P6SMB SERIES
Rev-1.1
www.elecsuper.com
SuperTVS – P6SMB SERIES
1. Features
For surface mounted applications in order
600W peak pulse power capability at
to optimize board space
10/1000μs waveform, repetition rate (duty
Low profile package
cycle): 0.01%
Built-in strain relief
Fast response time
Glass passivated junction
Typical IR less than 1μA above 10V
Low inductance
Plastic package has underwriters laboratory
Excellent clamping capability
Meets MSL level 1, per J-STD-020
flammability 94V-0
High Temperature soldering: 260℃/10
seconds at terminals
2. Mechanical Data
Case: JEDEC DO-214AA. Molded plastic
over glass passivated junction
Polarity: Color band denotes cathode except
bi-directional models
Terminal: Solder plated, solderable per
Standard Packaging: 12mm tape
MIL-STD-750, Method 2026
Weight: 0.10g
3. Maximum Ratings and Characteristics
Ratings at 25°ambient temperature unless otherwise specified
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000us waveform (Note1,2)
PPPM
600
W
Peak pulse current of at 10/1000us waveform (Note1)
IPPM
See Table
A
PM(AV)
5.0
W
IFSM
100
A
TJ, TSTG
-65 to 150
Typical thermal resistance junction to lead
RθJL
℃/W
Typical thermal resistance junction to ambient
RθJA
100
℃/W
Steady state power dissipation at TA=50℃
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load (JEDEC Method) (Note3)
Operating junction and Storage Temperature Range
Notes:
1.
Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
2.
Mounted on 5.0mm×5.0mm copper pads to each terminal.
Copyright© ElecSuper Incorporated
Contact Us
1 / 6
P6SMB SERIES
3.
Rev-1.1
www.elecsuper.com
8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
4. Electrical Characteristics (TA=25℃)
Reverse
Maximum
Maximum
Part
Breakdown
Test
off
Voltage VBR (Volts)
Current
Voltage
@ IT
IT
Part
Maximum
Peak
Clamping
Marking
Number
Stand
Number
Reverse
Pulse
Voltage
Leakage
VC @ Ipp
VR
UNI
BI
UNI
BI
(V)
P6SMB6.8A
P6SMB6.8CA
6V8A
6V8C
5.8
P6SMB7.5A
P6SMB7.5CA
7V5A
7V5C
P6SMB8.2A
P6SMB8.2CA
8V2A
P6SMB9.1A
P6SMB9.1CA
P6SMB10A
ROHS2.0
Current
IR @ VR
Ipp
MAX
(mA)
(V)
6.45
7.14
10
10.5
58.1
400
y
6.4
7.13
7.88
10
11.1
54
400
y
8V2C
7.02
7.79
8.61
10
12.1
50.4
200
y
9V1A
9V1C
7.78
8.65
9.55
1
13.4
45.5
50
y
P6SMB10CA
10A
10C
8.55
9.5
10.5
1
14.5
42.1
y
P6SMB11A
P6SMB11CA
11A
11C
9.4
10.5
11.6
1
15.6
39.1
10
y
P6SMB12A
P6SMB12CA
12A
12C
10.2
11.4
12.6
1
16.7
36.5
5
y
P6SMB13A
P6SMB13CA
13A
13C
11.1
12.4
13.7
1
18.2
33.5
1
y
P6SMB15A
P6SMB15CA
15A
15C
12.8
14.3
15.8
1
21.2
28.8
1
y
P6SMB16A
P6SMB16CA
16A
16C
13.6
15.2
16.8
1
22.5
27.1
1
y
P6SMB18A
P6SMB18CA
18A
18C
15.3
17.1
18.9
1
25.5
24.2
1
y
P6SMB20A
P6SMB20CA
20A
20C
17.1
19
21
1
27.7
22
1
y
P6SMB22A
P6SMB22CA
22A
22C
18.8
20.9
23.1
1
30.6
19.9
1
y
P6SMB24A
P6SMB24CA
24A
24C
20.5
22.8
25.2
1
33.2
18.4
1
y
P6SMB27A
P6SMB27CA
27A
27C
23.1
25.7
28.4
1
37.5
16.3
1
y
P6SMB30A
P6SMB30CA
30A
30C
25.6
28.5
31.5
1
41.4
14.7
1
y
P6SMB33A
P6SMB33CA
33A
33C
28.2
31.4
34.7
1
45.7
13.3
1
y
P6SMB36A
P6SMB36CA
36A
36C
30.8
34.2
37.8
1
49.9
12.2
1
y
P6SMB39A
P6SMB39CA
39A
39C
33.3
37.1
41
1
53.9
11.3
1
y
P6SMB43A
P6SMB43CA
43A
43C
36.8
40.9
45.2
1
59.3
10.3
1
y
P6SMB47A
P6SMB47CA
47A
47C
40.2
44.7
49.4
1
64.8
9.4
1
y
P6SMB51A
P6SMB51CA
51A
51C
43.6
48.5
53.6
1
70.1
8.7
1
y
P6SMB56A
P6SMB56CA
56A
56C
47.8
53.2
58.8
1
77
7.9
1
y
P6SMB58A
P6SMB58CA
58A
58C
52.78
55.1
60.9
1
79.8
7.7
1
y
P6SMB62A
P6SMB62CA
62A
62C
53
58.9
65.1
1
85
7.2
1
y
P6SMB68A
P6SMB68CA
68A
68C
58.1
64.6
71.4
1
92
6.6
1
y
P6SMB75A
P6SMB75CA
75A
75C
64.1
71.3
78.8
1
103
5.9
1
y
MIN
Contact Us
(A)
(µA)
2 / 6
P6SMB SERIES
Rev-1.1
www.elecsuper.com
Reverse
Maximum
Maximum
Maximum
Part
Part
Number
Number
Stand
Breakdown
Test
Clamping
Peak
off
Voltage VBR (Volts)
Current
Voltage
Pulse
Reverse
Marking
Leakage
Voltage
@ IT
IT
VC @ Ipp
ROHS2.0
Current
IR @ VR
VR
MIN
MAX
(mA)
(V)
Ipp
(V)
(A)
UNI
BI
UNI
BI
(V)
(µA)
P6SMB82A
P6SMB82CA
82A
82C
70.1
77.9
86.1
1
113
5.4
1
y
P6SMB91A
P6SMB91CA
91A
91C
77.8
86.5
95.5
1
125
4.9
1
y
P6SMB100A
P6SMB100CA
100A
100C
85.5
95
105
1
137
4.5
1
y
P6SMB110A
P6SMB110CA
110A
110C
94
105
116
1
152
4
1
y
P6SMB120A
P6SMB120CA
120A
120C
102
114
126
1
165
3.7
1
y
P6SMB130A
P6SMB130CA
130A
130C
111
124
137
1
179
3.4
1
y
P6SMB150A
P6SMB150CA
150A
150C
128
143
158
1
207
2.9
1
y
P6SMB160A
P6SMB160CA
160A
160C
136
152
168
1
219
2.8
1
y
P6SMB170A
P6SMB170CA
170A
170C
145
162
179
1
234
2.6
1
y
P6SMB180A
P6SMB180CA
180A
180C
154
171
189
1
246
2.5
1
y
P6SMB200A
P6SMB200CA
200A
200C
171
190
210
1
274
2.2
1
y
P6SMB220A
P6SMB220CA
220A
220C
185
209
231
1
328
1.9
1
y
P6SMB250A
P6SMB250CA
250A
250C
214
237
263
1
344
1.8
1
y
P6SMB300A
P6SMB300CA
300A
300C
256
285
315
1
414
1.5
1
y
P6SMB350A
P6SMB350CA
350A
350C
300
332
368
1
482
1.3
1
y
P6SMB400A
P6SMB400CA
400A
400C
342
380
420
1
548
1.1
1
y
P6SMB440A
P6SMB440CA
440A
440C
376
418
462
1
602
1
1
y
P6SMB480A
P6SMB480CA
480A
480C
408
456
504
1
658
0.9
1
y
P6SMB510A
P6SMB510CA
510A
510C
434
485
535
1
698
0.9
1
y
P6SMB530A
P6SMB530CA
530A
530C
451
503.5
556.5
1
725
0.8
1
y
P6SMB540A
P6SMB540CA
540A
540C
460
513
567
1
740
0.8
1
y
P6SMB550A
P6SMB550CA
550A
550C
468
522.5
577.5
1
760
0.8
1
y
For bidirectional type having VR of 10 volts and less, the IR limit is double.
Contact Us
3 / 6
P6SMB SERIES
Rev-1.1
www.elecsuper.com
5. Ratings and Characteristic Curves (TA =25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 2 Pulse Derating Curve
Figure 3 Pulse Waveform
Figure 4 Typical Junction Capacitance
Figure 5 Steady State Power Dissipation Derating Curve
Figure 6 Maximum Non-Repetitive Forward Surge Current
Uni-Directional Only
Contact Us
4 / 6
P6SMB SERIES
Rev-1.1
www.elecsuper.com
6. Packaging
Symbol
Dimension
W
12.0±0.20
P0
4.0±0.10
P1
8.00±0.10
P2
2.0±0.10
D0
φ1.55±0.10
D1
φ1.5±0.10
E
1.75±0.10
F
5.50±0.10
A0
3.86±0.15
B0
5.65±0.10
K0
2.75±0.15
T
0.25±0.05
D2
φ178.0±2.0
D3
φ50.0min.
D4
φ13.0±0.5
W1
16.0±2.0
Quantity: 500PCS
D5
330.0±2.0
D6
13.5±0.5
H
2.5±1.0
W2
16.0±2.0
Quantity: 3000PCS
7. Dimension (SMB/DO-214AA)
Inches
Millimeters
Dimensions
Contact Us
Min
Max
Min
Max
A
0.077
0.086
1.95
2.2
B
0.16
0.18
4.06
4.57
C
0.13
0.155
3.3
3.94
D
0.084
0.096
2.13
2.44
E
0.03
0.06
0.76
1.52
F
0.008
0.203
G
0.205
0.22
5.21
5.59
H
0.006
0.012
0.152
0.305
I
0.089
2.26
J
0.085
2.16
K
0.107
L
0.085
2.16
2.74
5 / 6
P6SMB SERIES
Rev-1.1
www.elecsuper.com
DISCLAIMER
ELECSUPER SUPERTVS PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN
RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION,
AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED,
INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR
PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS.
These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for
(1) selecting the appropriate ElecSuper products for your application;
(2) designing, validating and testing your application;
(3) ensuring your application meets applicable standards, and any other safety, security, or other requirements.
These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for
development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of
these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party
intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives
against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are
provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in
conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter
ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper product.
Contact Us
6 / 6
很抱歉,暂时无法提供与“P6SMB30CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.20110
- 50+0.17691
- 150+0.16492
- 500+0.15585
- 3000+0.14861
- 6000+0.14494
