P6SMB6.8A
P6SMB6.8A
    HXY(华轩阳)
    SMB(DO-214AA)
    单向TVS 5.8V截止 峰值脉冲电流:58.1A
P6SMB6.8A 数据手册
HXY P6SMB6.8(C)A-P6SMB550(C)A ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR HUAXUANYANG Features For surface mounted applications in order to optimize board space Low profile package Built-in strain relief Glass passivated junction Low inductance Excellent clamping capability SMB 600W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01% Fast response time Typical IR less than 1μA above 12V High Temperature soldering: 260℃/ 40 seconds at terminals Plastic package has underwriters laboratory flammability 94V-0 Mechanical Data Part Number Code Case : JEDEC DO-214AA/SMB molded plastic body Terminals : Solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body SMBJ XXX C A 5% VBR Voltage Tolerance Bidirectional Mounting Position : Any Weight : 0.003 ounce, 0.095 grams Voltage Series Code Applications I/O interface AC/DC power supply Industrial and Consumer electronic applications. MAXIMUM RATINGS AND CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Peak Pulse Power Dissipation at TA=25ºC by 10x1000μs waveform (Fig.1) (Note 1), (Note 2) PPPM 600 Watts Power Dissipation on infinite heat sink at TA=50O C PM(AV) 5.0 Watts Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3) IFSM 100 Amps Maximum Instantaneous Forward Voltage at 50A for Unidirectional only (Note 4) VF 3.5V/5.0 V TJ,TSTG -65 to +150 ℃ Operating Junction and Storage Temperature Range Typical Thermal Resistance Junction to Lead RθJL 20 ℃/W Typical Thermal Resistance Junction to Ambient RθJA 100 ℃/W Notes: 1.Non-repetitive current pulse , per Fig. 3 and derated above T = 25OC per Fig. 2. A 2. Mounted on copper pad area of 0.2x0.2” (5.0 x 5.0mm) to each terminal. 3. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional device only,duty cycle=4 per minute 4.VF
P6SMB6.8A 价格&库存
很抱歉,暂时无法提供与“P6SMB6.8A”相匹配的价格&库存,您可以联系我们找货
P6SMB6.8A
库存:360000
