SMBJ3.3(C)A
Features
SMB/DO-214AA
Glass passivated chip
600W peak pulse power capability with a 10/1000 µs
waveform, repetitive rate (duty cycle):0.01%
Excellent clamping capability
Low reverse leakage
Very fast response time
Lead and body according with RoHS standard
Mechanical Data
Case: SMB/DO-214AA Molded plastic
Lead: Solderable per MIL-STD-750, method 2026
Epoxy: UL 94V-0 rate flame retardant
Polarity: Color band denotes cathode end except Bipolar
Mounting position: Any
Dimensions:inch[mm]
Bi-directional
Uni-directional
Absolute Maximum Ratings (TA=25℃ unless otherwise noted)
Parameter
Symbol
(1)
Value
Unit
PPP
600
W
(1)
IPP
75
A
Power dissipation on infinite heatsink at TL = 75 °C
PD
5.0
W
Peak forward surge current, 8.3 ms single half sinewave unidirectional
only(2)
IFSM
100
A
Maximum instantaneous forward voltage at 10 A for unidirectional only
VF
3.5/5.0
V
TJ,TSTG
-55 to +150
Peak power dissipation with a 10/1000 us waveform
Peak pulse current wih a 10/1000 us waveform
Operating junction and storage temperature range
Note:
1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1;
2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum;
Electrical Characteristics (T A=25℃ unless otherwise noted)
Part Number
Device
Reverse
Breakdown
Marking
Stand-off
Voltage
Code
Voltage
UNI-POLAR
BI-POLAR
UNI
BI
SMBJ3.3A
SMBJ3.3CA
KC
DL
0571-87006810
VRWM(V)
3.3
VBR @ IT
Test
Max. Clamping
Current
Voltage @ IPP
VC MAX.(V)
Min.(V)
Max.(V)
IT(mA)
5.20
6.50
10
www.dowosemi.cn
8.0
Max. Peak
Max. Reverse
Pulse
Current
Leakage @
VRWM
IPP(A)
IR(uA)
75.0
600
1/2
SMBJ3.3(C)A
Ratings and Characteristics Curves (TA = 25°C unless otherwise noted)
120
Peak Forward Surge Current, (A)
PEAKPULSE DETATING IN % OF
PEAK POWER OR CUNRRENT
100
75
50
25
10X1000Waveform
as defined REA
80
60
40
50
75
100
125
150
175
200
1
Ambient Temperature,TA(℃)
Fig. 1-Pulse Derating Curve
PM(AV) STEADY STATE POWER DISSIPATION(W)
Pulse Width 8.3ms
Single Half-Sine-Wave
(JEDEC METHOD)
100
10
Number of Cycles at 60 Hz
Fig. 2-Maxmum Non-Repetitive Surge Current
100
1.0
Peak Power (KW)
0.8
0.6
0.4
10
1
60Hz Resistive or
Inductive Load
0.2
0.1
0.0
50
75
100
125
150
175
1
200
10
Lead Temperature,TL(℃)
100
Tj=25℃
Pulse Width(td) is defined as the
point where the peak current
decays to 50% of IPP
Junction Capacitancem, CJ (pF)
Peak Value (Ipp)
100
Half Value=IPP/2
50
10/1000 usec.Waveform
Uni-directional
1000
@zener bias
Uni-directional@VRWM
100
10
Bi-directional@VRWM
TJ=25℃
f=1.0MHz
1
2
3
4
1
10
100
1000
Reverse Breakdown Voltage, VBR (V)
Time,(ms)
Fig. 6-Typical Junction Capacitance
Fig. 5-Pulse Waveform
0571-87006810
Bi-directional
@zener bias
as defined by R.E.A
Fig. 4-Peak Pulse Power Rating Curve
10000
Tr=10us
1000
Pulse Width,td(us)
Fig. 3-Steady State Power Derating Curve
Peak Pulse Current,(%)
100
www.dowosemi.cn
2/2
很抱歉,暂时无法提供与“SMBJ3.3CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.48180
- 200+0.31130
- 1500+0.26950
- 3000+0.23870
- 国内价格
- 10+0.47013
- 100+0.36645
- 300+0.31461
- 3000+0.29949
- 6000+0.26838
- 12000+0.25272
