ASMBJ60CA
ASMBJ60CA
    PTTC(聚鼎)
    SMB(DO-214AA)
    双向TVS 60V截止 峰值浪涌电流:6.2A@10/1000US
ASMBJ60CA 数据手册
T VS Diode – ASMBJ Series Features           Plastic package, excellent insulation strength. Glass passivated chip junction in SMB package. Excellent voltage clamping capability. Automotive grade AEC–Q101 qualified. Low Zener impedance. 600W peak pulse power capability on 10/1000s waveform. Typical leakage current less than 1A above 13V. Very fast response time, typically less than 1.0ps from 0 volt to VBR minimum. High temperature soldering guaranteed: 265°C/10 sec. MSL: JEDEC-J-STD-020, Level 1 Applications     I/O interface, VCC bus Telecom / Automotive Industrial and consumer electronic applications. Relay and electromagnetic valve surge absorption. Agency Approval  UL certification pending Mechanical and Physical Data   Case: JEDEC SMB molded plastic. Axial leaded, solderable per MIL-STD-750, Method 2026  Polarity: Color band denoted cathode except bidirectional. Maximum Ratings and Thermal Characteristics Parameter Peak Pulse Power Dissipation on 10/1000s waveform (Note 1, Fig.1). Peak Pulse Current of 10/1000s waveform (Note 1, Fig.3). Steady State Power Dissipation at TL = 75°C, Lead lengths 0.375”, (9.5mm) (Fig.5). Peak Forward Surge Current, 8.3 ms Single Half Sine Wave Superimposed on Rated Load (Note 2, Fig.6). Operating Junction and Storage Temperature Range. Symbol Value Unit PPPM Min 600 Watt IPPM See Table Amp PM(AV) 5.0 Watt IFSM 100 Amp TJ, TSTG -55~150 °C Note: 1. Non-repetitive current pulse, per Fig.3 and derated above TA = 25°C per Fig.2. 2. 8.3ms single half sine wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum. Part Number Code ASMBJ □□□ C A - □□□ Packaging Code (T13: Tape with 13” Reel; T7: Tape with 7”) VBR Voltage tolerance (A: 5%; Blank: 10%) C: Bi-directional; Blank: Uni-directional Reverse Stand-Off Voltage or Typical Breakdown Voltage Automotive ASMBJ Series (600W) 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 1 of 6 2016/12/1 Rev: A T VS Diode – ASMBJ Series I-V Curve Characteristics PPPM Peak Pulse Power Dissipation – Maximum power dissipation VR Stand-off Voltage – Maximum voltage that can be applied to the TVS without operation VBR Breakdown Voltage – Maximum voltage that flows through the TVS at a specified test current (I T) VC Clamping Voltage – Peak voltage measured across the TVS at a specified IPPM (Peak Impulse Current) IR Reverse Leakage Current – Current measured at VR VF Forward Voltage Drop for Uni-directional Electrical Characteristics Part Number Marking Reverse Test Breakdown Voltage Stand Off Current VBR (V) @ IT Voltage VR IT Min. Max. (V) (mA) Maximum Clamping Voltage VC (V) @ IPP Maximum Peak Pulse Current IPP (A) Maximum Reverse Leakage IR (A) @ VR UL Uni Bi Uni Bi ASMBJ11A ASMBJ11CA KZA AZA 11.0 12.2 13.5 1 18.2 33.0 1 Pending ASMBJ12A ASMBJ12CA LEA BEA 12.0 13.3 14.7 1 19.9 30.2 1 Pending ASMBJ13A ASMBJ13CA LGA BGA 13.0 14.4 15.9 1 21.5 28.0 1 Pending ASMBJ14A ASMBJ14CA LKA BKA 14.0 15.6 17.2 1 23.2 25.9 1 Pending ASMBJ15A ASMBJ15CA LMA BMA 15.0 16.7 18.5 1 24.4 24.6 1 Pending ASMBJ16A ASMBJ16CA LPA BPA 16.0 17.8 19.7 1 26.0 23.1 1 Pending ASMBJ17A ASMBJ17CA LRA BRA 17.0 18.9 20.9 1 27.6 21.8 1 Pending ASMBJ18A ASMBJ18CA LTA BTA 18.0 20.0 22.1 1 29.2 20.6 1 Pending ASMBJ19A ASMBJ19CA LBA BBA 19.0 21.1 23.3 1 30.8 48.7 1 Pending ASMBJ20A ASMBJ20CA LVA BVA 20.0 22.2 24.5 1 32.4 18.6 1 Pending ASMBJ22A ASMBJ22CA LXA BXA 22.0 24.4 26.9 1 35.5 16.9 1 Pending ASMBJ24A ASMBJ24CA LZA BZA 24.0 26.7 29.5 1 38.9 15.5 1 Pending ASMBJ26A ASMBJ26CA MEA CEA 26.0 28.9 31.9 1 42.1 14.3 1 Pending ASMBJ28A ASMBJ28CA MGA CGA 28.0 31.1 34.4 1 45.4 13.3 1 Pending ASMBJ30A ASMBJ30CA MKA CKA 30.0 33.3 36.8 1 48.4 12.4 1 Pending ASMBJ33A ASMBJ33CA MMA CMA 33.0 36.7 40.6 1 53.3 11.3 1 Pending ASMBJ36A ASMBJ36CA MPA CPA 36.0 40.0 44.2 1 58.1 10.4 1 Pending ASMBJ40A ASMBJ40CA MRA CRA 40.0 44.4 49.1 1 64.5 9.3 1 Pending 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 2 of 6 2016/12/1 Rev: A T VS Diode – ASMBJ Series Part Number Marking Reverse Test Breakdown Voltage Stand Off Current VBR (V) @ IT Voltage VR IT Min. Max. (V) (mA) Maximum Clamping Voltage VC (V) @ IPP Maximum Peak Pulse Current IPP (A) Maximum Reverse Leakage IR (A) @ VR UL Uni Bi Uni Bi ASMBJ43A ASMBJ43CA MTA CTA 43.0 47.8 52.8 1 69.4 8.7 1 Pending ASMBJ45A ASMBJ45CA MVA CVA 45.0 50.0 55.3 1 72.7 8.3 1 Pending ASMBJ48A ASMBJ48CA MXA CXA 48.0 53.3 58.9 1 77.4 7.8 1 Pending ASMBJ51A ASMBJ51CA MZA CZA 51.0 56.7 62.7 1 82.4 7.3 1 Pending ASMBJ54A ASMBJ54CA NEA DEA 54.0 60.0 66.3 1 87.1 6.9 1 Pending ASMBJ58A ASMBJ58CA NGA DGA 58.0 64.4 71.2 1 93.6 6.5 1 Pending ASMBJ60A ASMBJ60CA NKA DKA 60.0 66.7 73.7 1 96.8 6.2 1 Pending ASMBJ64A ASMBJ64CA NMA DMA 64.0 71.1 78.6 1 103.0 5.9 1 Pending ASMBJ70A ASMBJ70CA NPA DPA 70.0 77.8 86.0 1 113.0 5.3 1 Pending ASMBJ75A ASMBJ75CA NRA DRA 75.0 83.3 92.1 1 121.0 5.0 1 Pending ASMBJ78A ASMBJ78CA NTA DTA 78.0 86.7 95.8 1 126.0 4.8 1 Pending Note: 1. For bi-directional type having VR of 10 volts and less, the IR limit is double. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 3 of 6 2016/12/1 Rev: A T VS Diode – ASMBJ Series Ratings and Characteristic Curves Fig 1 - Peak Pulse Power Rating Curve Fig 2 - Pulse Derating Curve Fig 3 - Pulse Waveform Fig 4 – Typical Junction Capacitance Uni-directional Fig 5 – Steady State Power Dissipation Derating Curve Fig 6 – Maximum Non-Repetitive Forward Surge Current (Uni-directional Only) 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 4 of 6 2016/12/1 Rev: A T VS Diode – ASMBJ Series Marking Definitions PolyTrans Trade mark Lot No Marking Code Cathode Band (For Uni-directional product only) Physical Dimensions Dimension A B C D E F G H I J K L Millimeters Inches Min Max Min Max 1.90 4.06 3.30 1.95 0.76 5.21 0.15 2.26 2.16 2.16 2.20 4.70 3.94 2.44 1.52 0.20 5.59 0.31 2.74 - 0.077 0.160 0.130 0.084 0.030 0.205 0.006 0.089 0.085 0.085 0.086 0.180 0.155 0.096 0.060 0.008 0.220 0.012 0.107 - Lead Free Reflow Soldering Recommendations Preheat - Temperature Min (Ts_min) - Temperature Max (Ts_max) - Time (Ts_min to Ts_max) - Average Ramp-Up Rate 150ºC 200ºC 60-180 seconds 1~3ºC/second Peak Temperature 260ºC max. Time within 5ºC of actual Peak Temperature (tp) 40 seconds max. Ramp-Down Rate 6 ºC /second max. Note: If the soldering temperatures exceed the recommended profile, devices may not meet the performance requirements. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 5 of 6 2016/12/1 Rev: A T VS Diode – ASMBJ Series Packaging Information Part Number Packaging Code Component Package Quantity ASMBJ Series ASMBJ Series T13 T7 DO-214AA DO-214AA 3000 500 Packaging Option Tape & Reel – 12mm tape/13” reel Tape & Reel – 12mm tape/7” reel Packaging Specification EIA STD RS-481 EIA STD RS-481 Tape and Reel Specifications 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 6 of 6 2016/12/1 Rev: A
ASMBJ60CA 价格&库存
很抱歉,暂时无法提供与“ASMBJ60CA”相匹配的价格&库存,您可以联系我们找货
