P0080SA
P0080SA
    LIOWN(里阳)
    SMB(DO-214AA)
    VDRM(V) 6 IDRM(uA) 5 VS(V) 25 IS(mA) 800 IH(mA) 50 Coty(pF) 50 IPP(A)@10/1000μs 45 VPP(V)@10/700μs 2...
P0080SA 数据手册
TSS PXXXXSX Series Features        Strong absorption capacity of surge High reliability Low leakage current Fast response time Meet MSL level1, per J-STD-020 Operating Junction Temperature: -40 to +150℃ Storage Temperature Range: -40 to +150℃ Applications TSS components are ideal for the protection of telecommunications equipment such as modems, line cards, fax machines, and other CPE. Electrical Characteristics (TA=25℃) Part Number Marking Peak Off-state Voltage Off-state Current Switching Voltage Switching Current On-state Voltage On-state Current Holding Current Off-state Capacitance @2V, 1MHz VDRM max.(V) IDRM max.(μA) VS max.(V) IS max.(mA) VT max.(V) IT max.(A) IH typ.(mA) CO typ.(pF) P0080SA P008A 6 5 25 800 4 2.2 50 50 P0080SB P008B 6 5 25 800 4 2.2 50 70 P0080SC P008C 6 5 25 800 4 2.2 50 100 P0300SA P03A 25 5 40 800 4 2.2 50 70 P0300SB P03B 25 5 40 800 4 2.2 50 70 P0300SC P03C 25 5 40 800 4 2.2 50 100 P0640SA P06A 58 5 77 800 4 2.2 150 50 P0640SB P06B 58 5 77 800 4 2.2 150 60 P0640SC P06C 58 5 77 800 4 2.2 150 100 P0720SA P07A 65 5 88 800 4 2.2 150 50 P0720SB P07B 65 5 88 800 4 2.2 150 60 P0720SC P07C 65 5 88 800 4 2.2 150 100 P0900SA P09A 75 5 98 800 4 2.2 150 45 P0900SB P09B 75 5 98 800 4 2.2 150 55 P0900SC P09C 75 5 98 800 4 2.2 150 90 www.liownsemi.com 掌握芯技术Core Technology (V1) TSS PXXXXSX Series Electrical Characteristics (TA=25℃) Part Marking Number Peak Off-state Voltage Off-state Current Switching Voltage Switching Current On-state Voltage On-state Current Holding Current Off-state Capacitance @2V, 1MHz VDRM max.(V) IDRM max.(μA) VS max.(V) IS max.(mA) VT max.(V) IT max.(A) IH typ.(mA) CO typ.(pF) P1100SA P11A 90 5 130 800 4 2.2 150 45 P1100SB P11B 90 5 130 800 4 2.2 150 55 P1100SC P11C 90 5 130 800 4 2.2 150 90 P1300SA P13A 120 5 160 800 4 2.2 150 45 P1300SB P13B 120 5 160 800 4 2.2 150 55 P1300SC P13C 120 5 160 800 4 2.2 150 90 P1500SA P15A 140 5 180 800 4 2.2 150 40 P1500SB P15B 140 5 180 800 4 2.2 150 60 P1500SC P15C 140 5 180 800 4 2.2 150 85 P1800SA P18A 170 5 220 800 4 2.2 150 40 P1800SB P18B 170 5 220 800 4 2.2 150 60 P1800SC P18C 170 5 220 800 4 2.2 150 85 P2300SA P23A 190 5 260 800 4 2.2 150 35 P2300SB P23B 190 5 260 800 4 2.2 150 55 P2300SC P23C 190 5 260 800 4 2.2 150 80 P2600SA P26A 220 5 300 800 4 2.2 150 35 P2600SB P26B 220 5 300 800 4 2.2 150 50 P2600SC P26C 220 5 300 800 4 2.2 150 80 P3100SA P31A 275 5 350 800 4 2.2 150 30 P3100SB P31B 275 5 350 800 4 2.2 150 45 P3100SC P31C 275 5 350 800 4 2.2 150 65 P3500SA P35A 320 5 400 800 4 2.2 150 30 P3500SB P35B 320 5 400 800 4 2.2 150 40 P3500SC P35C 320 5 400 800 4 2.2 150 65 Surge Rating Type IPP@8/20μs IPP@10/1000μs VPP@10/700μs A 150A 45A 2kV B 250A 80A 4kV C 400A 100A 6kV www.liownsemi.com 掌握芯技术Core Technology (V1) TSS PXXXXSX Series Characteristic Curves (TA=25℃) Figure 1. V-I Characteristics Figure 2. Pulse Waveform +I 100 IT IS IH Waveform = tr × td IDRM -V tr = rise time to peak value td = decay time to half value Peak Value +V VT 50 Half Value VDRM VS 0 -I td tr t-Time (µs) Figure 3. Normalized Vs Change versus Junction Temperature Percent of VS, Change - % 0 Figure 4. Normalized DC Holding Current versus Case Temperature 16 14 12 10 2.0 8 1.4 1.8 1.6 6 1.2 4 2 0 25℃ 1.0 25℃ 0.8 -4 0.6 -6 -8 -40 -20 0 20 40 60 80 100 120 140 160 0.4 -40 -20 TJ-Junction Temperature (℃) www.liownsemi.com 0 20 40 60 80 100 120 140 160 TC-Case Temperature (℃) 掌握芯技术Core Technology (V1) TSS PXXXXSX Series Soldering Parameters Reflow Soldering Profile Feature Pb-Free Assembly Average ramp-up rate (TL to TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max) ( tS) 150℃ 200℃ 60-180 seconds TS max to TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) -Time (tL) 217℃ 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual Peak Temperature (tP) Ramp-down Rate 20-40 seconds 6℃/second max. Time 25℃ to Peak Temperature 8 minutes max. Part Number Code and Marking Code www.liownsemi.com 掌握芯技术Core Technology (V1) TSS PXXXXSX Series Dimensions (SMB/DO-214AA) Symbol Millimeters Inches Min. Max. Min. Max. A 1.930 2.200 0.076 0.086 B 4.060 4.750 0.160 0.187 C 3.300 3.940 0.130 0.155 D 2.160 2.650 0.085 0.104 E 0.760 1.520 0.030 0.060 F - 0.203 - 0.008 G 5.210 5.590 0.205 0.220 H 0.152 0.305 0.006 0.012 I 2.260 - 0.089 - J 2.160 - 0.085 - K - 2.740 - 0.107 Packaging Specification Tape 13 Inches Reel Quantity:3000pcs/reel www.liownsemi.com 掌握芯技术Core Technology (V1)
P0080SA 价格&库存
很抱歉,暂时无法提供与“P0080SA”相匹配的价格&库存,您可以联系我们找货
