HXY
P6SMB6.8(C)A-P6SMB550(C)A
ELECTRONICS CO.,LTD
TRANSIENT VOLTAGE SUPPRESSOR
HUAXUANYANG
Features
For surface mounted applications in order to optimize board
space Low profile package
Built-in strain relief
Glass passivated junction
Low inductance
Excellent clamping capability
SMB
600W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle): 0.01%
Fast response time
Typical IR less than 1μA above 12V
High Temperature soldering: 260℃/ 40 seconds at terminals
Plastic package has underwriters laboratory flammability 94V-0
Mechanical Data
Part Number Code
Case : JEDEC DO-214AA/SMB molded plastic body
Terminals : Solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
SMBJ XXX C A
5% VBR Voltage Tolerance
Bidirectional
Mounting Position : Any
Weight : 0.003 ounce, 0.095 grams
Voltage
Series Code
Applications
I/O interface
AC/DC power supply
Industrial and Consumer electronic applications.
MAXIMUM RATINGS AND CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified.
Peak Pulse Power Dissipation at TA=25ºC by 10x1000μs waveform (Fig.1)
(Note 1), (Note 2)
PPPM
600
Watts
Power Dissipation on infinite heat sink at TA=50O C
PM(AV)
5.0
Watts
Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3)
IFSM
100
Amps
Maximum Instantaneous Forward Voltage at 50A for Unidirectional only (Note 4)
VF
3.5V/5.0
V
TJ,TSTG
-65 to +150
Operating Junction and Storage Temperature Range
Typical Thermal Resistance Junction to Lead
RθJL
℃/W
Typical Thermal Resistance Junction to Ambient
RθJA
100
℃/W
Notes:
1.Non-repetitive current pulse , per Fig. 3 and derated above T = 25OC per Fig. 2.
A
2. Mounted on copper pad area of 0.2x0.2” (5.0 x 5.0mm) to each terminal.
3. Measured on 8.3ms single half sine wave or equivalent square
wave for unidirectional device only,duty cycle=4 per minute
4.VF
很抱歉,暂时无法提供与“P6SMB6.8CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.20178
- 100+0.16467
- 300+0.14612
- 3000+0.13223
- 6000+0.12110
- 9000+0.11546
- 国内价格
- 1+0.22550
- 200+0.14520
- 1500+0.12650
- 3000+0.11220
