Document: W03020006, Rev: F
WSxxP6SMB(-B)
Power Transient Voltage Suppressor
Features
600 watts Peak Pulse Power (10/1000μs)
Unidirectional and Bidirectional Protection
Fast Response Time : Typically < 1ns
Excellent Clamping Capability
Built-in Strain relief
Low inductance
Low profile package
High temperature solder:260℃/10 seconds at terminal
SMB
(JEDEC DO-214AA)
Mechanical Characteristics
Applications
JEDEC DO-214AA package
I/O Interfaces
Molding compound flammability rating:
Power lines
UL 94V-0
Automotive and Telecommunication
Marking : Marking Code
Computers &Consumer Electronics
Packaging : Tape and Reel per EIA 481
Industrial Electronics
RoHS &UL497B Compliant
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power (tp =10/1000μs) (see Note1,2& 3)
PPPM
600
Watts
Peak pulse current (10/1000μs) (see Note2&3)
IPPM
See Electrical
Characteristics
A
Peak Forward surge current (see Note4&5)
IFSM
100
A
Power Dissipation on infinite heat sink TL = 50 °C (Fig5)
PD
5.0
W
Operating Junction Temperature range
TJ
-65 to + 150
TSTG
-65 to + 150
Storage Temperature range
Note1: Peak Pulse Power Rating as Pulse Width, per Fig1.
Note2: Peak Pulse Power or Current Derated above TA=25℃ Per Fig. 2 and Non-Repetitive Current Pulse, Per Fig.3.
Note3: Mounted on 5.0x5.0mm2 copper pad to each terminal.
Note4: 8.3ms Single Half Sine Wave or Equivalent Square Wave.
Note5: Maximum Forward Surge Current only for Unidirectional Device per Fig6.
©2008 WAYON Corporation
www.way-on.com
1/6
WSxxP6SMB(-B)
Pin Configuration
PIN 1
PIN 1
PIN 2
PIN 2
Unidirectional
Bidirectional
Electrical Characteristics
UNI-POLAR
BI-POLAR
Reverse
Stand off
Voltage
VRWM
(Volts)
WS5.0P6SMB
WS5.0P6SMB-B
WS6.0P6SMB
Part Number
Breakdown
Voltage
VBR(Volts)@IT
Test
Current
IT
(mA)
Maximum
Clamping
Voltage
Vc@IPP
(Volts)
Maximum
Peak Pulse
Current
Ipp
(Amps)
Maximum
Reverse
Leakage
IR@VRWM
(μA)
MIN
MAX
5.0
6.40
7.07
10
9.2
65.2
800
WS6.0P6SMB-B
6.0
6.67
7.37
10
10.3
58.3
800
WS6.5P6SMB
WS6.5P6SMB-B
6.5
7.22
7.98
10
11.2
53.6
500
WS7.0P6SMB
WS7.0P6SMB-B
7.0
7.78
8.60
10
12.0
50.0
200
WS7.5P6SMB
WS7.5P6SMB-B
7.5
8.33
9.21
1
12.9
46.5
100
WS8.0P6SMB
WS8.0P6SMB-B
8.0
8.89
9.83
1
13.6
44.1
50
WS8.5P6SMB
WS8.5P6SMB-B
8.5
9.44
10.40
1
14.4
41.7
WS9.0P6SMB
WS9.0P6SMB-B
9.0
10.00
11.10
1
15.4
39.0
10
WS10P6SMB
WS10P6SMB-B
10
11.10
12.30
1
17.0
35.3
5
WS11P6SMB
WS11P6SMB-B
11
12.20
13.50
1
18.2
33.0
5
WS12P6SMB
WS12P6SMB-B
12
13.30
14.7
1
19.9
30.2
5
WS13P6SMB
WS13P6SMB-B
13
14.40
15.90
1
21.5
27.9
1
WS14P6SMB
WS14P6SMB-B
14
15.60
17.20
1
23.2
25.9
1
WS15P6SMB
WS15P6SMB-B
15
16.70
18.50
1
24.4
24.6
1
WS16P6SMB
WS16P6SMB-B
16
17.80
19.70
1
26.0
23.1
1
WS17P6SMB
WS17P6SMB-B
17
18.90
20.90
1
27.6
21.7
1
WS18P6SMB
WS18P6SMB-B
18
20.00
22.10
1
29.2
20.5
1
WS20P6SMB
WS20P6SMB-B
24.50
1
32.4
18.5
1
WS22P6SMB
WS22P6SMB-B
22
24.40
26.90
1
35.5
16.9
1
WS24P6SMB
WS24P6SMB-B
24
26.70
29.50
1
38.9
15.4
1
WS26P6SMB
WS26P6SMB-B
26
28.90
31.90
1
42.1
14.3
1
WS28P6SMB
WS28P6SMB-B
28
31.10
34.40
1
45.4
13.2
1
WS30P6SMB
WS30P6SMB-B
30
33.30
36.80
1
48.4
12.4
1
WS33P6SMB
WS33P6SMB-B
33
36.70
40.60
1
53.3
11.3
1
WS36P6SMB
WS36P6SMB-B
36
40.00
44.20
1
58.1
10.3
1
WS40P6SMB
WS40P6SMB-B
40
44.40
49.10
1
64.5
9.3
1
www.way-on.com
2/6
WSxxP6SMB(-B)
Electrical Characteristics (Cont.)
Part Number
UNI-POLAR
BI-POLAR
WS43P6SMB
WS43P6SMB-B
WS45P6SMB
Reverse
Stand off
Voltage
VRWM
(Volts)
Breakdown
Voltage
VBR(Volts)@IT
Test
Current
IT
(mA)
Maximum
Clamping
Voltage
Vc@IPP
(Volts)
Maximum
Peak Pulse
Current
Ipp
(Amps)
Maximum
Reverse
Leakage
IR@VRWM
(μA)
MIN
MAX
43
47.80
52.80
1
69.4
8.6
1
WS45P6SMB-B
45
50.00
55.30
1
72.7
8.3
1
WS48P6SMB
WS48P6SMB-B
48
53.30
58.90
1
77.4
7.8
1
WS51P6SMB
WS51P6SMB-B
51
56.70
62.70
1
82.4
7.3
1
WS54P6SMB
WS54P6SMB-B
54
60.00
66.30
1
87.1
6.9
1
WS58P6SMB
WS58P6SMB-B
58
64.40
71.20
1
93.6
6.4
1
WS60P6SMB
WS60P6SMB-B
60
66.70
73.70
1
96.8
6.2
1
WS64P6SMB
WS64P6SMB-B
64
71.10
78.60
1
103
5.8
1
WS70P6SMB
WS70P6SMB-B
70
77.80
86.00
1
113
5.3
1
WS75P6SMB
WS75P6SMB-B
75
83.30
92.10
1
121
5.0
1
WS78P6SMB
WS78P6SMB-B
78
86.70
95.80
1
126
4.8
1
WS85P6SMB
WS85P6SMB-B
85
94.40
104
1
137
4.4
1
WS90P6SMB
WS90P6SMB-B
90
100
111
1
146
4.1
1
WS100P6SMB
WS100P6SMB-B
100
111
123
1
162
3.7
1
WS110P6SMB
WS110P6SMB-B
110
122
135
1
177
3.4
1
WS120P6SMB
WS120P6SMB-B
120
133
147
1
193
3.1
1
WS130P6SMB
WS130P6SMB-B
130
144
159
1
209
2.9
1
WS150P6SMB
WS150P6SMB-B
150
167
185
1
243
2.5
1
WS160P6SMB
WS160P6SMB-B
160
178
197
1
259
2.3
1
WS170P6SMB
WS170P6SMB-B
170
189
209
1
275
2.2
1
WS180P6SMB
WS180P6SMB-B
180
201
222
1
292
2.1
1
WS200P6SMB
WS200P6SMB-B
200
224
247
1
324
1.9
1
WS220P6SMB
WS220P6SMB-B
220
246
272
1
356
1.7
1
WS250P6SMB
WS250P6SMB-B
250
279
309
1
405
1.5
1
WS300P6SMB
WS300P6SMB-B
300
335
371
1
486
1.3
1
WS350P6SMB
WS350P6SMB-B
350
391
432
1
567
1.1
1
WS400P6SMB
WS400P6SMB-B
400
447
494
1
648
0.9
1
WS440P6SMB
WS440P6SMB-B
440
492
543
1
713
0.9
1
www.way-on.com
3/6
WSxxP6SMB(-B)
Typical Characteristics
Figure 1: Peak Pulse Power Rating Curve
Figure 2: Pulse Derating Curve
Percent of Rated Power or Ipp
P PPM – Peak Pulse Power - KW
110
600W 10/1000µs
Waveform
100
90
80
70
60
50
40
30
td – Pulse Width - µs
Ambient Temperature - TA (℃)
Figure 3: Pulse Waveform
Tj =25℃
Pulse Width(td ) is
defined as the point where
the peak current decays to
50% of IPPM
Percent
IppM
tr =10µs– Rise
Time
IPPM – Peak
Value
100
IPPM /2– Half
Value
50
10/1000µs
Waveform as
defined by R.E.A
td – Pulse
Width
10000
C j – Junction Capacitance ( pF)
150
Figure 4: Typical Junction Capacitance
Bidirectional
VR=0V
Unidirectional
VR=0V
1000
100
2.0
3.0
4.0
10
VBR –Reverse Breakdown Voltage (V)
Figure 5: Steady State Power Dissipation
Derating Curve
Figure 6: Maximum Non-Repetitive
Forward Surge Current Only Unidirectional
5.5
180
Peak Forward Surge Current IFSM (A)
Steady State Power Dissipation PD (W)
t - Time (ms)
5.0
4.5
4.0
3.5
3.0
2.5
2.0
1.5
1.0
0.5
140
120
100
80
60
40
Lead Temperature - TL (℃)
10
100
Number of Cycles at 60HZ
www.way-on.com
4/6
WSxxP6SMB(-B)
Soldering Parameters
Reflow Condition
Pre Heat
Temperature min (Ts(min))
150°C
Temperature max (Ts(max))
200°C
Time (min to max) (ts )
60-190 s
Average ramp up rate (Liquidus Temp) (TL)
to peak
3°C/s max
Ts(max) to TL - Ramp-up Rate
3°C/s max
Reflow
Temperature (TL) (Liquidus)
217°C
Temperature (tL)
60-150 s
Peak Temperature (TP)
260+0/-5 °C
Time within 5°C of actual peak
Temperature (tp)
20-40 s
Ramp-down Rate
5°C/s max
8 minutes
max
260°C
Time 25°C to peak Temperature (TP)
Do not exceed
Outline Drawing – SMB(DO-214AA)
Ref.(mm)
Millimeters
E1
Min.
Max.
A
2.130
2.600
A1
0.300
B
1.900
2.200
E
4.100
4.750
E1
5.210
5.590
D
3.300
3.940
L
0.760
1.520
E
B D
A
A1
L
Recommended Solder Pad Layout
2.74
2.16
2.26
2.16
Dimensions in mm
www.way-on.com
5/6
WSxxP6SMB(-B)
Part Numbering System
Part Marking System
Cathode Band
WS xx P6 SMB -B
(For uni-dire ctional products only)
Bidirectional
Package
Peak Pulse Power
PIN 1
Reverse Stand off Voltage
Way-on
Surge Protection Series
SMBJ
XXXA
PIN 2
C(Bidirectional) or not
Voltage
Package Information
Package Type
Description
Quantity(pcs)
Standard
SMB(DO-214AA)
Tape & Reel -12mm/13″ tape
3000
EIA-481-D
Contact Information
CYG WAYON CIRCUIT PROTECTION CO., LTD.
No.1001, Shiwan(7) Road, Pudong District, Shanghai, P.R.China.201207
Tel: +86-21-68969993 Fax: 86-21-50757680 Email: market@way-on.com
WAYON website: http://www.way-on.com
For additional information, please contact your local Sales Representative.
® is registered trademarks of Wayon Corporation.
Specifications are subject to change without notice.
The device characteristics and parameters in this data sheet can and do vary in different applications and actual device performance may vary over time.
Users should verify actual device performance in their specific applications.
www.way-on.com
6/6
很抱歉,暂时无法提供与“WS58P6SMB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.56906
- 100+0.47164
- 300+0.42293
- 3000+0.37422
- 6000+0.34496
- 9000+0.33027
