P0640SC
P0640SC
    YFW(佑风微)
    SMB(DO-214AA)
    表面贴装过压保护晶闸管,反向电压6.0~390V
P0640SC 数据手册
P0060SC THRU P4200SC SMB Surface Mounted Over-voltage Protection Thyristor Pinning Reverse Voltage 6.0 ~ 390 V 1.Cathode       1 Features  Low reverse leakage  High reliability  High temperature soldering guaranteed: 260℃/10seconds  Lead and body according with RoHS standard  Have low capacitance, making them ideal for high-speed transmission equipment  Will not fatigue  Are non-degenerative  Eliminate voltage overshoot caused by fast-rising transients  Cannot be damaged by voltage 2.Anode     2     DO-214AA/SMB Mechanical Data  Case:DO-214AA Molded plastic  Epoxy: UL 94V-0 rate flame retardant  Lead: Pure tin plated, lead free  Green compound Electrical Parameters Parameter VDRM Definition Peak Off-state Voltage – maximum voltage that can be applied while maintaining off state VS Switching Voltage – maximum voltage prior to switching to on state VT On-state Voltage – maximum voltage measured at rated on-state current IDRM Leakage Current – maximum peak off-state current measured at VDRM IS Switching Current – maximum current required to switch to on state IT On-state Current – maximum rated continuous on-state current IH Holding Current – minimum current required to maintain on state CO Off-state Capacitance – typical capacitance measured in off state VPP Peak Pulse Voltage – maximum rated peak impulse voltage IPP Peak Pulse Current – maximum rated peak impulse current www.yfwdiode.com Rev:2023DZ1 1/4 GuangDongYoufeng Microelectronics Co,Ltd. P0060SC THRU P4200SC SMB Electrical Characteristics VPP IPP 10/700us (V) 10/1000us (A) 105 6000 150 50 105 6000 150 2.2 50 105 6000 150 800 2.2 150 95 6000 150 5.0 800 2.2 150 95 6000 150 4.0 5.0 800 2.2 150 85 6000 150 130 4.0 5.0 800 2.2 150 85 6000 150 120 160 4.0 5.0 800 2.2 150 85 6000 150 P150C 140 180 4.0 5.0 800 2.2 150 80 6000 150 P1800SC P180C 170 220 4.0 5.0 800 2.2 150 80 6000 150 P2300SC P230C 190 260 4.0 5.0 800 2.2 150 75 6000 150 P2600SC P260C 220 300 4.0 5.0 800 2.2 150 75 6000 150 P3100SC P310C 275 350 4.0 5.0 800 2.2 150 65 6000 150 P3500SC P350C 320 400 4.0 5.0 800 2.2 150 65 6000 150 P4200SC P420C 390 500 4.0 5.0 800 2.2 0 65 6000 150 Part Number Marking VDRM (V) VS (V) VT (V) IDRM (uA) IS (mA) IT (A) IH (mA) CO (pF) P0060SC P006C 6 25 4.0 5.0 800 2.2 50 P0080SC P008C 6 25 4.0 5.0 800 2.2 P0300SC P030C 25 40 4.0 5.0 800 P0640SC P064C 58 77 4.0 5.0 P0720SC P072C 65 88 4.0 P0900SC P090C 75 98 P1100SC P110C 90 P1300SC P130C P1500SC Note: 1)All measurements are made at an ambient temperature of 25℃. IPP applies to -40℃ through +85℃ temperature range. 2)Off-state capacitance (CO ) is measured at 1 MHz with a 2 V bias and is typical value. Thermal Considerations Package DO-214AA SMB www.yfwdiode.com Symbol Parameter Value Unit TJ Operating Junction Temperature -40 to +150 ℃ TS Storage Temperature Range -40 to +150 ℃ RJA Junction to Ambient on printed circuit 53 ℃/W Rev:2023DZ1 2/4 GuangDongYoufeng Microelectronics Co,Ltd. P0060SC THRU P4200SC SMB Characteristics Curves Figure 2. tr x td Pulse Wave-form Figure 1. V-I Characteristics +I IT tr=rise time to peak value td=decay time to half value 100 Peak Value IS IH Waveform = tr x td IDRM -V +V VT VDRM Half Value 50 VS 0 td tr t - Time (us) -I Figure 3. Normalized V S Change versus Figure 4. Normalized DC Holding Current versus Case Temperature Junction Temperature 14 IH (TC=25℃ ) 2.0 1.8 IH 10 8 6 4 1.6 1.4 25℃ Ratio of Percent of VS Change-% 12 2 0 -2 25℃ 1.2 1.0 0.8 -4 0.6 -6 Tj=25℃ 0.4 -8 -40 -20 0 20 40 60 80 -40 100 120 140 160 Junction Temperature (TJ) - ℃ www.yfwdiode.com Rev:2023DZ1 -20 0 20 40 60 80 100 120 140 160 Case Temperature (TJ) - ℃ 3/4 GuangDongYoufeng Microelectronics Co,Ltd. P0060SC THRU P4200SC SMB Package Outline DO-214AA SMB Unit: inch (mm) Summary of Packing Options Package DO-214AA SMB www.yfwdiode.com Packing Description Packing Quantity Industry Standard Tape/Reel,13”reel 3000 EIA-481-1 Rev:2023DZ1 4/4 GuangDongYoufeng Microelectronics Co,Ltd.
P0640SC 价格&库存
很抱歉,暂时无法提供与“P0640SC”相匹配的价格&库存,您可以联系我们找货
