SMBJ7.0A
SMBJ7.0A
    ELECSUPER(静芯微)
    SMB(DO-214AA)
    单向TVS 7V截止 峰值脉冲电流:50A
SMBJ7.0A 数据手册
SMBJ SERIES Rev-1.1 www.elecsuper.com SuperTVS – 600W Transient Voltage Suppressor 1. Features ⚫ For surface mounted applications in order ⚫ 600W peak pulse power capability at to optimize board space 10/1000μs waveform, repetition rate (duty ⚫ Low profile package cycle): 0.01% ⚫ Built-in strain relief ⚫ Fast response time ⚫ Glass passivated junction ⚫ Typical IR less than 1μA above 10V ⚫ Low inductance ⚫ Plastic package has underwriters laboratory ⚫ Excellent clamping capability ⚫ Meets MSL level 1, per J-STD-020 flammability 94V-0 ⚫ High Temperature soldering: 260℃/10 seconds at terminals 2. Mechanical Data ⚫ Case: JEDEC DO-214AA. Molded plastic ⚫ over glass passivated junction ⚫ Polarity: Color band denotes cathode except bi-directional models Terminal: Solder plated, solderable per ⚫ Standard Packaging: 12mm tape MIL-STD-750, Method 2026 ⚫ Weight: 0.10g 3. Maximum Ratings and Characteristics Ratings at 25°ambient temperature unless otherwise specified Rating Symbol Value Units Peak pulse power dissipation at 10/1000us waveform(Note1,2) PPPM 600 W Peak pulse current of at 10/1000us waveform(Note1) IPPM See Table A PM(AV) 5.0 W IFSM 100 A TJ, TSTG -65 to 150 ℃ Typical thermal resistance junction to lead RθJL 20 ℃/W Typical thermal resistance junction to ambient RθJA 100 ℃/W Steady state power dissipation at TA=50℃ Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load (JEDEC Method)(Note3) Operating junction and Storage Temperature Range Copyright© ElecSuper Incorporated Contact Us 1 / 7 SMBJ SERIES Rev-1.1 www.elecsuper.com Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2. 2. Mounted on 5.0mm×5.0mm copper pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. 4. Electrical Characteristics (TA=25℃) Reverse Maximum Maximum Stand Part Test Part Maximum Peak Clamping Marking Number Breakdown off Voltage VBR (Volts) Current Voltage @ IT IT Number Reverse Pulse Voltage Leakage ROHS2.0 Current VC @ Ipp VR IR @ VR Ipp UNI BI UNI BI (V) (mA) (V) SMBJ5.0A SMBJ5.0CA KE AE 5 6.4 7 10 9.2 65.3 400 y SMBJ6.0A SMBJ6.0CA KG AG 6 6.67 7.37 10 10.3 58.3 400 y SMBJ6.5A SMBJ6.5CA KK AK 6.5 7.22 7.98 10 11.2 53.6 250 y SMBJ7.0A SMBJ7.0CA KM AM 7 7.78 8.6 10 12 50 100 y SMBJ7.5A SMBJ7.5CA KP AP 7.5 8.33 9.21 1 12.9 46.6 80 y SMBJ8.0A SMBJ8.0CA KR AR 8 8.89 9.83 1 13.6 44.2 50 y SMBJ8.5A SMBJ8.5CA KT AT 8.5 9.44 10.4 1 14.4 41.7 20 y SMBJ9.0A SMBJ9.0CA KV AV 9 10 11.1 1 15.4 39 10 y SMBJ10A SMBJ10CA KX AX 10 11.1 12.3 1 17 35.3 5 y SMBJ11A SMBJ11CA KZ AZ 11 12.2 13.5 1 18.2 33 1 y SMBJ12A SMBJ12CA LE BE 12 13.3 14.7 1 19.9 30.2 1 y SMBJ13A SMBJ13CA LG BG 13 14.4 15.9 1 21.5 28 1 y SMBJ14A SMBJ14CA LK BK 14 15.6 17.2 1 23.2 25.9 1 y SMBJ15A SMBJ15CA LM BM 15 16.7 18.5 1 24.4 24.6 1 y SMBJ16A SMBJ16CA LP BP 16 17.8 19.7 1 26 23.1 1 y SMBJ17A SMBJ17CA LR BR 17 18.9 20.9 1 27.6 21.8 1 y SMBJ18A SMBJ18CA LT BT 18 20 22.1 1 29.2 20.6 1 y SMBJ20A SMBJ20CA LV BV 20 22.2 24.5 1 32.4 18.6 1 y SMBJ22A SMBJ22CA LX BX 22 24.4 26.9 1 35.5 16.9 1 y SMBJ24A SMBJ24CA LZ BZ 24 26.7 29.5 1 38.9 15.5 1 y SMBJ26A SMBJ26CA ME CE 26 28.9 31.9 1 42.1 14.3 1 y SMBJ28A SMBJ28CA MG CG 28 31.1 34.4 1 45.4 13.3 1 y SMBJ30A SMBJ30CA MK CK 30 33.3 36.8 1 48.4 12.4 1 y SMBJ33A SMBJ33CA MM CM 33 36.7 40.6 1 53.3 11.3 1 y SMBJ36A SMBJ36CA MP CP 36 40 44.2 1 58.1 10.4 1 y SMBJ40A SMBJ40CA MR CR 40 44.4 49.1 1 64.5 9.3 1 y SMBJ43A SMBJ43CA MT CT 43 47.8 52.8 1 69.4 8.7 1 y Copyright© ElecSuper Incorporated MIN MAX Contact Us (A) (µA) 2 / 7 SMBJ SERIES Rev-1.1 www.elecsuper.com Maximum Reverse Test Part Part Number Number Stand Breakdown off Voltage VBR (Volts) Current Marking @ IT UNI BI (Volts) SMBJ45A SMBJ45CA MV CV SMBJ48A SMBJ48CA MX SMBJ51A SMBJ51CA SMBJ54A Reverse Pulse Leakage Current IR @ VR Ipp (A) (µA) ROHS2.0 (V) VR BI Peak VC @ Ipp (mA) UNI Maximum Voltage IT Voltage Maximum Clamping MIN MAX (mA) (V) 45 50 55.3 1 72.7 8.3 1 y CX 48 53.3 58.9 1 77.4 7.8 1 y MZ CZ 51 56.7 62.7 1 82.4 7.3 1 y SMBJ54CA NE DE 54 60 66.3 1 87.1 6.9 1 y SMBJ58A SMBJ58CA NG DG 58 64.4 71.2 1 93.6 6.5 1 y SMBJ60A SMBJ60CA NK DK 60 66.7 73.7 1 96.8 6.2 1 y SMBJ64A SMBJ64CA NM DM 64 71.1 78.6 1 103 5.9 1 y SMBJ70A SMBJ70CA NP DP 70 77.8 86 1 113 5.3 1 y SMBJ75A SMBJ75CA NR DR 75 83.3 92.1 1 121 5 1 y SMBJ78A SMBJ78CA NT DT 78 86.7 95.8 1 126 4.8 1 y SMBJ85A SMBJ85CA NV DV 85 94.4 104 1 137 4.4 1 y SMBJ90A SMBJ90CA NX DX 90 100 111 1 146 4.1 1 y SMBJ100A SMBJ100CA NZ DZ 100 111 123 1 162 3.7 1 y SMBJ110A SMBJ110CA PE EE 110 122 135 1 177 3.4 1 y SMBJ120A SMBJ120CA PG EG 120 133 147 1 193 3.1 1 y SMBJ130A SMBJ130CA PK EK 130 144 159 1 209 2.9 1 y SMBJ150A SMBJ150CA PM EM 150 167 185 1 243 2.5 1 y SMBJ160A SMBJ160CA PP EP 160 178 197 1 259 2.3 1 y SMBJ170A SMBJ170CA PR ER 170 189 209 1 275 2.2 1 y SMBJ180A SMBJ180CA PT ET 180 201 222 1 292 2.1 1 y SMBJ200A SMBJ200CA PV EV 200 224 247 1 324 1.9 1 y SMBJ220A SMBJ220CA PX EX 220 246 272 1 356 1.7 1 y SMBJ250A SMBJ250CA PZ EZ 250 279 309 1 405 1.5 1 y SMBJ300A SMBJ300CA QE FE 300 335 371 1 486 1.3 1 y SMBJ350A SMBJ350CA QG FG 350 391 432 1 567 1.1 1 y SMBJ400A SMBJ400CA QK FK 400 447 494 1 648 0.9 1 y SMBJ440A SMBJ440CA QM FM 440 492 543 1 713 0.9 1 y For bidirectional type having VRWM of 10 volts and less, the IR limit is double. Copyright© ElecSuper Incorporated Contact Us 3 / 7 SMBJ SERIES Rev-1.1 www.elecsuper.com 5. Ratings and Characteristic Curves (TA =25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2 Pulse Derating Curve Figure 3 Pulse Waveform Figure 4 Typical Junction Capacitance Figure 5 Steady State Power Dissipation Derating Curve Figure 6 Maximum Non-Repetitive Forward Surge Current Uni-Directional Only Copyright© ElecSuper Incorporated Contact Us 4 / 7 SMBJ SERIES Rev-1.1 www.elecsuper.com 6. Dimension (SMB/DO-214AA) Dimensions Inches Millimeters Min Max A 0.077 0.086 1.95 2.2 B 0.16 0.18 4.06 4.57 C 0.13 0.155 3.3 3.94 D 0.084 0.096 2.13 2.44 E 0.03 0.06 0.76 1.52 F - 0.008 - 0.203 G 0.205 0.22 5.21 5.59 H 0.006 0.012 0.152 0.305 I 0.089 - 2.26 - J 0.085 - 2.16 - K - 0.107 - 2.74 L 0.085 - 2.16 - Copyright© ElecSuper Incorporated Contact Us Min Max 5 / 7 SMBJ SERIES Rev-1.1 www.elecsuper.com 7. Packaging Symbol Dimension W 12.0±0.20 P0 4.0±0.10 P1 8.00±0.10 P2 2.0±0.10 D0 φ1.55±0.10 D1 φ1.5±0.10 E 1.75±0.10 F 5.50±0.10 A0 3.86±0.15 B0 5.65±0.10 K0 2.75±0.15 T 0.25±0.05 D2 φ178.0±2.0 D3 φ50.0min. D4 φ13.0±0.5 W1 16.0±2.0 Quantity: 500PCS D5 330.0±2.0 D6 13.5±0.5 H 2.5±1.0 W2 16.0±2.0 Quantity: 3000PCS Copyright© ElecSuper Incorporated Contact Us 6 / 7 SMBJ SERIES Rev-1.1 www.elecsuper.com DISCLAIMER ELECSUPER SUPERTVS PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products. Copyright© ElecSuper Incorporated Contact Us 7 / 7
SMBJ7.0A 价格&库存
很抱歉,暂时无法提供与“SMBJ7.0A”相匹配的价格&库存,您可以联系我们找货
