Transient
Voltage Suppressor
瞬态抑制二极管
SMBJ Series
http://www.szshaoxin.com/
绍 鑫 实 业
Transient Voltage Suppressors - SMBJ Series
Features
UNI
1. Halogen-free
2. Rohs compliant
3. Typical maximum temperature coefficient
4. ΔVBR = 0.1% xVBR@25°C x ΔT
BI
5. Glass passivated Chip junction in DO-214AA package
6. 600W peak pulse capadility at 10×1000μs waveform, repetition
rate(duty cycles):0.01%
7. Fast response time:typically less than 1.0ps from 0 Volts to BV min
8. Excellent clamping capability
9. Low incremental surge resistance
Cathode
BI
Anode
10. Typical IR less than 5μA above 12V
11. High temperature soldering guaranteed: 260°C/40 seconds /
0.375”,(9.5mm) lead length, 5lbs., (2.3kg) tension
UNI
12. Plastic package has underwriters laboratory flammability classification
94v-0
Applications
TVS devices are ideal for the protection of I/O interfaces,VCC bus and other vulnerable circuits used in telecom, computer,
industrial and consumer electronic applications.
Mechanical Characteristics
Rating
Symbol
Value
Units
PPPM
600
Watts
PD
5
Watts
IFSM
100
Amps
VF
3.5/5.0
V
Operating junction and Storage Temperature Range.
TJ,TSTG
-55°C to 150°C
°C
Typical Thermal Resistance Junction to Lead
RuJL
°C/W
to Ambient
RuJA
100
°C/W
Peak Pulse Power Dissipation by 10x1000μs test
waveform (Fig.1)(Note 1)
Steady State Power Dissipation on
inifinite heat sink at TL=75ºC (Fig. 5)
Peak Forward Surge Current, 8.3ms Single Half
Sine Wave Unidirectional only (Note 2)
Maximum Instantaneous Forward Voltage at 25A for
Unidirectional only (Note 3)
Notes:
1. Non-repetitive current pulse , per Fig. 3 and derated above TA = 25°C per Fig. 2.
2. Mounted on copper pad area of 0.2x0.2” (5.0 x 5.0mm) to each terminal.
3. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle=4 per minute
maximum.
4. VF
很抱歉,暂时无法提供与“SMBJ26CA”相匹配的价格&库存,您可以联系我们找货
