SMB 600WSeries
Transient Voltage Suppressor
Version: B1 2023/01/05
Exterior
Features
IEC 61000-4-2(ESD)±30KV(air), ±30KV(contact)
600Watts peak pulse power (tp=10/1000μS)
Quick response to surge voltage
Low clamping voltage
Moisture sensitivity level: level 1
DO-214AA(SMB)
Application Information
rmation
Agency Approvals
DC Port
Icon
RS485/232/422
Description
Compliance with 2011/65/EU
I/O Port
Compliance withIEC61249-2-21:2003
UL Certificated E232249
Schematic Symbol
cathode
anode
UNI-directional
BI-directional
Part Numbering and Electrical Parameter
Part Number
Marking
VR
VBR
VBR
It
Vc@IPP○1
IPP○1
IR@VR
(V)
(A)
(uA)
BI
UNI
BI
UNI
(V)
min.(V)
max.(V)
(mA)
BV-SMBJ5CA
BV-SMBJ5A
B5C
B5
5
6.4
7
10
9.2
65.3
800
BV-SMBJ6CA
BV-SMBJ6A
B6C
B6
6
6.67
7.37
10
10.3
58.3
800
BV-SMBJ6.5CA
BV-SMBJ6.5A
B6.5C
B6.5
6.5
7.22
7.98
10
11.2
53.6
500
BV-SMBJ7CA
BV-SMBJ7A
B7C
B7
7
7.78
8.6
10
12
50
200
BV-SMBJ7.5CA
BV-SMBJ7.5A
B7.5C
B7.5
7.5
8.33
9.21
1
12.9
46.6
100
BV-SMBJ8CA
BV-SMBJ8A
B8C
B8
8
8.89
9.83
1
13.6
44.2
50
BV-SMBJ8.5CA
BV-SMBJ8.5A
B8.5C
B8.5
8.5
9.44
10.4
1
14.4
41.7
BV-SMBJ9CA
BV-SMBJ9A
B9C
B9
9
10
11.1
1
15.4
39
10
BV-SMBJ10CA
BV-SMBJ10A
B10C
B10
10
11.1
12.3
1
17
35.3
5
BV-SMBJ11CA
BV-SMBJ11A
B11C
B11
11
12.2
13.5
1
18.2
33
1
BV-SMBJ12CA
BV-SMBJ12A
B12C
B12
12
13.3
14.7
1
19.9
30.2
1
BV-SMBJ13CA
BV-SMBJ13A
B13C
B13
13
14.4
15.9
1
21.5
28
1
BV-SMBJ14CA
BV-SMBJ14A
B14C
B14
14
15.6
17.2
1
23.2
25.9
1
BV-SMBJ15CA
BV-SMBJ15A
B15C
B15
15
16.7
18.5
1
24.4
24.6
1
BV-SMBJ16CA
BV-SMBJ16A
B16C
B16
16
17.8
19.7
1
26
23.1
1
BV-SMBJ17CA
BV-SMBJ17A
B17C
B17
17
18.9
20.9
1
27.6
21.8
1
BV-SMBJ18CA
BV-SMBJ18A
B18C
B18
18
1
29.2
20.6
1
BV-SMBJ20CA
BV-SMBJ20A
B20C
B20
24.5
1
32.4
18.6
1
1/6
www.bencent.com.cn
Specifications are subject to change without notice.
Customers should verify actual device performance in their specific applications
SMB 600WSeries
Part Number
Marking
VR
VBR
VBR
It
Vc@Ipp○1
IPP○1
IR@VR
(V)
min.(V)
max.(V)
(mA)
(V)
(A)
(uA)
BI
UNI
BI
UNI
BV-SMBJ22CA
BV-SMBJ22A
B22C
B22
22
24.4
26.9
1
35.5
16.9
1
BV-SMBJ24CA
BV-SMBJ24A
B24C
B24
24
26.7
29.5
1
38.9
15.5
1
BV-SMBJ26CA
BV-SMBJ26A
B26C
B26
26
28.9
31.9
1
42.1
14.3
1
BV-SMBJ28CA
BV-SMBJ28A
B28C
B28
28
31.1
34.4
1
45.4
13.3
1
BV-SMBJ30CA
BV-SMBJ30A
B30C
B30
30
33.3
36.8
1
48.4
12.4
1
BV-SMBJ33CA
BV-SMBJ33A
B33C
B33
33
36.7
40.6
1
53.3
11.3
1
BV-SMBJ36CA
BV-SMBJ36A
B36C
B36
36
40
44.2
1
58.1
10.4
1
BV-SMBJ40CA
BV-SMBJ40A
B40C
B40
40
44.4
49.1
1
64.5
9.3
1
BV-SMBJ43CA
BV-SMBJ43A
B43C
B43
43
47.8
52.8
1
69.4
8.7
1
BV-SMBJ45CA
BV-SMBJ45A
B45C
B45
45
50
55.3
1
72.7
8.3
1
BV-SMBJ48CA
BV-SMBJ48A
B48C
B48
48
53.3
58.9
1
77.4
7.8
1
BV-SMBJ51CA
BV-SMBJ51A
B51C
B51
51
56.7
62.7
1
82.4
7.3
1
BV-SMBJ54CA
BV-SMBJ54A
B54C
B54
54
60
66.3
1
87.1
6.9
1
BV-SMBJ58CA
BV-SMBJ58A
B58C
B58
58
64.4
71.2
1
93.6
6.5
1
BV-SMBJ60CA
BV-SMBJ60A
B60C
B60
60
66.7
73.7
1
96.8
6.2
1
BV-SMBJ64CA
BV-SMBJ64A
B64C
B64
64
71.1
78.6
1
103
5.9
1
BV-SMBJ70CA
BV-SMBJ70A
B70C
B70
70
77.8
86
1
113
5.3
1
BV-SMBJ75CA
BV-SMBJ75A
B75C
B75
75
83.3
92.1
1
121
5
1
BV-SMBJ78CA
BV-SMBJ78A
B78C
B78
78
86.7
95.8
1
126
4.8
1
BV-SMBJ85CA
BV-SMBJ85A
B85C
B85
85
94.4
104
1
137
4.4
1
BV-SMBJ90CA
BV-SMBJ90A
B90C
B90
90
100
111
1
146
4.1
1
BV-SMBJ100CA
BV-SMBJ100A
B100C
B100
100
111
123
1
162
3.7
1
BV-SMBJ110CA
BV-SMBJ110A
B110C
B110
110
122
135
1
177
3.4
1
BV-SMBJ120CA
BV-SMBJ120A
B120C
B120
120
133
147
1
193
3.1
1
BV-SMBJ130CA
BV-SMBJ130A
B130C
B130
130
144
159
1
209
2.9
1
BV-SMBJ150CA
BV-SMBJ150A
B150C
B150
150
167
185
1
243
2.5
1
BV-SMBJ160CA
BV-SMBJ160A
B160C
B160
160
178
197
1
259
2.3
1
BV-SMBJ170CA
BV-SMBJ170A
BV-SMBJ180CA
②
BV-SMBJ188CA
②
BV-SMBJ200CA
②
BV-SMBJ220CA
②
BV-SMBJ250CA
②
BV-SMBJ300CA
②
BV-SMBJ350CA
②
BV-SMBJ400CA
②
BV-SMBJ440CA
②
BV-SMBJ480CA
②
B170C
B170
170
189
209
1
275
2.2
1
BV-SMBJ180A
②
B180C
B180
180
201
222
1
292
2.1
1
BV-SMBJ188A
②
B188C
B188
188
209
231
1
304
2.0
1
BV-SMBJ200A
②
B200C
B200
200
224
247
1
324
1.9
1
BV-SMBJ220A
②
B220C
B220
220
246
272
1
356
1.7
1
BV-SMBJ250A
②
B250C
B250
250
279
309
1
405
1.5
1
BV-SMBJ300A
②
B300C
B300
300
335
371
1
486
1.3
1
BV-SMBJ350A
②
B350C
B350
350
391
432
1
567
1.1
1
BV-SMBJ400A
②
B400C
B400
400
447
494
1
648
0.9
1
BV-SMBJ440A
②
B440C
B440
440
492
543
1
713
0.9
1
BV-SMBJ480A
②
B480C
B480
480
536
593
1
750
0.8
1
Note: Absolute maximum ratings measured at T= 25ºC RH = 45%-75% (unless otherwise noted).
1 Surge Waveform: 10/1000μS
2/6
www.bencent.com.cn
② These part numbers do not have UL497b safety certification
SMB 600WSeries
Mark
cathode
anode
UNI: BXX
BI: BXXC
Part Number System
BV —SMBJ
(1)
(2)
XX
C
(3)
(4)
A
(5)
(1) Bencent Transient Voltage Suppressor
(2) Series Code
(3) VR=XXV
(4) BI-directional
(5) Suffix ‘A’ denotes 5% tolerance devices
V-I Curve
IPP
VC VBR
VR
IR
It
IR
It
VR
VC
VBR
V
UNI-directional
BI-directional
IPP
3/6
Parameters
Definition
VF
Forward Voltage drop for UNI-directional
VC
Clamping Voltage
Ipp
Surge Waveform 10/1000μs
VR
Stand-off Voltage
VBR
Breakdown Voltage
IR
Reverse Leakage Current
It
Test Current
Ppp
Peak Pulse Power Dissipation
www.bencent.com.cn
SMB 600WSeries
Typical Characteristics
Peak Pulse Power Rating Curve
Pulse Derating Curve
Pulse Waveform
Typical Junction Capacitance
Steady State Power Dissipation Derating Curve
4/6
www.bencent.com.cn
Maximum Non-Repetitive Forward Surge
Current Uni-Directional Only
SMB 600WSeries
Thermal Considerations
symbol
Parameter
Value
Unit
TJ
Operating Junction Temperature Range
-55 to +150
TS
Storage Temperature Range
-55 to +150
3.5/5
V
100
A
VF
IFSM
Maximum Instantaneous Forward; Voltage at 50A for Unidirectional
Only (Note 1)
Peak Forward Surge Current, 8.3ms;Single Half Sine Wave (Note 2)
Notes:
1. VF < 3.5V for single die parts and VF< 5.0V for stacked-die parts.
2. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional
device only.
Product Dimensions
REF.
mm
inch
D
3.6±0.3
0.142±0.012
D1
2±0.15
0.079±0.006
L
4.6±0.3
0.181±0.012
T
5.4±0.3
0.213±0.012
T1
1.1±0.3
0.043±0.012
d
0~0.4
0~0.016
H
2.10~2.60
0.083~0.102
REF
mm
inch
A
5.45
0.215
B
2.45
0.096
C
2.15
0.085
Recommended Soldering Pad
5/6
www.bencent.com.cn
SMB 600WSeries
Reflow Profile
Reflow Condition
Temperature Min.
+150°C
Temperature Max.
+200°C
Time (Min to Max)
60 – 180 seconds
Average ramp up rate (Liquidus Temp
(TL) to peak)
TS(max) to TL - Ramp-up Rate
- Temperature (TL)
Reflow
(Liquidus)
- Temperature (TL)
Peak Temp (TP)
TP
TP
Critical Zone
TL to TP
3°C/second max
TL
3°C/second max
Temperature
Pre Heat
Pb-Free Assembly
217°C
60 – 150 seconds
TL
TS(max)
Ramp-down
Preheat
TS(min)
TS
260+0/-5 °C
Time within 5°C of actual Peak Temp
(TP)
TL
8-15 seconds
Ramp-down Rate
6°C/s max
Time 25°C to peak Temp (TP)
8 min max.
Do not exceed
260°C
25
Time
time to peak temperature
Package Reel Information
6/6
Outline
Reel
(pcs)
Per Carton
(pcs)
Reel Diameters
(mm)
Taping
3,000
48,000
330
www.bencent.com.cn
REF.
mm
inch
W
12±1
0.472±0.039
E
1.75±0.3
0.069±0.012
F
5.5±0.3
0.217±0.012
D0
1.55±0.15
0.061±0.006
D1
1.5±0.2
0.059±0.008
P0
4.0±0.2
0.157±0.008
P1
8.0±0.2
0.315±0.008
P2
2.0±0.2
0.079±0.008
A0
3.6±0.3
0.142±0.012
B0
5.7±0.3
0.224±0.012
D5
Ø330
Ø13
D6
Ø13.5±1.0
Ø0.531±0.039
W2
18±2.0
0.709±0.079
Carton Size(mm)
L
W
H
360
360
385
很抱歉,暂时无法提供与“BV-SMBJ18CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.61712
- 50+0.47715
- 150+0.40716
- 500+0.35468
