P6SMB20CA
P6SMB20CA
    JKSEMI(金开盛)
    SMB(DO-214AA)
    双向TVS 17.1V截止 峰值脉冲电流:21.7A@10/1000US
P6SMB20CA 数据手册
P6SMB Series 600W Transient Voltage Suppressor DESCRIPTION: TVS diodes can be used in a wide range of applications which like consumer electronic products, automotive industries, munitions, telecommunications, aerospace industries, and intelligent control systems. SMB FEATURES:  Glass passivated or planar junction.  Excellent clamping capability.  Repetition rate (duty cycle): 0.01%.  Typical IR less than 1μA above 10V.  Low profile package and low inductance.  600W Peak Pulse power capability at 10×1000μs waveform.  Fast response time: typically less than 1.0ps from 0V to VBR min. Symbol  High temperature soldering: 260℃/10s at terminals.  Plastic package has Underwriters Laboratory Flammability 94V-0.  For surface mounted applications in order to optimize board space. ABSOLUTE MAXIMUM RATINGS (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Storage temperature range Operating junction temperature range Steady state power dissipation at TL=75℃ Peak pulse power dissipation on 10/1000μs waveform Maximum Instantaneous Forward Voltage at 50A for Unidirectional Symbol Value Unit Tstg -55 to +150 ℃ Tj -55 to +150 ℃ PM(AV) 5.0 W PPP 600 W VF 5.0 V MARKING 6V8A 1409 http:// www.jksemi.com 6V8A : Device Marking Code 1409: In ninth week, 2014 2021-10-21 版次: c P6SMB Series 600W Transient Voltage Suppressor ELECTRICAL CHARACTERISTICS (TA=25℃) Part Number Marking VR IR@ VR Uni-polar Bi-polar Uni Bi (V) μA P6SMB6.8A P6SMB6.8CA 6V8A 6V8C 5.8 P6SMB7.5A P6SMB7.5CA 7V5A 7V5C P6SMB8.2A P6SMB8.2CA 8V2A P6SMB9.1A P6SMB9.1CA P6SMB10A VBR@IT IT VC@ IPP IPP① min(V) max(V) mA V A 1000 6.45 7.14 10 10.5 58.1 6.4 500 7.13 7.88 10 11.3 54.0 8V2C 7.02 200 7.79 8.61 10 12.1 50.4 9V1A 9V1C 7.78 50 8.65 9.55 1 13.4 45.5 P6SMB10CA 10A 10C 8.55 10 9.50 10.50 1 14.5 42.1 P6SMB11A P6SMB11CA 11A 11C 9.4 5 10.50 11.60 1 15.6 39.1 P6SMB12A P6SMB12CA 12A 12C 10.2 5 11.40 12.60 1 16.7 36.5 P6SMB13A P6SMB13CA 13A 13C 11.1 5 12.40 13.70 1 18.2 33.5 P6SMB15A P6SMB15CA 15A 15C 12.8 1 14.30 15.80 1 21.2 28.8 P6SMB16A P6SMB16CA 16A 16C 13.6 1 15.20 16.80 1 22.5 27.1 P6SMB18A P6SMB18CA 18A 18C 15.3 1 17.10 18.90 1 25.2 24.2 P6SMB20A P6SMB20CA 20A 20C 17.1 1 19.00 21.00 1 27.7 21.7 P6SMB22A P6SMB22CA 22A 22C 18.8 1 20.90 23.10 1 30.6 19.7 P6SMB24A P6SMB24CA 24A 24C 20.5 1 22.80 25.20 1 33.2 18.4 P6SMB27A P6SMB27CA 27A 27C 23.1 1 25.70 28.40 1 37.5 16.3 P6SMB30A P6SMB30CA 30A 30C 25.6 1 28.50 31.50 1 41.4 14.7 P6SMB33A P6SMB33CA 33A 33C 28.2 1 31.40 34.70 1 45.7 13.3 P6SMB36A P6SMB36CA 36A 36C 30.8 1 34.20 37.80 1 49.9 12.2 P6SMB39A P6SMB39CA 39A 39C 33.3 1 37.10 41.00 1 53.9 11.3 P6SMB43A P6SMB43CA 43A 43C 36.8 1 40.90 45.20 1 59.3 10.3 P6SMB47A P6SMB47CA 47A 47C 40.2 1 44.70 49.40 1 64.8 9.3 P6SMB51A P6SMB51CA 51A 51C 43.6 1 48.50 53.60 1 70.1 8.6 P6SMB56A P6SMB56CA 56A 56C 47.8 1 53.20 58.80 1 77.0 7.8 P6SMB62A P6SMB62CA 62A 62C 53.0 1 58.90 65.10 1 85.0 7.1 P6SMB68A P6SMB68CA 68A 68C 58.1 1 64.60 71.40 1 92.0 6.6 P6SMB75A P6SMB75CA 75A 75C 64.1 1 71.30 78.80 1 103.0 5.9 P6SMB82A P6SMB82CA 82A 82C 70.1 1 77.90 86.10 1 113.0 5.4 P6SMB91A P6SMB91CA 91A 91C 77.8 1 86.50 95.50 1 125.0 4.8 P6SMB100A P6SMB100CA 100A 100C 85.5 1 95.00 105.0 1 137.0 4.4 http:// www.jksemi.com 2021-10-21 版次: c P6SMB Series 600W Transient Voltage Suppressor ELECTRICAL CHARACTERISTICS (TA=25℃, continued) Part Number Uni-Polar VR IR@ VR VBR@IT IT VC@ IPP IPP① min(V) max(V) mA V A Uni Bi V μA P6SMB110A P6SMB110CA 110A 110C 94.0 1 105.0 116.0 1 152.0 4.0 P6SMB120A P6SMB120CA 120A 120C 102 1 114.0 126.0 1 165.0 3.7 P6SMB130A P6SMB130CA 130A 130C 111 1 124.0 137.0 1 179.0 3.4 P6SMB150A P6SMB150CA 150A 150C 128 1 143.0 158.0 1 207.0 2.9 P6SMB160A P6SMB160CA 160A 160C 136 1 152.0 168.0 1 219.0 2.8 P6SMB170A P6SMB170CA 170A 170C 145 1 162.0 179.0 1 234.0 2.6 P6SMB180A P6SMB180CA 180A 180C 154 1 171.0 189.0 1 246.0 2.5 P6SMB200A P6SMB200CA 200A 200C 171 1 190.0 210.0 1 274.0 2.2 P6SMB220A P6SMB220CA 220A 220C 185 1 209.0 231.0 1 328.0 1.9 P6SMB250A P6SMB250CA 250A 250C 214 1 237.0 263.0 1 344.0 1.8 P6SMB300A P6SMB300CA 300A 300C 256 1 285.0 315.0 1 414.0 1.5 P6SMB350A P6SMB350CA 350A 350C 300 1 332.0 368.0 1 482.0 1.3 P6SMB400A P6SMB400CA 400A 400C 342 1 380.0 420.0 1 548.0 1.1 P6SMB440A P6SMB440CA 440A 440C 376 1 418.0 462.0 1 602.0 1.0 P6SMB480A P6SMB480CA 480A 480C 408 1 456.0 504.0 1 658.0 0.9 P6SMB510A P6SMB510CA 510A 510C 434 1 485.0 535.0 1 698.0 0.9 P6SMB550A P6SMB550CA 550A 550C 460 1 513.0 567.0 1 740.0 0.8 P6SMB600A P6SMB600CA 600A 600C 512 1 570.0 630.0 1 828.0 0.75 ① Surge Bi-Polar Marking waveform: 10/1000μs VR :Stand-off Voltage -- Maximum voltage that can be applied VBR: Breakdown Voltage VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp IR: Reverse Leakage Current http:// www.jksemi.com 2021-10-21 版次: c P6SMB Series 600W Transient Voltage Suppressor ORDERING INFORMATION P6SMB xx C A 600W SMB Series 5% VBR Voltage tolerance VBR Voltage C: Bi-directional RATINGS AND V‐I CHARACTERISTICS CURVES (TA=25ºC, unless otherwise noted) FIG.1:V- I curve characteristics (Uni-directional) FIG.2:V- I curve characteristics (Bi-directional) IPP V VC VBR VR IT IR VC VBR VR VF VR V BR VC FIG.4: Pulse derating curve FIG.3: Pulse waveform PPP derating in percentage(%) 100 tr = rise time to peak value td = decay t ime to half value tr= 10μs 100 IR IT IPP IPP IPPM(%IRSM) 150 V 80 Pea k value 60 Half val ue 40 50 20 0 0 td 1.0 http:// www.jksemi.com t(ms) 2.0 3.0 4.0 0 0 25 50 TA(℃) 75 100 2021-10-21 125 版次: c 150 175 P6SMB Series 600W Transient Voltage Suppressor SOLDERING PARAMETERS Pb-Free assembly (see FIG.5) Reflow Condition -Temperature Min (Ts(min)) -Temperature Max(Ts(max)) +200℃ TP -Time (Min to Max) (ts) 60-180 secs. TL Critical Zone TL to TP tL TS(max) Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow tp Ramp-up -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. Temperature Pre Heat FIG.5: Reflow condition +150℃ Ramp-down Preheat TS(min) 25 Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ ts time to peak temperatue (t 25℃ to peak) Time PACKAGE MECHANICAL DATA A Dimensions B C Ref. Max. Min. Max. A 4.25 4.75 0.167 0.187 B 3.30 3.94 0.130 0.155 C 1.85 2.21 0.073 0.087 D 0.76 1.52 0.030 0.060 E E 5.08 5.59 0.200 0.220 F 0.051 0.203 0.002 0.008 J K G 0.15 0.31 0.006 0.012 H 2.11 2.44 0.083 0.096 J 6.80 F H Inches Min. G L D Millimeters 2.60 K DO-214AA (SMB) http:// www.jksemi.com L 0.270 2.40 0.100 0.090 2021-10-21 版次: c P6SMB Series 600W Transient Voltage Suppressor TAPE AND REELSPECIFICATION‐SMB Cathode Ref. B W FE P0 P1 A P Dimensions Millimeters Inches 3.76 ± 0.2 0.144 ± 0.012 B 5.69 ± 0.2 0.244 ± 0.012 d 1.5 ± 0.25 0.059 ± 0.004 A D 330.0 13.0 D2 13 ± 1 0.512 ± 0.039 E 1.75 ± 0.2 0.059 ± 0.008 F 5.5 ± 0.1 0.222 ± 0.008 P 8.0 ± 0.2 0.315 ± 0.008 P0 4.0 ± 0.2 0.157 ± 0.008 P1 2.0 ± 0.2 0.079 ± 0.008 W 12.0 ± 0.3 0.472 ± 0.008 W1 16.8 ± 2.0 0.661 ± 0.079 OUTLINE REEL (PCS) PER CARTON (PCS) REEL DIAMETERS (mm) TAPING 3,000 48,000 330 Website: http://www.jksemi.com For additional information, please contact your local SalesRepresentative. ©Copyright 2021, jksemi is a registered trademark of jksemi All rights arereserved http:// www.jksemi.com 2021-10-21 版次: c
P6SMB20CA 价格&库存
很抱歉,暂时无法提供与“P6SMB20CA”相匹配的价格&库存,您可以联系我们找货
P6SMB20CA
库存:2482
