SMBJ6.0A
SMBJ6.0A
    ZHIDE(志得)
    SMB(DO-214AA)
    单向TVS 6V截止 峰值浪涌电流:58.3A@10/1000US
SMBJ6.0A 数据手册
SMBJxx(C)A Series Surface Mount Transient Voltage Suppressor Rectifiers Reverse Voltage 5.0 ~ 550 V 600 Watt Peak Pulse Power DO214AA/(SMB) Features ● Glass passivated chip ● 600 W peak pulse power capability with a 10/1000 us waveform, repetitive rate (duty cycle):0.01 % ● Excellent clamping capability ● Low reverse leakage ● Very fast response time ● Lead and body according with RoHS standard Mechanical Data ● Case Case: DO214AA/(SMB) O /(S ) Molded o ded plastic p ast c ● Lead: Solderable per MIL-STD-750, method 2026 ● Epoxy: UL 94V-0 rate flame retardant ● Polarity: Color band denotes cathode end except Bipolar Unit: inch (mm) ● Mounting position: Any Maximum Ratings & Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. specified Symbols Value Unit Peak power dissipation with a 10/1000 us waveform(1) PPP 600 W Peak pulse current wih a 10/1000 us waveform(1) IPP See Next Table A Power dissipation on infinite heatsink at TL = 75 °C C PD 50 5.0 W IFSM 100 A VF 3.5/6.5 V TJ,TSTG -55 to +150 ℃ Parameter Peak forward surge current, 8.3 ms single half sinewave unidirectional only(2) Maximum instantaneous forward voltage at 50 A for unidirectional only(3) Operating junction and storage temperature range Note: 1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1; 2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum; 3)VF
SMBJ6.0A
物料型号:SMBJxx(C)A Series
器件简介:这是一系列表面安装瞬态电压抑制二极管整流器,具有5.0至550V的反向电压和600瓦的峰值脉冲功率。
引脚分配:文档中没有提供具体的引脚分配图,但提到了极性,其中色带表示阴极端。
参数特性: - 玻璃钝化芯片 - 600瓦峰值脉冲功率,10/1000微秒波形,重复率(占空比):0.01% - 优秀的钳位能力 - 低反向漏电流 - 非常快的响应时间 - 引脚和本体符合RoHS标准
功能详解:文档提供了详细的电气特性和最大额定值,包括峰值功率耗散、峰值脉冲电流、在无限大散热器上75°C时的功率耗散、峰值正向浪涌电流、最大瞬态正向电压等。
应用信息:文档没有明确提供应用信息,但根据器件的特性,这些瞬态电压抑制器可能用于保护电子设备免受电压瞬变的影响。
封装信息:封装类型为DO214AA/(SMB),尺寸数据以英寸和毫米为单位提供。
SMBJ6.0A 价格&库存
很抱歉,暂时无法提供与“SMBJ6.0A”相匹配的价格&库存,您可以联系我们找货
