SMBJ28A
SMBJ28A
    JKSEMI(金开盛)
    SMB(DO-214AA)
    单向TVS 28V截止 峰值脉冲电流:13.2A@10/1000US
SMBJ28A 数据手册
SMBJ Series 600W Transient Voltage Suppressor DESCRIPTION: TVS diodes can be used in a wide range of applications which like consumer electronic products, automotive industries, munitions, telecommunications, aerospace industries, and intelligent control systems. SMB FEATURES:  Glass passivated or planar junction.  Excellent clamping capability.  Repetition rate (duty cycle): 0.01%.  Typical IR less than 1μA above 10V.  Low profile package and low inductance  600W Peak Pulse power capability at 10×1000μs waveform.  Fast response time: typically less than 1.0ps from 0V to VBR min.  High temperature soldering: 260℃/10s at terminals. Symbol  Plastic package has Underwriters Laboratory Flammability 94V-0.  For surface mounted applications in order to optimize board space. ABSOLUTE MAXIMUM RATINGS (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Storage temperature range Operating junction temperature range Steady state power dissipation at TL=75℃ Peak pulse power dissipation on 10/1000μs waveform Maximum Instantaneous Forward Voltage at 50A for Unidirectional Symbol Value Unit Tstg -55 to +150 ℃ Tj -55 to +150 ℃ PM(AV) 5.0 W PPP 600 W VF 5.0 V MARKING KE 1409 http:// www.jksemi.com KE : Device Marking Code 1409: In ninth week, 2014 2021-10-21 版次: c SMBJ Series 600W Transient Voltage Suppressor ELECTRICAL CHARACTERISTICS (TA=25℃) Part Number Marking VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar Uni Bi V μA min(V) max(V) mA max(V) A SMBJ5.0A SMBJ5.0CA KE AE 5.0 800 6.40 7.00 10 9.2 65.2 SMBJ6.0A SMBJ6.0CA KG AG 6.0 800 6.67 7.37 10 10.3 58.3 SMBJ6.5A SMBJ6.5CA KK AK 6.5 500 7.22 7.98 10 11.2 53.6 SMBJ7.0A SMBJ7.0CA KM AM 7.0 200 7.78 8.60 10 12.0 50.0 SMBJ7.5A SMBJ7.5CA KP AP 7.5 100 8.33 9.21 1 12.9 46.5 SMBJ8.0A SMBJ8.0CA KR AR 8.0 50 8.89 9.83 1 13.6 44.1 SMBJ8.5A SMBJ8.5CA KT AT 8.5 20 9.44 10.40 1 14.4 41.7 SMBJ9.0A SMBJ9.0CA KV AV 9.0 10 10.00 11.10 1 15.4 39.0 SMBJ10A SMBJ10CA KX AX 10 5 11.10 12.30 1 17.0 35.3 SMBJ11A SMBJ11CA KZ AZ 11 5 12.20 13.50 1 18.2 33.0 SMBJ12A SMBJ12CA LE BE 12 5 13.30 14.70 1 19.9 30.2 SMBJ13A SMBJ13CA LG BG 13 1 14.40 15.90 1 21.5 27.9 SMBJ14A SMBJ14CA LK BK 14 1 15.60 17.20 1 23.2 25.9 SMBJ15A SMBJ15CA LM BM 15 1 16.70 18.50 1 24.4 24.6 SMBJ16A SMBJ16CA LP BP 16 1 17.80 19.70 1 26.0 23.1 SMBJ17A SMBJ17CA LR BR 17 1 18.90 20.90 1 27.6 21.8 SMBJ18A SMBJ18CA LT BT 18 1 20.00 22.10 1 29.2 20.6 SMBJ20A SMBJ20CA LV BV 20 1 22.20 24.50 1 32.4 18.6 SMBJ22A SMBJ22CA LX BX 22 1 24.40 26.90 1 35.5 16.9 SMBJ24A SMBJ24CA LZ BZ 24 1 26.70 29.50 1 38.9 15.4 SMBJ26A SMBJ26CA ME CE 26 1 28.90 31.90 1 42.1 14.3 SMBJ28A SMBJ28CA MG CG 28 1 31.10 34.40 1 45.4 13.2 SMBJ30A SMBJ30CA MK CK 30 1 33.30 36.80 1 48.4 12.4 SMBJ33A SMBJ33CA MM CM 33 1 36.70 40.60 1 53.3 11.3 SMBJ36A SMBJ36CA MP CP 36 1 40.00 44.20 1 58.1 10.4 SMBJ40A SMBJ40CA MR CR 40 1 44.40 49.10 1 64.5 9.3 SMBJ43A SMBJ43CA MT CT 43 1 47.80 52.80 1 69.4 8.7 SMBJ45A SMBJ45CA MV CV 45 1 50.00 55.30 1 72.7 8.3 SMBJ48A SMBJ48CA MX CX 48 1 53.30 58.90 1 77.4 7.8 SMBJ51A SMBJ51CA MZ CZ 51 1 56.70 62.70 1 82.4 7.3 http:// www.jksemi.com 2021-10-21 版次: c SMBJ Series 600W Transient Voltage Suppressor ELECTRICAL CHARACTERISTICS (TA=25℃, continued) Part Number Marking VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar Uni Bi V μA min(V) max(V) mA max(V) A SMBJ54A SMBJ54CA NE DE 54 1 60.00 66.30 1 87.1 6.9 SMBJ58A SMBJ58CA NG DG 58 1 64.40 71.20 1 93.6 6.4 SMBJ60A SMBJ60CA NK DK 60 1 66.70 73.70 1 96.8 6.2 SMBJ64A SMBJ64CA NM DM 64 1 71.10 78.60 1 103.0 5.8 SMBJ70A SMBJ70CA NP DP 70 1 77.80 86.00 1 113.0 5.3 SMBJ75A SMBJ75CA NR DR 75 1 83.30 92.10 1 121.0 5.0 SMBJ78A SMBJ78CA NT DT 78 1 86.70 95.80 1 126.0 4.8 SMBJ85A SMBJ85CA NV DV 85 1 94.40 104.0 1 137.0 4.4 SMBJ90A SMBJ90CA NX DX 90 1 100.0 111.0 1 146.0 4.1 SMBJ100A SMBJ100CA NZ DZ 100 1 111.0 123.0 1 162.0 3.7 SMBJ110A SMBJ110CA PE EE 110 1 122.0 135.0 1 177.0 3.4 SMBJ120A SMBJ120CA PG EG 120 1 133.0 147.0 1 193.0 3.1 SMBJ130A SMBJ130CA PK EK 130 1 144.0 159.0 1 209.0 2.9 SMBJ150A SMBJ150CA PM EM 150 1 167.0 185.0 1 243.0 2.5 SMBJ160A SMBJ160CA PP EP 160 1 178.0 197.0 1 259.0 2.3 SMBJ170A SMBJ170CA PR ER 170 1 189.0 209.0 1 275.0 2.2 SMBJ180A SMBJ180CA PT ET 180 1 201.0 222.0 1 292.0 2.1 SMBJ190A SMBJ190CA PV EV 190 1 211.0 234.0 1 307.0 2.0 SMBJ200A SMBJ200CA PX EX 200 1 224.0 247.0 1 324.0 1.9 SMBJ210A SMBJ210CA PZ EZ 210 1 233.0 258.0 1 337.0 1.8 SMBJ220A SMBJ220CA QE FE 220 1 246.0 272.0 1 356.0 1.7 SMBJ250A SMBJ250CA QG FG 250 1 279.0 309.0 1 405.0 1.5 SMBJ300A SMBJ300CA QK FK 300 1 335.0 371.0 1 486.0 1.3 SMBJ350A SMBJ350CA QM FM 350 1 391.0 432.0 1 567.0 1.1 SMBJ400A SMBJ400CA QP FP 400 1 447.0 494.0 1 648.0 0.9 SMBJ440A SMBJ440CA QR FR 440 1 492.0 543.0 1 713.0 0.8 ① Surge waveform: 10/1000μs VR :Stand-off Voltage -- Maximum voltage that can be applied VBR: Breakdown Voltage VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp IR: Reverse Leakage Current http:// www.jksemi.com 2021-10-21 版次: c SMBJ Series 600W Transient Voltage Suppressor ORDERING INFORMATION SMBJ xx C A 600W SMB Series 5% VBR Voltage tolerance VR Voltage C: Bi-directional RATINGS AND V‐I CHARACTERISTICS CURVES (TA=25ºC, unless otherwise noted) FIG.1:V- I curve characteristics (Uni-directional) FIG.2:V- I curve characteristics (Bi-directional) IPP V VC VBR VR IT IR VC VBR VR VF FIG.3: Pulse waveform VR V BR VC FIG.4: Pulse derating curve PPP derating in percentage(%) 100 tr = rise time to peak value td = decay t ime to half value tr= 10μs 100 IR IT IPP IPP IPPM(%IRSM) 150 V 80 Pea k value 60 Half val ue 40 50 20 0 0 td 1.0 http:// www.jksemi.com t(ms) 2.0 3.0 4.0 0 0 25 50 TA(℃) 75 100 2021-10-21 125 版次: c 150 175 SMBJ Series 600W Transient Voltage Suppressor SOLDERING PARAMETERS Pb-Free assembly (see FIG.5) -Temperature Min (Ts(min)) Pre Heat -Temperature Max(Ts(max)) -Time (Min to Max) (ts) FIG.5: Reflow condition +150℃ +200℃ TP 60-180 secs. TL Critical Zone TL to TP tL TS(max) Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow tp Ramp-up -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. Temperature Reflow Condition Ramp-down Preheat TS(min) 25 Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ ts time to peak temperatue (t 25℃ to peak) Time PACKAGE MECHANICAL DATA A Dimensions B C Ref. Max. Min. Max. A 4.25 4.75 0.167 0.187 B 3.30 3.94 0.130 0.155 C 1.85 2.21 0.073 0.087 D 0.76 1.52 0.030 0.060 E E 5.08 5.59 0.200 0.220 F 0.051 0.203 0.002 0.008 J K G 0.15 0.31 0.006 0.012 H 2.11 2.44 0.083 0.096 J 6.80 F H Inches Min. G L D Millimeters 2.60 K DO-214AA (SMB) http:// www.jksemi.com L 0.270 2.40 0.100 0.090 2021-10-21 版次: c SMBJ Series 600W Transient Voltage Suppressor TAPE AND REELSPECIFICATION‐SMB Cathode Ref. B W FE P0 P1 A P Dimensions Millimeters Inches 3.76 ± 0.2 0.144 ± 0.012 B 5.69 ± 0.2 0.244 ± 0.012 d 1.5 ± 0.25 0.059 ± 0.004 A D 330.0 13.0 D2 13 ± 1 0.512 ± 0.039 E 1.75 ± 0.2 0.059 ± 0.008 F 5.5 ± 0.1 0.222 ± 0.008 P 8.0 ± 0.2 0.315 ± 0.008 P0 4.0 ± 0.2 0.157 ± 0.008 P1 2.0 ± 0.2 0.079 ± 0.008 W 12.0 ± 0.3 0.472 ± 0.008 W1 16.8 ± 2.0 0.661 ± 0.079 OUTLINE REEL (PCS) PER CARTON (PCS) REEL DIAMETERS (mm) TAPING 3,000 48,000 330 Website: http://www.jksemi.com For additional information, please contact your local SalesRepresentative. ©Copyright 2021, jksemi is a registered trademark of jksemi All rights arereserved http:// www.jksemi.com 2021-10-21 版次: c
SMBJ28A 价格&库存
很抱歉,暂时无法提供与“SMBJ28A”相匹配的价格&库存,您可以联系我们找货
SMBJ28A
  • 10+0.37466
  • 100+0.31245
  • 300+0.28134
  • 3000+0.26320
  • 6000+0.24452
  • 9000+0.23512
