SMBJ33CA
SMBJ33CA
    PAKER(派克微)
    SMB(DO-214AA)
SMBJ33CA 数据手册
600W Surface Mount Transinet Voltage Suppression SMBJ Series Features SMB Peak power disspation 600W@10 x 1000 us Pluse Low incremental surge resistance Excellent clamping capability Glass passivated junction Fast response time Typical IR less than 1uA above 10V Halogen free and RoHS compliant Mechanical Data CASE: SMBJ(DO-214AA) Molded Plastic Polarity: By cathode band denites uni-directional decice, none cathode band denotes bi-directional device Mounting Position:Any Symbol Making Code & information Package SMBJ XXX A Packing Description Packing Quantity Tape/Reel,13" reel 3000 SMB SMBJ XXX C A SMBJ 5% VBR Voltage Tolerance XXX CA Bidirectional VRWM Voltage Series Code Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) Parameter Peak Pulse Power Dissipation on 10/1000 us Waveform (Note 1, 2, FIG.1) Power Dissipation on Infinite Heat Sink at TL=50°C Peak Pulse Current of on 10/1000us Waveform (Note 1, FIG.3) Peak Forward Surge Current, 8.3ms Single Half Sine-Wave (Note 2. 3) Operating Junction Temperature Range Storage Temperature Range Symbol Value Units PPPM Min 600 W PD 5 W IPPM See Table 1 A IFSM 100 A TJ -55 to 150 °C TSTG -55 to 150 °C Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25°C per Fig.2. 2 2. Mounted on 5.0x5.0mm (0.03mm thick) Copper Pads to each terminal. 3. Measured on 8.3ms single half sine-wave, or equivalent square wave, for Unidirectional device only. Rev 1: Feb 2018 派克微电子(深圳)有限公司 www.pakermicro.com Page 1 of 3 600W Surface Mount Transinet Voltage Suppression SMBJ Series Electrical Characteristics ( Ratings at 25℃ ambient temperature unless otherwise specified). Type Number (Uni) SMBJ5.0A SMBJ6.0A SMBJ6.5A SMBJ7.0A SMBJ7.5A SMBJ8.0A SMBJ8.5A SMBJ9.0A SMBJ10A SMBJ11A SMBJ12A SMBJ13A SMBJ14A SMBJ15A SMBJ16A SMBJ17A SMBJ18A SMBJ20A SMBJ22A SMBJ24A SMBJ26A SMBJ28A SMBJ30A SMBJ33A SMBJ36A SMBJ40A SMBJ43A SMBJ45A SMBJ48A SMBJ51A SMBJ54A SMBJ58A SMBJ60A SMBJ64A SMBJ70A SMBJ75A SMBJ78A SMBJ85A SMBJ90A SMBJ100A SMBJ110A SMBJ120A SMBJ130A SMBJ150A SMBJ160A SMBJ170A SMBJ180A SMBJ188A SMBJ200A SMBJ210A SMBJ220A SMBJ250A SMBJ300A SMBJ350A SMBJ400A SMBJ440A (Bi) SMBJ5.0CA SMBJ6.0CA SMBJ6.5CA SMBJ7.0CA SMBJ7.5CA SMBJ8.0CA SMBJ8.5CA SMBJ9.0CA SMBJ10CA SMBJ11CA SMBJ12CA SMBJ13CA SMBJ14CA SMBJ15CA SMBJ16CA SMBJ17CA SMBJ18CA SMBJ20CA SMBJ22CA SMBJ24CA SMBJ26CA SMBJ28CA SMBJ30CA SMBJ33CA SMBJ36CA SMBJ40CA SMBJ43CA SMBJ45CA SMBJ48CA SMBJ51CA SMBJ54CA SMBJ58CA SMBJ60CA SMBJ64CA SMBJ70CA SMBJ75CA SMBJ78CA SMBJ85CA SMBJ90CA SMBJ100CA SMBJ110CA SMBJ120CA SMBJ130CA SMBJ150CA SMBJ160CA SMBJ170CA SMBJ180CA SMBJ188CA SMBJ200CA SMBJ210CA SMBJ220CA SMBJ250CA SMBJ300CA SMBJ350CA SMBJ400CA SMBJ440CA Reverse Breakdown Breakdown Test Stand-Off Voltage Min. Voltage Max. Current Voltage @IT @ IT VRMW(V) VBR MIN(V) VBR MAX(V) IT (mA) 5.0 6.40 7.00 10 6.0 6.67 7.37 10 6.5 7.22 7.98 10 7.0 7.78 8.60 10 7.5 8.33 9.21 1 8.0 8.89 9.83 1 8.5 9.44 10.40 1 9.0 10.00 11.10 1 10.0 11.10 12.30 1 11.0 12.20 13.50 1 12.0 13.30 14.70 1 13.0 14.40 15.90 1 14.0 15.60 17.20 1 15.0 16.70 18.50 1 16.0 17.80 19.70 1 17.0 18.90 20.90 1 18.0 20.00 22.10 1 20.0 22.20 24.50 1 22.0 24.40 26.90 1 24.0 26.70 29.50 1 26.0 28.90 31.90 1 28.0 31.10 34.40 1 30.0 33.30 36.80 1 33.0 36.70 40.60 1 36.0 40.00 44.20 1 40.0 44.40 49.10 1 43.0 47.80 52.80 1 45.0 50.00 55.30 1 48.0 53.30 5,890 1 51.0 56.70 62.70 1 54.0 60.00 66.30 1 58.0 64.4 71.20 1 60.0 66.7 73.70 1 64.0 71.1 78.60 1 70.0 77.8 86.00 1 75.0 83.3 1 92.10 78.0 86.7 1 95.80 85.0 94.4 104.00 1 90.0 100.0 111.00 1 100.0 111.0 123.00 1 110.0 122.00 135.00 1 120.0 133.00 147.00 1 130.0 144.00 159.00 1 150.0 167.00 185.00 1 160.0 178.00 197.00 1 170.0 189.00 209.00 1 180.0 201.00 222.00 1 188.0 209.00 231.00 1 200.0 224.00 247.00 1 210.0 237.00 263.00 1 220.0 246.00 272.00 1 250 0. 279 0.0 309 0.0 1 300.0 335.00 371.00 1 350.0 391.00 432.00 1 400.0 447.00 494.00 1 440.0 492.00 543.00 1 Maximum Clamping Voltage VC(V) 9.2 10.3 11.2 12.0 12.9 13.6 14.4 15.4 17.0 18.2 19.9 21.5 23.2 24.4 26.0 27.6 29.2 32.4 35.5 38.9 42.1 45.4 48.4 53.3 58.1 64.5 69.4 72.7 77.4 82.4 87.1 93.6 96.8 103.0 113.0 121.0 126.0 137.0 146.0 162.0 177.0 193.0 209.0 243.0 259.0 275.0 292.0 304.0 324.0 340.0 356.0 405.0 486.0 567.0 648.0 713.0 Peak Pulse Current IPP(A) 65.3 58.3 53.6 50.0 46.6 44.2 41.7 39.0 35.3 33.0 30.2 27.9 25.9 24.6 23.1 21.8 20.6 18.6 16.9 15.5 14.3 13.3 12.4 11.3 10.4 9.3 8.7 8.3 7.8 7.3 6.9 6.5 6.2 5.9 5.3 5.0 4.8 4.4 4.1 3.7 3.4 3.1 2.9 2.5 2.3 2.2 2.1 2.0 1.9 1.8 1.7 1.5 1.3 1.1 0.9 0.9 Reverse Leakage @VRMW IR(uA) 500 500 300 200 100 50 20 10 5 2 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 . IR limit is double. Notes: For Bi-directional type having VRWM. of 10 Volts. and less, the For parts without A, the VBR is ± 10% and VC is 5% higher than with A parts. Rev 1: Feb 2018 派克微电子(深圳)有限公司 www.pakermicro.com Page 2 of 3 SMBJ Series 600W Surface Mount Transinet Voltage Suppression Ratings and Characteristic Curves ( Ratings at 25℃ ambient temperature unless otherwise specified). Fig.1 - Peak Pulse Power Rating Fig.2 - Pulse Derating Cure Fig.3 – Pulse Waveform Fig.4 - Typical Junction Capacitance Package Outline Dimensions: SMB(DO-214AA) Dim T Rev 1: Feb 2018 Millimeters Inches Min Max Min Max L 4.4 4.6 0.173 0.181 D 3.5 3.7 0.138 0.146 D1 1.9 2.1 0.075 0.083 T 5.1 5.48 0.201 0.216 T1 1.0 1.6 0.039 0.063 d - 0.2 - 0.008 H 2.2 2.45 0.087 0.096 H1 2.15 2.35 0.085 0.093 派克微电子(深圳)有限公司 www.pakermicro.com Page 3 of 3
SMBJ33CA
物料型号: SMBJ系列,包括不同型号如SMBJ5.0A、SMBJ6.0A等,直到SMBJ300A、SMBJ350A等。
器件简介: 这些是600W表面贴装瞬态电压抑制二极管,特点是高峰值功率耗散、低增量浪涌电阻、出色的钳位能力和快速响应时间。它们还具有典型的正向电压小于1uA,并且是无卤素和符合RoHS标准的。
引脚分配: 通过阳极带定义单向装置,没有阳极带表示双向设备。安装位置任意。
参数特性: 包括峰值脉冲功率耗散、无限热沉上的功率耗散、峰值脉冲电流、峰值正向浪涌电流、工作结温范围和存储温度范围等。
功能详解: 提供了详细的电气特性表,包括反向工作电压、最小击穿电压、最大击穿电压、测试电流、最大钳位电压、峰值脉冲电流和反向漏电流等。
应用信息: 该系列适用于需要高峰值功率耗散和快速响应的应用场合。
封装信息: 提供了SMB(DO-214AA)的封装轮廓尺寸,包括最小和最大尺寸。
SMBJ33CA 价格&库存
很抱歉,暂时无法提供与“SMBJ33CA”相匹配的价格&库存,您可以联系我们找货
