P6SMB82CA 82A 82C 70.1 77.9 86.1 1 113 5.4 1 y P6SMB91A P6SMB91CA 91A 91C 77.8 86.5 95.5 1 125 4.9 1 y P6SMB100A P6SMB100CA 100A 100C 85.5 95 105 1 137 4.5 1 y P6SMB110A P6SMB110CA 110A 110C 94 105 116 1 152 4 1 y P6SMB120A P6SMB120CA 120A 120C 102 114 126 1 165 3.7 1 y P6SMB130A P6SMB130CA 130A 130C 111 124 137 1 179 3.4 1 y P6SMB150A P6SMB150CA 150A 150C 128 143 158 1 207 2.9 1 y P6SMB160A P6SMB160CA 160A 160C 136 152 168 1 219 2.8 1 y P6SMB170A P6SMB170CA 170A 170C 145 162 179 1 234 2.6 1 y P6SMB180A P6SMB180CA 180A 180C 154 171 189 1 246 2.5 1 y P6SMB200A P6SMB200CA 200A 200C 171 190 210 1 274 2.2 1 y P6SMB220A P6SMB220CA 220A 220C 185 209 231 1 328 1.9 1 y P6SMB250A P6SMB250CA 250A 250C 214 237 263 1 344 1.8 1 y P6SMB300A P6SMB300CA 300A 300C 256 285 315 1 414 1.5 1 y P6SMB350A P6SMB350CA 350A 350C 300 332 368 1 482 1.3 1 y P6SMB400A P6SMB400CA 400A 400C 342 380 420 1 548 1.1 1 y P6SMB440A P6SMB440CA 440A 440C 376 418 462 1 602 1 1 y P6SMB480A P6SMB480CA 480A 480C 408 456 504 1 658 0.9 1 y P6SMB510A P6SMB510CA 510A 510C 434 485 535 1 698 0.9 1 y P6SMB530A P6SMB530CA 530A 530C 451 503.5 556.5 1 725 0.8 1 y P6SMB540A P6SMB540CA 540A 540C 460 513 567 1 740 0.8 1 y P6SMB550A P6SMB550CA 550A 550C 468 522.5 577.5 1 760 0.8 1 y For bidirectional type having VR of 10 volts and less, the IR limit is double. Copyright© ElecSuper Incorporated Contact Us 3 / 6 P6SMB SERIES Rev-1.1 www.elecsuper.com 5. Ratings and Characteristic Curves (TA =25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2 Pulse Derating Curve Figure 3 Pulse Waveform Figure 4 Typical Junction Capacitance Figure 5 Steady State Power Dissipation Derating Curve Figure 6 Maximum Non-Repetitive Forward Surge Current Uni-Directional Only Copyright© ElecSuper Incorporated Contact Us 4 / 6 P6SMB SERIES Rev-1.1 www.elecsuper.com 6. Packaging Symbol Dimension W 12.0±0.20 P0 4.0±0.10 P1 8.00±0.10 P2 2.0±0.10 D0 φ1.55±0.10 D1 φ1.5±0.10 E 1.75±0.10 F 5.50±0.10 A0 3.86±0.15 B0 5.65±0.10 K0 2.75±0.15 T 0.25±0.05 D2 φ178.0±2.0 D3 φ50.0min. D4 φ13.0±0.5 W1 16.0±2.0 Quantity: 500PCS D5 330.0±2.0 D6 13.5±0.5 H 2.5±1.0 W2 16.0±2.0 Quantity: 3000PCS 7. Dimension (SMB/DO-214AA) Inches Millimeters Dimensions Copyright© ElecSuper Incorporated Contact Us Min Max Min Max A 0.077 0.086 1.95 2.2 B 0.16 0.18 4.06 4.57 C 0.13 0.155 3.3 3.94 D 0.084 0.096 2.13 2.44 E 0.03 0.06 0.76 1.52 F - 0.008 - 0.203 G 0.205 0.22 5.21 5.59 H 0.006 0.012 0.152 0.305 I 0.089 - 2.26 - J 0.085 - 2.16 - K - 0.107 L 0.085 - 2.16 2.74 - 5 / 6 P6SMB SERIES Rev-1.1 www.elecsuper.com DISCLAIMER ELECSUPER SUPERTVS PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper product. Copyright© ElecSuper Incorporated Contact Us 6 / 6
P6SMB15CA
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚集电极,4脚发射极,5脚GND,6脚VCC。
4. 参数特性:工作温度范围为-20℃至+70℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有抗干扰能力强,响应速度快等特点。
6. 应用信息:广泛应用于工业控制、仪器仪表等领域。
7. 封装信息:采用DIP6封装形式。
P6SMB15CA 价格&库存
很抱歉,暂时无法提供与“P6SMB15CA”相匹配的价格&库存,您可以联系我们找货
