BV-SMBJ7.5CA
BV-SMBJ7.5CA
    BENCENT(槟城)
    SMB(DO-214AA)
    双向TVS 7.5V截止 峰值浪涌电流:46.6A@10/1000US
BV-SMBJ7.5CA 数据手册
SMB 600W Series Version: A2 2016-05-27 Transient Voltage Suppressor Features Exterior IEC 61000-4-2(ESD)±15KV(air), ±8KV(contact) 600Watts peak pulse power (tp=10/1000μS) Low clamping voltage Moisture sensitivity level: level 1 SMB Agency Approvals Application Information DC Port Icon RS485/232/422 Description Compliance with 2011/65/EU I/O Port ` Compliance with IEC61249-2-21:2003 Schematic Symbol cathode anode UNI-directional BI-directional Part Numbering and Electrical Parameter Part Number Reverse Marking Stand off Voltage Max VBR VBR min. max. (V) (V) It (mA) Clamping Voltage Max Peak Max Reverse Pulse Leakage Current IR@VR IPP○1 (A) (uA) 9.2 65.3 800 10 10.3 58.3 800 7.98 10 11.2 53.6 500 7.78 8.6 10 12 50 200 7.5 8.33 9.21 1 12.9 46.6 100 B8 8 8.89 9.83 1 13.6 44.2 50 B8.5C B8.5 8.5 9.44 10.4 1 14.4 41.7 20 BV-SMBJ9A B9C B9 9 10 11.1 1 15.4 39 10 BV-SMBJ10CA BV-SMBJ10A B10C B10 10 11.1 12.3 1 17 35.3 5 BV-SMBJ11CA BV-SMBJ11A B11C B11 11 12.2 13.5 1 18.2 33 1 BV-SMBJ12CA BV-SMBJ12A B12C B12 12 13.3 14.7 1 19.9 30.2 1 BV-SMBJ13CA BV-SMBJ13A B13C B13 13 14.4 15.9 1 21.5 28 1 BV-SMBJ14CA BV-SMBJ14A B14C B14 14 15.6 17.2 1 23.2 25.9 1 BI UNI BI UNI VR(V) BV-SMBJ5CA BV-SMBJ5A B5C B5 5 6.4 7 10 BV-SMBJ6CA BV-SMBJ6A B6C B6 6 6.67 7.37 BV-SMBJ6.5CA BV-SMBJ6.5A B6.5C B6.5 6.5 7.22 BV-SMBJ7CA BV-SMBJ7A B7C B7 7 BV-SMBJ7.5CA BV-SMBJ7.5A B7.5C B7.5 BV-SMBJ8CA BV-SMBJ8A B8C BV-SMBJ8.5CA BV-SMBJ8.5A BV-SMBJ9CA 1/5 www.bencent.com.cn Vc@IPP○1 (V) Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications   SMB 600W Series   Version: A2 2016-05-27 Transient Voltage Suppressor   Max Part Number Marking Reverse Stand off Voltage BI UNI BI UNI VR(V) VBR VBR min. max. (V) (V) Clampin Max Peak Max Reverse It g Pulse Leakage (mA) Voltage Current IR@VR Vc@I 1 ○ PP I 1 ○ PP (A) (uA) (V) BV-SMBJ15CA   BV-SMBJ15A B15C B15 15 16.7 18.5 1 24.4 24.6 1 BV-SMBJ16CA BV-SMBJ16A B16C B16 16 17.8 19.7 1 26 23.1 1 BV-SMBJ17CA BV-SMBJ17A B17C B17 17 18.9 20.9 1 27.6 21.8 1 BV-SMBJ18CA BV-SMBJ18A B18C B18 18 20 22.1 1 29.2 20.6 1 BV-SMBJ20CA BV-SMBJ20A B20C B20 20 22.2 24.5 1 32.4 18.6 1 BV-SMBJ22CA BV-SMBJ22A B22C B22 22 24.4 26.9 1 35.5 16.9 1 BV-SMBJ24CA BV-SMBJ24A B24C B24 24 26.7 29.5 1 38.9 15.5 1 BV-SMBJ26CA BV-SMBJ26A B26C B26 26 28.9 31.9 1 42.1 14.3 1 BV-SMBJ28CA BV-SMBJ28A B28C B28 28 31.1 34.4 1 45.4 13.3 1 BV-SMBJ30CA BV-SMBJ30A B30C B30 30 33.3 36.8 1 48.4 12.4 1 BV-SMBJ33CA BV-SMBJ33A B33C B33 33 36.7 40.6 1 53.3 11.3 1 BV-SMBJ36CA BV-SMBJ36A B36C B36 36 40 44.2 1 58.1 10.4 1 BV-SMBJ40CA BV-SMBJ40A B40C B40 40 44.4 49.1 1 64.5 9.3 1 BV-SMBJ43CA BV-SMBJ43A B43C B43 43 47.8 52.8 1 69.4 8.7 1 BV-SMBJ45CA BV-SMBJ45A B45C B45 45 50 55.3 1 72.7 8.3 1 BV-SMBJ48CA BV-SMBJ48A B48C B48 48 53.3 58.9 1 77.4 7.8 1 BV-SMBJ51CA BV-SMBJ51A B51C B51 51 56.7 62.7 1 82.4 7.3 1 BV-SMBJ54CA BV-SMBJ54A B54C B54 54 60 66.3 1 87.1 6.9 1 BV-SMBJ58CA BV-SMBJ58A B58C B58 58 64.4 71.2 1 93.6 6.5 1 BV-SMBJ60CA BV-SMBJ60A B60C B60 60 66.7 73.7 1 96.8 6.2 1 BV-SMBJ64CA BV-SMBJ64A B64C B64 64 71.1 78.6 1 103 5.9 1 BV-SMBJ70CA BV-SMBJ70A B70C B70 70 77.8 86 1 113 5.3 1 BV-SMBJ75CA BV-SMBJ75A B75C B75 75 83.3 92.1 1 121 5 1 BV-SMBJ78CA BV-SMBJ78A B78C B78 78 86.7 95.8 1 126 4.8 1 BV-SMBJ85CA BV-SMBJ85A B85C B85 85 94.4 104 1 137 4.4 1 BV-SMBJ90CA BV-SMBJ90A B90C B90 90 100 111 1 146 4.1 1 BV-SMBJ100CA BV-SMBJ100A B100C B100 100 111 123 1 162 3.7 1 BV-SMBJ110CA BV-SMBJ110A B110C B110 110 122 135 1 177 3.4 1 Note: Absolute maximum ratings measured at T= 25ºC RH = 45%-75% (unless otherwise noted). 1 Surge Waveform: 10/1000μS ○ Mark BXXC 2/5 www.bencent.com.cn BI: BXXC BXX UNI: BXX Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications SMB 600W Series Version: A2 2016-05-27 Transient Voltage Suppressor V-I Curve IPP VC VBR VR IR It IR It VC VBR VR V UNI-directional BI- directional IPP Parameters Definition VF Forward Voltage drop for UNI-directional VC Clamping Voltage Ipp Surge Waveform 10/1000μs VR Stand-off Voltage VBR Breakdown Voltage IR Reverse Leakage Current It Test Current Ppp Peak Pulse Power Dissipation Thermal Considerations symbol Parameter Value Unit TJ Operating Junction Temperature Range -55 to +150 ℃ TS Storage Temperature Range -55 to +150 ℃ Environmental Characteristics Testing Items High Temperature Reverse Bias Test High Temperature Life Test High-low Temperature Cycle Test High Temperature &High Humidity Test Pressure Cooker Test Resistance of Soldering Heat Technical Standards Temperature: 150±3℃, Bias=80%VDRM Time:96H Temperature: 150℃ Time:168H Temperature: From -40℃ to125℃ Dwell time: 30min, 10-100 cycles Temperature: 85℃Humidity:85% Test time:168H Temperature: 121℃, 2atm. Humidity:100% Test time: 24H to 168H Temperature: 260±5℃ Time of dip soldering: 10s, 3times Note: The above testing items can be specified by customers by contacting Bencent service 3/5 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications SMB 600W Series Version: A2 2016-05-27 Transient Voltage Suppressor Product Dimensions REF. mm inch A 1.85--2.15 0.073--0.085 B 3.45--3.75 0.138--0.148 C 4.35--4.65 0.171--0.183 D 2.10--2.60 0.083--0.102 E 0.15--0.25 0.006--0.010 F 0.80--1.50 0.031--0.059 G 0.00--0.40 0.000--0.016 H 4.95--5.45 0.195--0.215 REF mm inch A 5.45 0.215 B 2.45 0.097 C 2.15 0.085 Recommended Soldering Pad Reflow Profile Pre Heat Pb-Free Assembly Temperature Min. +150°C Temperature Max. +200°C Time(Min to Max) 60 – 180 secs. Average ramp up rate(Liquidus Temp(TL) to peak) TS(max) to TL - Ramp-up Rate - Temperature (TL) Reflow (Liquidus) - Temperature (TL) Peak Temp (TP) Time within 5°C of actual Peak Temp (TP) 60 – 150 secs. 30 secs. Time 25°C to peak Temp (TP) 8 min. Max. Do not exceed +260°C TL TS(max) Ramp-down Preheat TS(min) +(260+0/-5 )°C 6°C/sec. Max. www.bencent.com.cn TL 3°C/sec. Max. +217°C Critical Zone TL to TP Ramp-up 3°C/sec. Max. Ramp-down Rate 4/5 TP TP Temperature Reflow Condition TS TL 25 time to peak temperature Time Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications SMB 600W Series Version: A2 2016-05-27 Transient Voltage Suppressor Package 5/5 Reel Information REF mm inch A 3.8+/-0.3 0.150+/-0.012 B 5.5+/-0.3 0.217+/-0.012 d 1.5+/-0.1 0.059+/-0.004 D 330+/-1 13+/-0.039 D1 72+/-3 2.835+/-0.118 D2 13+/-0.3 0.512+/-0.012 E 1.75+/-0.2 0.069+/-0.008 F 5.5+/-0.02 0.217+/-0.008 P 8.0+/-0.2 0.315+/-0.008 P0 4.0+/-0.2 0.157+/-0.008 P1 2.0+/-0.2 0.079+/-0.008 W 12.0+/-0.2 0.472+/-0.008 W1 18+/-2.0 0.709+/-0.079 Outline Reel (pcs) Per Carton (pcs) Reel Diameters (mm) Taping 3,000 24,000 330 www.bencent.com.cn Carton Size(mm) L W H 360 360 380 Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications
BV-SMBJ7.5CA 价格&库存
很抱歉,暂时无法提供与“BV-SMBJ7.5CA”相匹配的价格&库存,您可以联系我们找货
